Question about Toshiba Televison & Video
My toshiba TV is just over 10 years old. I have been watching it when suddenly it shuts down and the power button light was flashing. Went through the steps of unplugging it and plugging it back in and it still did the same thing.
U got problem with power supply module need replacement.
Posted on Jul 27, 2008
You have a major problem. you will need a tech.
after 10 years I recommend replacing it.
Thanks Guy9
Posted on Jul 25, 2008
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
The tv suddenly shuts off
flyback on the verge of giveing out on you.. needs a new flyback..
Apr 21, 2009 | Toshiba CF36G40 36" TV
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony LCD 52 inch
This sound like you are having problems with the power supply board. Since you are getting a momentary picture and sound the fuses are good but TVs today have "shorts" and "overvoltage" circuitry build in that will shut it down on errors. Someone knowledgeable in electronics will have to isolate the exact cause.
Dec 05, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
On and off
That hapened to me once and the solution that worked for me was unpluging the TV for about 5 minutes and pluging it back in, you may just need a new remote though.
Jul 28, 2008 | Philips 55PP9352 55" Projection Television
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Jun 17, 2007 | Bush 5693D 24" TV
Loud electrical sounds
It sounds like the Power transistor that drives the High Voltage Transformer shorted out. The rapid clicking sound you are hearing when pressing the power button now is that of the power supply starting to come up, detecting a short circuit and shutting back off again, preventing further damage. It is likely that the HV Transformer is shorted as well which usually causes the Output transistor to fail. Since the set is only 2 1/2 years old, it is probably worthwhile getting it to a repair shop as long as you have been very satisfied with the picture quality up to this point. If the picture size was larger than you needed, you might consider going down to a 37" LCD HDTV set. Toshiba is tops in this category IMHO.
Mar 30, 2007 | Zenith R40W46 40" Rear Projection...
No sound or picture
Keith, Check fuses Then Resoder The COMPLETE board I bet there is heat related problem W/Old Soder Just a Hunch!!!!!!!! G'Luck Chance One 559 @ Yahoo . Com
Oct 24, 2006 | Toshiba TP55G60 55" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
