Question about Bosch Dishwashers
How do we replace soap dispenser for Bosch SGS5302GB/07
  • tina2uk Jul 24, 2008
    thank you. we'll try it and let you know how it went! tina
  • Anonymous Mar 29, 2014
    FACIA CAT NO 00449039 HOW DO YOU REPLACE DOES IT JUST CLIP OFF AND ON
    Scholar:
  • 93 Answers
Unplug the unit. Open the DW door .remove screws.Carefully place it aside. you are going to see soap dispenser unit. remove the wire harness carefully, remove the screws. Replaced it with new one. so simple. assemble back the door panel.
Posted on Jul 24, 2008
I need to replace the soap dispenser on a Bosch dishwasher. I have the replacement part (645208) but I cannot remove the old one. Can you help?
bend all the clips out of the way the dispenser will fall into machine but some washing soap on gasket of new one straighten clips straight with pliers and refit new one push firmly clips will click back into place
Oct 02, 2016 | Bosch Dishwashers
Electra Meister front loading washer softener not dispensing
Dispensing..What? Advice! Oh No you mean the machine? OK Water? Soap? I have to ASSUME both. If you are getting NO soap it is because you are getting NO WATER! So you need to have your water inlet valves replaced or Dispensed. Then your soap will follow
Mar 05, 2014 | Bosch Washing Machines
Washer will not dispense soap from dispenser.
make sure that the soap dispenser if clean and free of residue build up. if this is clean you need to replace the dispencer
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The soap dispenser fails to open at times
Hi
Bosch dishwashers (not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced.
Older Bosch dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Oct 12, 2009 | Bosch Dishwashers
Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Nov 26, 2008 | Bosch SHU9925UC Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Water not heating up in the dishwasher
This appears to have the controls on the front , this unit the heat relay on the control board would separate from the control board causing the unit to quit heating. the control is located in the panel right behind the push buttons. you will either have to replace the control or you may be able to resolder the relay if the board has not been damaged
Jan 09, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
235 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
