Question about APC Back UPS 650 (APWBK650MC) UPS System
Problem Constant alarm both on battery and mains.
    Sergeant:
    Champion:
  • 214 Answers
Need to checked by expert
Posted on Jul 24, 2008
My liftmaster garage door openers as a constant alarm noise. Not beeping. Just constant. How to fix?
Premium Chamberlain garage access systems feature an internal battery backup that will operate the opener in case of a power outage. The garage door opener will emit a beeping sound when it is operating off of battery power or when the battery is no longer able to recharge. needs a battery.
Hope this helps.
Dec 31, 2017 | Building Materials
New smoke detector, new batteries, red light flashing is that normal
copied from the manual, available at the kidde website
RED AND GREEN LED INDICATORS This smoke alarm features separate red and green LED indicators. The LEDs indicate the following: GREEN LED CONSTANT ON - AC power is present. OFF - AC power is not present. RED LED - Can be seen through the Push-to-Test button. Blinks once a minute - Indicating presence of a working battery. Blinks once a second - Smoke alarm senses smoke and simultaneously sounds an audible alarm. Blinks once every 10 seconds - Smoke alarm is quieting an unwanted alarm (Model ADC only). (Interconnected system only): OFF - Another smoke alarm in the network has sensed smoke and is signalling this alarm.
Nov 14, 2015 | Kidde 4618 Firex Hardwire Ionization Smoke...
When I replaced battery my MPT1340 alarm armed it will not disarm either by key or remote
by removing the battery it is possible to corrupt the CPU program where the alarm is located. Constant removing of the lead fixes it immediately but not the corrupted program. Try using a scanner to reset the program.
Nov 29, 2014 | Cars & Trucks
2008 electra glide battery draw, test light pulses, now bike wont crank over
The pulsing could be the alarm module. When bike is turned of, you will get small draw for a minute or so and then it should go very low, below a miliamp or so. This is the alarm module setting itself. Check for this. Is battery gone flat while checks were being made? Make sure ignition switch is on when disconnecting battery if alarm (Stock HD) is fitted. If not, alarm module gets confused and can cause problems. The corrct procedure for disconnecting a battery from an alarm fitted HS is - alarm off, ignition switch on, pull main fuse (Maxi Fuse), disconnect battery. To fit, ignition stitch off, connect battery then install main fuse.
Nov 01, 2013 | Harley Davidson FLHTCUI Electra Glide...
Constant alarm but works fine otherwise
Jordan,
It probably burned up one of the capacitors on the board that signal the UPS to turn the alarm off. I've had this happen before and I unplugged everything, turned the UPS off, disconnected the batteries and then opened the UPS up to cut off the tiny, annoying, surprisingly loud speaker. I then put everything back together and that was the end of it :)
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Feb 02, 2013 | Opti -UPS PowerES 1000 UPS System
How can i shut off my kidde carbon monoxide detector, it is a constant alarm unless you remove the battery completely
Try another hard whack. If that does not undo the initial damage, nada will and you have a nice paper weight.
Sep 01, 2017 | Kidde Nighthawk Combo Gas/co Detector
When turn on, can hear a constant clicking noise but wont turn over. When get a jump turns on immediately. Had starter/battery replaced. Problem has been going on for about 6 years. No one can determine...
Sounds like an aftermarket alarm is stopping the car from turning over... either tow to aftermarket electronics shop or take dash apart and look for something with a bunch of wires coming off it, post the model # here, hopefully someone can help u further...
May 09, 2009 | 1994 Buick LeSabre
Contant Beeping on alarm
The Fail To Comm message is not related to your low battery problem. A Fail to Communicate occurs when the alarm system tries to send a signal (alarm, trouble or restore) to a monitoring service but can't. Most often the causes are telephone related. Has your system been disconnected from it's phone line? Have you recently changed phone services from your main carrier to an internet provider that provides VOIP service? Sometimes alarm systems have a hard time communicating over these services. Whatever the reason for the
Mar 28, 2009 | GE Interlogix Dvmre Pro 10 Channel Triplex...
Problems
must be either low main power or cable damaged or not inserted properly
Jul 23, 2008 | APC Back UPS 650 (APWBK650MC) UPS System
650 APC UPS
try to change with new battery and test. if it does't work it could be the hardware is malfuntion. but that the lastsolution to think, what are the indicator light is stated? can u descibe more detail on the ups. so i can able to asst u?
Jul 23, 2008 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
APC Back UPS 650 (APWBK650MC) UPS System Logo
94 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
