Question about Canon MV630i Mini DV Digital Camcorder
MV630I I need to record some footage using an external mic to increase the sound quality. do i just plug in the mic and switch it on or do i need to adjust the camcorder settings?
    Master:
  • 763 Answers
The best is to have a mic plug in on a camcorder its more advantage than using a mic built in. hope that helps you
CHARCOIS
Posted on Jul 23, 2008
Sound noise feedback during recording
Noise can be a big problem when trying to record into a computer. Reducing and canceling out noise using several simple techniques will help increase recording quality and increase your satisfaction with recordings. Solutions range from complete room overhauls to simple changes in the placement of the microphone and other objects in the recording.
Use a stabilized microphone to reduce vibrations. Many hand-held or headset microphones will pick up on vibrations and movements from the user. These vibrations can carry over into the recording and reduce the quality of the recording. Using a microphone stand or stationary microphone will reduce noise while recording. Mic stands will help increase recording quality and off a possible solution that requires very little financial investment. Set up a designated sound room that is set away from the rest of your home. The farther the recording area is from windows and doorways, the better. Windows allow very small amounts of noise to filter in from the outdoors and create white noise in the recording. Hang blankets on the walls around the recording station and use many rough objects in the recording room. Sound travels in waves that bounce back and forth between smooth objects. Blankets and other rough objects will help reduce sound vibrations. These additions to the recording room will reduce ambient sounds from both the room and outside the building by blocking sound waves from bouncing back and forth in the room. If you can make a considerable investment in the room, there are several acoustic products on the market than help nearly eliminate echoes and outside noises. Install software that filters out unwanted sounds and echoes. Many computer applications exist that use programs to increase the quality of recordings and reduce the ambient noise levels in a recording room. Software is used to reduce echoes and feedback in a recording studio. Several free applications can be used to achieve the desired effects when recording. A program called Audacity is one of the most effective software packages that can help reduce noise in recordings. http://audacity.sourceforge.net/ Software can also be used to reduce electronic humming and other white noise that can be picked up during a recoding session. Buy a high-quality microphone with noise and echo cancellation. One of the best investments that a recording specialist can make is a high-quality mic. The microphone itself can reduce many unwanted noises and echoes in the recording room by filtering the actual sounds that are recorded.
b>
Jan 15, 2013 | Computers & Internet
Sound noise feeback during recording
b>
Jan 15, 2013 | Logitech Webcam
My acer aspire 5332 laptop doesnot have clear microphone sound
the issue is that the mic is built in and it has a poor quality ..It was meant to be used for instant messaging calls ..so if you have to make quality recordings use an external one ..either on usb or just plug one in the pink jack ..
you can also go to sound settings in control panel and try to adjust it ..turn on advanced and select to boost it up ..but low the volume to avoid oscillations ..
Dec 19, 2011 | Acer Aspire One PC Notebook
How do I record without sound on the Canon FS200?
go into the settings and switch to external mic and dont use the mic. or if you have an on off switch on the mic switch to off , its cumbersome but works. I have forgot to plug it in all the way and that too works gives you video no sound. you dont need a new camera , good luck
Aug 29, 2011 | Canon FS200 Flash Media Camcorder
How do I switch off the audio on the Panasonic NV-GS250 so I can record video footage with no sound.
I think this camera has manual audio control.
Use the menu system and set the audio to manual then turn down the audio completely.
Another option is to place a microphone jack into the external mic socket without a mic attached. This will mute the onboard mic.
Al
Feb 11, 2011 | Panasonic NV-GS250 Mini DV Digital...
Friends say When i speak sounds like Static any 1 know how to change setting or find it in computer. Im using Satellite Fusion
The external microphone itself could be the culprit, or its connection to the 3.5mm port could be flaky. To test the theory do this:
1 Connect an external microphone to the computer.
2 Click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder.
3 Click the Record button and speak normally into the microphone.
>>>> WIGGLE THE CONNECTION AT THE LAPTOP OR FLEX THE MIC CABLE WHILE RECORDING. Maybe even narrate what you are doing while you record your voice. "Flexing cable near mic, now near plug..." <<<<
NOTE: You can only record 60 seconds at a time.
4 When you have finished recording, click the Stop button.
5 To hear what you just recorded, click the Play button.
6 To save the file, select Save from the File menu.
>>>> If you hear crackling in the playback that correlates with your handling of the cable then bad seating or a bad cable are the problem. <<<<
Adjusting recording quality
The better the quality of the recording, the more disk space the sound file requires. Experiment to find a balance that fits your needs.
1 Open Sound Recorder, if necessary (click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder).
2 In the Sound Recorder window, click Edit, then click Audio Properties.
3 In the Audio Properties window, adjust the Sound Playback quality and volume, and the Sound Recording volume.
4 Click OK.
Your new settings take effect the next time you record.
Dec 30, 2010 | Toshiba (P000257700) Microphone
There is no audio on video playback
I need more detail on your digital cam such what brand, model
It is possible the internal micro was defective, or some model it have external MIC switch, which now on external mic position
if this is Sony brand depend the model it could be the tape transport was out of alignment in this case You need a qualified Tech to repair it
I hope that give you some ideas
Jan 08, 2010 | Cameras
Can not record with mic
For using the mic in karaoke you should mute the mic playback in windows mixer
Jul 06, 2009 | Creative Labs Sound Blaster Live! 24-bit...
I dont understand how to use an external mic. Use of external mic.
Your external mic needs to have a 1/8" plug. You will need to find the "Mic" input, this is generally found behind a removable or hinged plastic or rubber panel, and usually near the A/V plug connectors. When you plug in an external mic, the camera switches over to use it rather than the built-in mic. On this camcorder, you cannot set the recording level of the external mic. The camera sets the level automatically. So it is simply a plug-and-play, or plug-and-record solution.
Using an external mic allows you to reduce self-noise and handling noise. It is generally recommended for better videos. Different microphones are likely to interact in different ways with your camera and its automatic level-setting, so you should try out different microphones if you have more than one available to you.
Sep 26, 2008 | JVC GZ-MG575 Camcorder
Missing Audio
sound changes to external mic. when any ex. mic. is inserted the internal mic. comes out of order then you don't and can't have two sounds same time that mean you only get the ex. mic sound regards please don't forget to rate thx
May 02, 2007 | Canon MV630i Mini DV Digital Camcorder
Canon MV630i Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Chance Miller
Chris Phillips
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
