Question about Lands Phones
My phone doesn't ring! When I phone my house from say a mobile, it seems to be ringing ok but there's no ring coming from any phone??I have taken every phone out of the sockets, taken out the broadband filters, got a new phone to try but it just wont ring inside the house?? I can phone out ok, and get a dial tone!just can't seem to get a ringing in???
  • 85 Answers
YOUR SPEAKER ALSO IS DEFECTIVE,REPLACE NEW ONE
Posted on Jul 25, 2008
    Problem Solver:
  • 6 Answers
Contact your dial tone provider, it sounds as if they are not sending you thge ringing voltage from their equipment.
Posted on Jul 24, 2008
  • 682 Answers
Please try different phones one by one while you are confirmed that ringer in high in all phones if you got no ring you must call phone company.
I can make calls but phone doe not ring
You said "it seems to ring once then stops." One possible cause of what you're describing is called a "Ring Trip." It is characterized when the button that flashes to indicate an incoming call changes to steady red (which would normally indicate the call is answered) although no one actually answered the call. If that occurs, then you have to test to see whether you can tell where the problem is coming from. If you unplug all the phones, you can then call in (from a cell phone or other phone that's not part of the system) and see if the incoming call rings unanswered, as it should when no phones are attached. If all rings in OK, plug just one phone in at a time and call in to see if any particular phone causes the problem. If one causes the ring trip, then disconnect that broken phone. If ringing still stops when no phones are attached, you'll have to disconnect the phones' connection wires (Station Wires) at the phone system box that plug into the "Station Ports" (label them before you unplug any!). Do not unplug the plugs for the wires that feed phone company lines into the phone system, the jacks are called CO line ports. With the "Station" wires unplugged, see if If all rings in OK by calling in from a cell phone or other phone that's not part of the system. If all rings in OK, plug just one station wire in at a time to see if one causes the problem. If one station wire causes the ring trip, then disconnect that troublesome wire and inspect its "system box jack" and its phone jack for water damage, carpet cleaning solvent, exterminator spray or any other corrosive liquid damage. Sometimes a staple through a wire where there's humidity can cause the problem. This process will find the offending wire, jack or phone that causes a "Ring Trip." There are many other possibilities, but the extremely limited description you've provided "it seems to ring once then stops." doesn't help me send you a better answer yet.
Jun 27, 2014 | Panasonic KX-T7730 Corded Phone
INCREASE RING TONES FROM 3 RINGS TO 6 RINGS
Generally (without knowing what phone yopu have) you need to press menu, arrow up to answermachine or TAM then press OK then arrow up to settings or TAM settings then press ok then arrow down to answer delay/ring delay/ring number press ok then use arrow keys to adjust rings, when on required number, press ok.
Feb 25, 2011 | Cell Phones
Phone has worked ok till saturday ,now no dial tone ,if i ring my phone with my mobile i can here it ringing but no sound coming from my phone , i plugged in another phone and still the same ,please help...
No dial tone on telephone set? could mean alot of things. Phone went bad, jack is bad(test in different jack or from a network interface, either inside or outside. depending what your dwelling is)
Just to point out a fact, when dial from your mobile to that number that has no dialtone, that ringing sound you hear is from the central office that is putting out that ringing, it has nothing to do with the phone you're trying to ring to. You would hear the ringing sound, even if all your phones were unplugged from every jack in your dwelling.
Oct 25, 2010 | Lands Phones
Nokia 1110i incoming call is not ringing
Your Phone Ringer Default So Please change Ringer And Problem will solved .
thanks.
Jul 20, 2010 | Nokia 1110 Cellular Phone
My phone only rings for 15sec and stops where do i have to change the ringing time
You have to dial a code into the phone and press send, it changes the ring time with t-mobile. Here are the instructions, key part is what number you choose to put in the ( ), (10) (15) (30), etc. You seem to be at (15) right now.
try this from your phone to extend the ring time
dial **61*18056377243**(5-10-15-30)# send
again, the numbers in() represent the amount of time you want the phone to ring before going to voice mail. this can only be done with t-mobile2_bing.gif
Nov 28, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Problem with incoming call ring alret
It may change due to your profile or because of your memory card (if u have one).
Apr 22, 2009 | Nokia N73 Cellular Phone
No sound on my house phone
The phone company just brings the line to the demarc( the box on the side of your house) go there and if it is a new style box there will be a place to unplug the house and you can plug in your phone. If you have dial tone and the "demarc" the hose wiring needs to be strigtened out, if you do not have dial tone and the "demarc" then it is the telephone companies problem. It is much easier to test with a corded phone if you have one , good luck
Dec 24, 2008 | Uniden UIP1868G 5.8 GHZ DIGITAL WHOLE...
No ring on phone
check that you have master type socket
Jun 02, 2008 | Lands Phones
Lands Phones Logo
458 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
