Question about APC Back UPS 650 (APWBK650MC) UPS System
Problems constant alarm both on battery and mains. Meanwhile the battery is tested ok.
  • roselito orque Apr 05, 2013
    how long time ups battery shutdown
Must be either low main power or cable damaged or not inserted properly
Posted on Dec 28, 2008
2004 Chevy Malibu-issue with doors locking and unlocking by themselves. Reset battery and doors are working now except for door locks on passenger side you cannot manually unlock doors? New issue is...
Hi Shannon,
My guess is that something is shorting in the lock control circuit. Sounds to me that your passenger locks are constantly energized in the lock position, causing the battery drain.
This is likely not involving the computer. A good electrical guy can find it pretty quick. Meanwhile, envision that you have little electromagnets energized and hot. These would drain the battery fast. Disconnect negative when not using the car.
Consider unplugging the lock slaves inside the doors until you get a chance to get in at a shop. By slave I mean the actuator that is energized, inside each door.
Doc
Jan 23, 2014 | 2004 Chevrolet Malibu Maxx
Peugeot Alarm Problems
you need a battery connected for the ignition to work, lol..
sounds like there is a short somewhere - might need an auto sparky to look at it.
Nov 21, 2013 | Peugeot 807 Cars & Trucks
2008 electra glide battery draw, test light pulses, now bike wont crank over
The pulsing could be the alarm module. When bike is turned of, you will get small draw for a minute or so and then it should go very low, below a miliamp or so. This is the alarm module setting itself. Check for this. Is battery gone flat while checks were being made? Make sure ignition switch is on when disconnecting battery if alarm (Stock HD) is fitted. If not, alarm module gets confused and can cause problems. The corrct procedure for disconnecting a battery from an alarm fitted HS is - alarm off, ignition switch on, pull main fuse (Maxi Fuse), disconnect battery. To fit, ignition stitch off, connect battery then install main fuse.
Nov 01, 2013 | Harley Davidson FLHTCUI Electra Glide...
I have a 2004 Jeep Grand Cherokee V8 model which gives me a lot of power failure problems. Each time i park it in the garage at night and return in the morning to crank it, the battery gets drained with no...
Ok if you have a multimeter, set it on 12V and hook it up to the negative side on the terminal and the battery and it should read some volts, what that means is that there is a draw. Now while the meter pluged pull one fuse at a time and see the meter, when the meter drops to zero that is the circuit at fault, let me know how you make out.
Apr 22, 2011 | Jeep Grand Cherokee Cars & Trucks
Replaced cycle battery. Scorpio alarm is armed constantly. Cannot reset. Advice?
Have you checked alarm wirinig connections and the sensor sensitivity switch?
If not able to resolve, have you Scorpio Owners manual, and check the electrical diag connections?
Take the power connection off from Scorpio and let it be disconnected for at least 30 minute while that check connection wirings. If all OK then reconnect after 30 minute, adjust sensitivity switch counterclock wise and test if it arming as before.
Mar 27, 2010 | 2004 Yamaha YZF-R1
Security System Alarm Activates in damp weather
hi seems like water is getting inside the drivers door and getting on the alarm switch inside the door or it could just be afaulty alarm switch its the micro switch that connects to the door lock yatse210456
Sep 26, 2008 | 2006 Honda Accord
650 APC UPS
try to change with new battery and test. if it does't work it could be the hardware is malfuntion. but that the lastsolution to think, what are the indicator light is stated? can u descibe more detail on the ups. so i can able to asst u?
Jul 23, 2008 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
1994 Chevy cavalier short circuit
possible SHORT ON THE CHASSIS.CHECK FOR WIRE TOUCHING CHASSIS,ALSO CHECK THE STARTER CABLE.ALSO CHECK DOOR A DOME LIGHTS,AND ALARM.YOU HAVE AN AFTER MARKET STEREO?
Jan 01, 2008 | Car Audio & Video
APC Back UPS 650 (APWBK650MC) UPS System Logo
120 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
