Question about Siemens Lands Phones
I have only had my Gigaset Duo a short time and everything has worked perfectly until to-day. I am not now able to register the correct date. WEhen I attempt to enter this on one handset I continually get "00.00" and on the I get "17.43". Can you help
Thanks for your concern. However I managed to resolve my query with the help of Siemens.
Posted on Jul 23, 2008
I want to send data to my Gigaset 810 Cordless Phone from my Samsung Galaxy S5830 via Bluetooth
Common issue, some bluetooth devices seem to pair but actually won't work correctly. If you paired and then couldn't get any result, tried this repeatedly, so you should resignate, it is not working.
Jun 19, 2015 | Samsung Lands Phones
Incorrect Date
open shortcut on will show correct date, time, etc tho unit does not as it hasn't changed days..on the shortcut, click on Update settings then Send to receiver..then punch in button on back of Station..says "pc search"..transmitter on unit will start steady flashing..unit will go black..gradually everything comes back..don't touch until all back..everything will now match the stuff on the shortcut and the day and date will have changed to the correct one..I do this process every day.
Jun 01, 2012 | Sharper Image 5 Day Internet Weather...
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
₪ Settings ₪ Base ₪ Base Reset
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
Dec 27, 2017 | Siemens Gigaset C200 Cordless Phone
I am an Englishman living in Spain. I have just purchased a Gigaset AL170 Duo telephones and require an English manual to set up correctly. Can you help?
I looked for the manual in English and couldn't find one, but this is the closest thing I found:
Gigaset AL180 DUO Manual ENGLISH
I hope that could help you.
Aug 02, 2011 | Cell Phones
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
Our Siemens gigaset A2 keeps flashing at us and doesn't work.
First pull the battery fron the handset, pres the register button (Page) for a long time, eg 10 sec, then register the handset through the menu, setings, handset, register
Aug 07, 2010 | Siemens Gigaset 8825 Cordless Phone
Indiglo WR 30M
i wind the clock hands forward until the calendar date and week day changes and then i re-wind the hands until it comes to the correct time. when i re-wind the hands, the week day goes back to the correct date and the calendar date does not go back by one day. i don't know if this is the "correct" way to do it, but it works.
Sep 12, 2008 | Timex 27191 Wristwatch
Phones will not register
Try this:
Pick a handheld, press Menu - H/set settings - Reg Handset - Select Base 1, enter 0000 as password. Now on the bottom of the base station press and hold the Register button in for about 10 seconds or until the h/set beeps.
Jan 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Set correct time on Logitech MX 3200 wireless keyboard
Cordless Desktop MXTM 3200 Laser
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
The time and date on the LCD should now be displayed properly.
Dec 31, 2007 | Logitech Wireless Access Duo Optical...
Lands Phones Logo
192 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
