Question about Video Cameras
JVC GR-DX67EX Digital Video Camera - Safe Mode Fault
The fault is - as usual - "Camera is in Safe Mode - remove and replace battery"
I have previously fixed this by leaving the battery out for 24 hours and on re-insertion, quickly pressed the Menu Button which has allowed me to scroll down and reset the camera. Everything was then OK.
This time I can't get the menu to stay long enough to reset before the fault message comes up again.
Is there a hidden reset button somewhere - accessible with a pin, as there is on other equipment?
Many thanks
  • Sion-y-Tren Jul 25, 2008
    Hi
    I have tried the battery thing. I have 2 batteries of my own and today we tried a battery from someone elses camera. Exactly the same fault message. The batteries tested at 8V +/- .01V at no load.
    Camparing a working camera with mine, it seems that, on start-up, the tape winds for considerably longer then the fault shows up.
    Any clues?
  • 64 Answers
The user's manual indicates that if your camera enters safeguard mode even after removing the battery, it is necessary for you to consult your nearest JVC dealer.
Posted on Jul 23, 2008
    Master:
  • 382 Answers
Well acutally theres no other reset option like the one which you enquired which could be accessible with a pin in your video cam..So try the same procedure like Remove your batter for a day or two and then put it back after which try to reset the cam using the reset option in the menu..May be this is a problem with your battery rather the cam,So if this fails try to replace the battery or Service your cam in the authorised showroom..Claim your warranty too!..Thank you..
Please post back on how things turned or for further assistance..
Regards!!..
    Brigadier General:
  • 6,966 Answers
Might it be that your problem is caused by weak battery or the battery contacts in need of cleaning? In certain instances, it may be necessary to lightly scrape the battery contacts so as to remove corrosion. In some versions/models, the battery contacts could be slightly bent in order to provide a more tighter contact with the battery when inserted. Please give the cleaning,bending a try.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 25, 2008
    Hi again,
    Appreciate the "Ask Me". With your indulgence, I would be reposting this in your original problem/post here.
    Bear with me on this one, the battery. Your post, "wind the tape for much longer"
    (all other things being equal) would indicate a comparatively weak
    power source (the battery). Assuming that the battery is not weak, then
    the problem may lie on how the power of the battery is transferred to
    the camera.
    Here is a test, try the camera with the AC adapter (with
    or without the battery). If problem persists, then it is internal to
    the camera, if it works and you could perform the reset, then it is a
    battery issue.
    As earlier stated battery issues need not be the battery itself, it
    maybe how the battery transfers power to the camera. Check the
    terminals of the camera where the battery contacts. Clean or scrape and
    when you try the battery, apply manual pressure (press on the battery)
    to add force to the contact. See if problem persist.
    Software (firmware) update - I am not aware of any updates for your particular model GR-DX67EK, however pls try here.
    Again, good luck and would appreciate an update at your convenience.
JVC Camcorder Error code E 01
Your camera can not load mechanism completely(E01). Could have problem with mechanism or the mode motor itself fails. By the way, serial number is not necessary. Good Luck
Mar 20, 2010 | JVC Cybercam GR-DX95 Mini DV Digital...
Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Apr 28, 2009 | JVC Video Cameras
Hi, Regarding the above fault with my JVC camcorder, I have solved the problem by removing the tape and replacing with a new one. Thanks anyway.
Regards,
**** Coupe
Mar 30, 2009 | JVC Video Cameras
Trouble shooting my GR- DF550 vidio camera
mine is in safe mode 3 too and it won't go away. It's over a year old and not worth $$$ to fix. It's time to move up to a HD hard drive video. I suggest you too.
Jan 20, 2009 | JVC GR-DF550 Mini DV Digital Camcorder
Safe guard mode
Turn off the camera and put it in a cool, dry place for about 30 minutes, then turn it on again.
Sep 10, 2008 | JVC GR-D250 Mini DV Digital Camcorder
JVC Camcorder Model # GR-D270U
I think youre talking about safeguard mode.
Here is the manual if you don't have one:
http://resources.jvc.com/Resources/00/00/94/LYT1354-001A.pdf
See page 51. There should be an error indication number as well.
Jun 19, 2008 | JVC GR-D290 Mini DV Digital Camcorder
JVC DIGITAL VIDEO CAMERA GR-D23EK
Replace ccd base assy. Part no. LYH-30446-002A-S
May 30, 2008 | JVC Cybercam GR-DX75 Mini DV Digital...
JVC GR-D270
Try to put the camera on default settings without using battery, that is using power adapter, do this 2 to 3 times, it will solve your problem.
Jul 20, 2007 | JVC GR-D270 Mini DV Digital Camcorder
Video Cameras Logo
120 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
