Crown CTT3207W stuck on standby will not turn on from the remote or the back button there is definately power as the red standby light is on
  • 1153 Answers
SOURCE: Pioneer SD-62A5 has red standby light, won't turn on
Check C258 video assy.
Posted on Aug 16, 2007
SOURCE: Pioneer SD-532HD5 Projection Screen TV won't turn back on.
The problem is the power supply components over heating. The power supply is on the back side right hand. supply extra cooling via a fan and it will stop shutting down. This is just a cheap and simple fix that wil tie you over for a while. cheers mates.
Posted on Mar 09, 2008
talknerdy2me
SOURCE: samsung hc-r5245w no power
Hello Chac c,
The reason that you are getting a 'red light' is because your lamp is burned out. There is a panel on the back of the TV that gives you access to this lamp. You can remove it and check the part# to be sure then replace it. I did a quick search for you just based on the model# which you provided. You can see it here - http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=samsung+lamp&gg_site=&gg_aid=1295966762
Hope this helps :)
Posted on Mar 17, 2008
  • 213 Answers
SOURCE: My Samsung LCD LA32R7 won't
you have a bad power supply.
Posted on Jun 11, 2008
SD Tech
  • 14553 Answers
SOURCE: can't turn on
When you turn the MAIN off you are killing all power to the set---Some advice---If you Google the model number of this set with the word problem after it you should find what I have seen a lot in these sets: they develop bad solder connections on the power supply printed circuit board---usually the board is about 18 inches tall and 12 inches wide--A number of sites online offer to have you ship them the board and they will resolder it for you.
I have repaired about 12 of these with this problem in the last 2 years---The board has to be removed(there are quite a few plugs that need to be labeled and removed and lots of screws that secure the board in place.)
Maybe not a job for a do it yourself person but the soldering (if it is your problem) will take about 45 minutes(including removal and installing board back).
Like most modern sets this set uses lead free solder and it is soldered(the boards) in a wave or one step process---over time from heat and expansion some connections may crack or even break loose----I would look at the POWER SUPPLY board(follow the power cord as it goes right to it)
If you have any questions or need help please contact me here.
I do this here for free so if this information has helped you take a minute and give me a vote here.
SD TECH
Posted on Sep 06, 2009
Hitachi l37v01ua won't turn on from standby mode.....HELP!!!!
when in stand-by mode then red light's blinking. Try to turn it on not from remote but by pushing a button on the set.
Apr 26, 2015 | Televison & Video
How can i put a crown ctt1506lc in game mode without remote?
I could not find an owner's manual online, so you get a generic answer. Look for an "Input" button among the TV's controls. If you don't find one, go to the TV's lowest channel number (in US TV sets, that's Channel 2). Press the Down Channel button once more. That may take you to the external video input, which I assume is what you want for "game mode."
Jul 26, 2014 | Crown Televison & Video
Preamp stuck in standby mode
a flaslight bulb and batteries and couple of wires can be used to make a continuity tester.and also pls check the small pushbutton(power button)try the remote if theres any
Feb 04, 2014 | Adcom GFP-710 2-Channel Amplifier
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
My crown ctt3207w returns to standby as soon as turned on.
I googled the info and its a easy repair for £14 with parts.Follow the link and your standby problem is sorted, with a little soldering and the tv is easy to open.
http://www.chsinteractive.co.uk/electrical-components/spares-televsion-audio-video/kits-repair-modification-and-upgrade/toshiba/reliability-kit-psu-17pw15-6-vestel-board.htm
Apr 18, 2011 | Televison & Video
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Crown ctt3207w dark picture
on the driver board below the power board check the fuses one of mine had blown
Jun 22, 2008 | Televison & Video
Magnavox 15MF237 LCD - stuck in standby
just one idea.. some set you may program to stay on in case you use cable box and when you turn on the box tv turn on same time but may be defective tv there is relay,transistor and the micro that may be bad so check your settings again ... Good luck
Apr 10, 2008 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
