Question about Panasonic Computers & Internet
Power calibration fix for a Matsushita UJ-831B. My drive will copy a CD or DVD but it fails to burn either, and says power calibration error
  • spottyprince Jul 24, 2008
    Tried that as soon as it happened , no use .
    If anyone else can help , please let me know .
Try to swop the disc that you have for another one-it will very likely burn to the the replacement.Some discs are troublesome.
Posted on Jul 24, 2008
I keep having failed burn sessions it says "Power Calibration error" what and how can I fix that
Their could be several possible reasons and solutions for the above error, basically what is happening is for some reason the CD/DVD burning software is unable to determine the Optimum Power Calibration rate (a small pre-burn test to determine optimal laser power for writing), resulting a disk burn failure. There is no easy way to pinpoint the exact reason, so try all the possible fixes from top to bottom (easy to hard) and see what works:
Try using different brands of quality blank media, most common reason for such error's is cheap blank media.
Try burning at lower speeds (Highly effective).
If this fails try a different burning software
Aug 20, 2010 | Sony AD-7191A DVD±RW Dual Layer Burner
Problem with matshita dvd-ram uj-850S
Your DVD drive was probably misaligned, probably due to some force applied to it such as when you mistakenly added two DVDs at the same time. Or it may be a factory defect. It is difficult to calibrate a DVD drive or any drive for that matter because of high precision needed.
You may try however to just clean the lens which may have been blocked with dirt. Just eject the drive, you will see the lens somewhere in the middle of the platform. Use a drop of 10% alcohol on the tip of a cotton bud and clean the lens without applying too much pressure.
Aug 29, 2008 | Computers & Internet
Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty)
i had the same problem, first when i burn movies i was using fujilim dvd+r after 10 movies burned i use maxell dvd-r i burn just 3 movies then i had a error (Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty) after doing a lot of things to fixed and research thounsands of webpages one told me to use a diferent dvd then i buy sony dvd+r and now everything work perfect, maybe it helps, write me if you need help.
weddie2006@univision.com
Jun 20, 2008 | Toshiba Computers & Internet
My matshita uj-860s disc drive has stopped working
In my case, MATSHITA DVD-RAM UJ-860S did not want to write CD-R,-RW Verbatim using software NERO 8, but is easy to write their own software windows XP.
in the Log file was as follows:
Could not perform start of Disc-at-once
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Power calibration error
whether
Invalid field in parameter
E: MATSHITA DVD-RAM UJ-860S
ACTION! :)
Change in method of recording NERO 8 Burning mode: DAO (Disc-at-once) at Burning mode: TAO (Track-At-Once) all have established!
Simply drive MATSHITA was UNSUPPORTED software producers to write disks.
Updating the software to burn CDs, as is windows XP supports the recording and includes drivers for the drive! :)
Apr 17, 2008 | Computers & Internet
MATSHITA DVD-RAM UJ 85JS problem
I have mashita DVD-ram UJ 850s in acer aspire 3100 that wont play vide while it only plays sound
Mar 05, 2008 | Toshiba Style Bay DVD-RAM Drive Kit...
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Computers & Internet Logo
119 people viewed this question
Top Panasonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
