Samsung pcj522r The funny thing is I never could completely get the convergance in, but the screen will have flashing lines running up and down the screen. I noticed the screen brighten and darken on the flashing.
  • 8,617 Answers
I am at a loss for what your symptoms are. Did you have a convergence issue and while adjusting your screen is flashing? Please respond to the same post each time so I dont lose any previous info. thanks
Posted on Jul 23, 2008
52inch projection screen television has only red and green colors and its difficult to see the picture.
If the picture looks 3d with lines bowed it may be a convergence problem---go into the customer menu and call up convergence and at least look.
Aug 27, 2012 | Samsung PCJ522R 52" Rear Projection...
I can not adjust the convergance with the remote or TV buttons
Ur convergence is dead.Must change the convergence board.Buy the whole refurbish convergence at Tv repair world.com for the replacement.The Samsung/Akai use the same convergence boards.
Mar 23, 2010 | Samsung PCJ522R 52" Rear Projection...
My Samsung 52" Older Big Screen went out. When I plug it in, it makes a funny sound like it's trying to come on then starts clicking sounds like a cricket noise. any ideas??? model pcj522r
The convergence is dead.It cause 3D colors misalign
and clicking chirping noise with no power on.Know how how to solders?The 2 Convergence ICS must change and all it resistors. Tries Tv Repair World.com,Tvrepairkits.com for the convergence kit to repair it ur self.The shop will cost $300 for parts and labors.
Feb 07, 2010 | Samsung PCJ522R 52" Rear Projection...
Samsung pcj522r
That sounds like a solder issue on one of the CRT drive circuit boards. Check the CRT boards for bad solder joints especially on the socket connections.
Jul 23, 2008 | Televison & Video
Samsung pcj522r
no but the board which is on the upper neck of the green CRT could its the velocity board which has an effect on all 3 tubes convergence.
Jul 20, 2008 | Televison & Video
Flash focus will not finish
replace the small convergence board on the left bottom board within the metal case.
Jun 21, 2008 | Samsung PCJ522R 52" Rear Projection...
Samsung pcj522r shuts off randomly
samsungs have convergence ic that heat up and cause tv to shut off but most of the time the colors will be off. Alsp solder connections could cause this on voltage regulators.my guess would be convergence ics cost for repair is 250.00
thanks doctor video
May 12, 2008 | Samsung PCJ522R 52" Rear Projection...
I have a 6 year old Samsung PCJ522R 52" TV.
It sounds like at least one of 3 "IHVT",s popped. in short, a "IHVT" is a high voltage transformer. It will have to be replaced along with any other parts that were damaged in the process.
They do produce a strong odor when they pop!!
It is repairable but at a price. there is a good chance that parts will have to be ordered.
you might consider buying a new LCD HDTV instead of fixing this one.
Dec 27, 2007 | Samsung PCJ522R 52" Rear Projection...
Samsung PCJ522R Pictures is completely shaded with yellow
Everybody here seems to have basically the same problem so I will write a general fix for these Samsungs. First what you got is known as Convergence failure, A Ic or resistor, fuse or some other component has failed in the convergence circuit. So finding the service menu and trying to align the colors or spinning magnets on the CRT’s or a real bad idea of tipping a CRT or mirror would be the equitant of ripping the transmission out of your car because it had a flat tire. When the convergence fails no adjustment will bring it back, and if you do one of these stupid things then you have two problems. Now most of these Samsungs have an easily replicable board that all the convergence amplifiers are on. This can be found by removing the back and seeing if there is a board about 9 X 5 inches big and mounted to the CRT mounts, there will be 5 connector to this board. Now if your set does not have this board and instead has the two convergence Ic’s (these are about the size of a playing card and have the numbers STK392-040 on them) mount down on a board below and to the right ( this is known as the deflection board) this repair will not work for you. Instead you will need to component level repair the convergence circuit. But if you do have this separate convergence board the repair is fairly straight forward. Go to www.vancebaldwin.com or some other supplier and order BP95-00142E this is the convergence board. This board has been crossed several times through the years but this is the current version. Now once you get this board simply replace it making sure to get al the connector back in there original spot. The fire up the set and run Flash focus and for about 95% this will fix the set
Oct 25, 2007 | Samsung PCJ522R 52" Rear Projection...
Sony kp-51sw500
Jul 21, 2007 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
