Question about Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC
Audio central not coping to files
Hi
I cant copy any audio files all of a sudden to my playlists from an audio cd
other programmes work with the same cd , but ive been using roxio for years now but havent got the back up disk otherwise i would have re installed it to see if that would help
help
nigel
  • swabi24 Sep 01, 2008
    I try to re-load the entire programme
  • 476 Answers
Have you done any updates lately???
XP needs SP2 for device functionality,SP3???
Did you install or are already using nero on the same system???
ROXIO & NERO,check compatibility spec's
These guys do not play well together on the same system,
They will try to dominate for resources to be the boss,
Dump Game that one,I don't Play that.
I have heard of some people using www.bitcomet.com for researching what they are looking for but I would not install it unless I had the original,Let me know if thats any help,
or,
Can you give me the make type model etc of you PC thanks
Posted on Jul 23, 2008
Hi, I recently purchased a Creative Zen XFi2 (big mistake). The packaged software Creative Centrale is slow and not very user friendly - I can create a playlist using the software but cannot edit the...
You can use iTunes or iMesh instead for creating a playlist and moving files, but first you will need to copy all the audio files you have from your MP3 player to your computer then use either one of the 2 software I mentioned to sync your audio onto your MP3 PLayer.
Also make sure that the Firmware of your Zen is up to date.
I hope this helps.
Jul 27, 2011 | Audio Players & Recorders
Tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | Computers & Internet
How do I copy a CD, playable on a CD player?
1. First make sure you have some blank CD-R's. 2. Put one in the drive and load iTunes. 3. Make a playlist and select the songs you want and add them to the playlist. 4. When you have the songs you want (no more then 70min worth) highlight the playlist by clicking it 5. Now press the iTunes File Menu and select burn playlist to DISC. 6. In the disk format make sure Audio CD is selected. 7. Press Burn.
You can now use this disk on a CD player.
Regards, Chris
Jul 01, 2011 | Apple 27" iMac 2.8GHz Quad-Core Intel Core...
How do i make a copy to copy
this depends on what you want to copy if its a cd or a dvd you will need the burning software that will support this if you just want to copy a file click start all programs accessories open windows explorer navigate to the file select it right click select copy then you can copy it to another place on your computer
hope this helps
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
May 03, 2011 | Computers & Internet
Radio not play Copies - Laguna (2005)
The default cd player is not MP3 compatible, You would need to buy an after-market Audio Unit.
Sorry but only way to avoid this is to keep coping your mp3's into WMA format and then copy them to disk ...
Jul 11, 2010 | Car Audio & Video
Zen MX MP4 - as an older person I am relatively new to this type of technology. I don't have access to broadband so can't download info about my music files (taken from CDs) from the internet. Consequently...
Support site for the Zen MX, see:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=231&subCatName=MIDI+Keyboards&prodID=18615&prodName=ZEN+MX&bTopTwenty=1&VARSET=prodfaq:PRODFAQ_18615,VARSET=CategoryID:213
Important Tool
Software application "Creative Centrale"
This software can be used for:
1. Ripping audio CD's: transferring from audio into mp3.
2. Making playlists.
3. Edit tag properties like Artist; Album; Genre; Year.
A User's Guide is hidden in the Zen MX Starter Pack 1.14.03, called Creative Centrale.
This download ZENMX_PCApp_E6_1_14_03.exe is about 15 MB sized.
The execute file can be started after download and will install Creative Centrale: The User's Guide can be accessed selecting the question mark in the top of Creative Centrale.
Creative Centrale screen view example:
  • See the icons on the left in top:
Rip for converting audio CD's to mp3.
Transfer for transferring playlists from computer to the player.
New for making a new list: playlist, album, artist, genre.
Edit for edit song info, when selected a song in a playlist.
  • See the icons on the right in top:
Fix unreadable tag properties.
Website: Creative online.
Updates: online update check.
User's Guide helpfile.
Settings for:
music folders search on the computer.
music import CD player(s)
automatic transfer enable/disable
  • Bottom right
Player option with volume adjustment.
Need more help ? Just post a comment.
Dec 06, 2009 | Creative Technology Zen MX Black (8 GB)...
Need to know how to install a game on my computer to a cd
you cant instal on cd because it is a optical instal the game on desk to copy the files and folders came on screen to cd now you can ply by just coping files and folder from cd and by clicking on louncher
Jul 04, 2009 | Computers & Internet
Some OS files not coping
your CD Rom drives could be dirty if if they are not copying files from the CD's correctly. tipically while installing an OS the CD's are moving alot of data very fast and can encounter errors if drives are dusty or dirty or even if the cd's have small scratches or smudges.
I recommend a CD/DVD drive cleaner disk, or fresh copies of your CD's.
You May also have to replace your drives, you can buy replacements fairly cheap from online retailers such as tigerdirect.com or on auction sites.
Apr 17, 2009 | Computers & Internet
After i burn a playlist to cd, audio central deletes the playllist which can not be restored
I use Roxio Easy CD & DVD Creator 6 to burn CDs. No I don't move any files during or after burning the playlist to CD.
Sep 18, 2008 | Computers & Internet
Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC Logo
69 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
