Cant log in windows live messenger - they says Error code 81000395
  • 22 Answers
As refer to MSN error code,
You may not be able to sign in because you entered the wrong e-mail address. Re-enter your credentials and try to sign in to Messenger again.
If you sure you are enter correct username & password, second thing to check is your connectivity. In Windows Live Messenger,
  1. Click the Tools menu, and then click Options.
  2. In the left pane, click Connection.
  3. Click Refresh to freshen your display and view current information, such as signal strength, account name, and connection type. — or —
  4. To run the Connection Troubleshooter, click Start and the troubleshooter will run an analysis of your system and connection settings (Settings associated with your Internet connection.) . If you're using an 802.11b wireless card, the Connection Troubleshooter may indicate that you have a wired connection.
  5. Click Finish.
To test your connection settings:
  2. Under Connection, click Advanced Settings.
  3. Click Test to run several tests on your connections.
  4. If you'd like to save a log of your server connections, select the Save a log of my server connections to help troubleshoot connection problems check box.
Posted on Jul 23, 2008
I cant insall windows messenger in mu computer acer aspire one
Have you gone to the windows messager website and tryed to install it that way? If it wont let you download, Try installing Windows Live Messenger, or even Windows Live Messenger PLUS. If those are still not working for you, You can log onto through Meebo.com and still chat with your friends.
Jun 03, 2011 | Windows Live Messenger
Can not log on to windows live messanger
Hello.
Are you trying to log-on to the messenger on the PC or mobile?
Mar 08, 2010 | Microsoft Windows Live Messanger
Cant open yahoo messenger
Hi! This error code relates mainly due to your action due to upgrade / re-install / repair of windows XP and to avoid this reinstall XP SP1a [service pack 1a] and immediately restart the system. have fine in all applications
Dec 21, 2009 | Yahoo Messenger
Problem with MSN Messenger
well they were hit with denial of service recently so try again later as it suggested. We cant log you in from here anyway.
Thanks for using FIXYA please rate our help++++ Thanks
Oct 09, 2009 | Microsoft MSN Messenger Connect Service
Error code 8007007
This error indicates a problem with Messenger on your machine, not a problem with the service.
You may be able to quickly solve the problem by installing the following components simply by downloading the MSI files linked following and just running them to install:
> http://messenger.jonathankay.com/redir/w3rc/dw20.asp
> http://messenger.jonathankay.com/redir/w3rc/msvcrt.asp
> http://messenger.jonathankay.com/redir/w3qfe/contacts.asp
After these are installed, try Messenger again.
Aug 25, 2009 | Microsoft Windows Live Messanger
I have the same regsvr32 wintrust.dll error code 0x80070005 i cant log into my hotmail. i found in another forum that i should try running the following: regsvr32 softpub.dll regsvr32 wintrust.dll...
- Double click on the clock in the taskbar and make sure the system clock is set correctly.
- Disable Zone Alarm
- Register softpub.dll using the regsvr32.exe tool.Click Start, and then click Run.
- In the Open box, type regsvr32 softpub.dll and then click OK.
- Do the same for the following regsvr32 wintrust.dll, regsvr32 initpki.dll, regsvr32 MSXML3.dll.
- Restart Windows Live Messenger.
If you are still unable to fix Windows Live Messenger your computer might be infected, I recommend you Download registry cleaner to fix your errors and speed up your computer.
Aug 21, 2009 | Microsoft Windows Xp Home Edition English...
I have a problem with windows live messenger i cant log in
Remove the Windows Live Messenger from the Control Panel, Add Remove Programs including the utilities associated with your live messenger.
Then try reinstalling the Windows Live Messneger from this site
www.microsoft.com/downloads then search for Windows Live Messenger
Hope this woould help
Aug 11, 2009 | Microsoft Windows XP Home Edition
Windows Live messenger Error : 80048820
If you are receiving error 80048820 when trying to sign into Windows Live Messenger you should also get an extended error code. If this extended error code is 80048412 the problem often occurs because the time and date settings on the computer are incorrect. The error will appear like below:
You cannot sign in to Messenger. Additionally, you may receive the following error message:
We were unable to sign you in to the Messenger at this time. Please try again later.
To let us try and troubleshoot the problem, click the Troubleshoot button.
Error code: 80048820
Extended error code: 80048412
The following steps may help resolve your issue:
To troubleshoot the problem on a Microsoft Windows XP-based computer:
1. Click Start, click Run, type control timedate.cpl, and then click OK.
2. In the Date and Time Properties dialog box, confirm that the date and time settings on the computer are correct, and then click OK.
To troubleshoot the problem on a Windows Vista-based computer:
1. Click Start, type control timedate.cpl in the Start Search box, and then press ENTER.
May 29, 2009 | Microsoft Windows Live Messanger
Windows Live Messenger Error 80004005
To fix Windows Live Messenger error 80004005, you have to reinstall the latest version of Windows Live Messenger From here - http://get.live.com/messenger/overview
In case you are curious, the cause of this error is the Microsoft .NET Passport account is blocked by the .NET Messenger Service because your computer may be running a non Microsoft program that is not licensed by Microsoft this is a violation of the MSN Messenger Terms of Use.
Error 80004005 was originally created by MSN Messenger maintenance procedures. In order to stop users from using non Microsoft add-on's, that may harm Microsoft's service.
Have a good day.
Nov 10, 2008 | Microsoft Windows Live Messanger
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
