Question about APC Back-UPS ES 725 Broadband (BE725BB-TU) UPS System
650 APC UPS
Constant alarm when on battery and mains. Meanwhile the battery is tested ok.
    New Friend:
  • 37 Answers
Try to change with new battery and test. if it does't work it could be the hardware is malfuntion. but that the lastsolution to think, what are the indicator light is stated? can u descibe more detail on the ups. so i can able to asst u?
Posted on Mar 30, 2009
Apc smart 1000 ups after changing batteries all right are blinking
Is this the RT or the VT or the RM or the XL? Recheck the UPS's batteries by conducting a battery test. Press the I/Test button to initiate the battery test. If All LED are lit and the UPS emits a constant beeping then there is a internal fault.
FRONT PANEL LEDS FLASH SEQUENTIALLY: The UPS has been shut down remotely through software or an optional accessory card.
If all else fails then remove the input power. Unplug the batteries. Check the fuses in the back. If fuses are ok then push and hold the power button. This will reset the logic. Plug batteries back in, apply power and hopefully all is ok. If not then purchase another UPS the cost to repair it will be more then what it's worth
Sep 20, 2011 | APC Smart-UPS 1000VA UPS System
My apc ups cannot produce output
Open it up and check the fuse. or your UPS may have a pop out fuse that may need to be reset
Sep 13, 2011 | APC Computers & Internet
I connected 8, 100Ah battery with APC 2.2KVA inverter, now it doesnt give correct battery indication and keep producing beeping noise, whats the problem?
Continuous Beeping (theamber On Battery LED will be illuminated)
This alarm indicates that the UPS has reached aLow Battery condition and will soon shutdown. The UPS can only operate onbattery for a limited amount of time. In order to protect the unit's batteriesfrom discharging too much, the UPS will shutdown and turn off its output. Towarn you that the unit will soon shutdown, the UPS will sound this alarm 2minutes before actual shutdown. With optional Powerchute Plus software, 2minutes can be changed to 5, 7, or 10 minutes to give you more of a warning ofimpending shutdown. If you hear this tone, you should immediately gracefullyshutdown your operating system to prevent data loss or corruption.
Note:This graceful shutdown will occur automatically if Powerchute PLUS software isbeing used.
Constant, Solid Tone (the red Overload LEDwill be illuminated)
This alarm indicates that the UPS has detectedan Overload condition. If this alarm is sounded, try removing non-essentialequipment. The alarm will remain until the load is reduced. To determine ifyour UPS is capable of handling the equipment you want to protect, visit APC'sSizing Guide at www.apcc.com/sizing.
Continuous Beeps for One Minute; RepeatedEvery 5 Hours (Replace Battery LED will be illuminated)
This alarm indicates that the UPS has failed itsSelf-Test of the battery. The unit will continue to sound this alarm until theunit passes the test. Try to let the unit charge for a few hours and thenperform another Self-Test (Press and hold the on/off button until the second'chirp', then release). If it fails and the unit is still in-warranty (twoyears from date of purchase), then contact APC. If the unit fails and its outof warranty, then order a replacement battey cartridge through your reseller,distributor, or from APC's web site.
Apr 21, 2011 | APC Computers & Internet
I have a BX900R that suddenly the red light came on and the alarm sound was constant - not beeping and the unit did not supply any backup power. The most recent status on the monitor program showed about...
If the device was still under warranty, you should call APC support and ask to send it in for repairs or replacement. Just keep politely asking, and ask to talk to their superior whenever they say it isn't possible and eventually you will get an RMA ticket/number.
If the device is not under warranty, you might be able to convince APC to service the device for a fee.
Mar 02, 2011 | APC Back-UPS XS900 (BX900) UPS System
Getting alarm after genuine APC battery replacement
restart the ups by to turning off your ups and main source. and turn it on again. anybe the battery u purchase is deflected. change the new battery & test again. i suggest to replace other type of battery like neuton power, chloride powersafe as this type is much reliable and cost saving. the cost of the the problem if still occur it could the setting of the UPS that it to configue.. ask the vendor to check your ups
Mar 26, 2009 | NEC APC Smart-UPS 3000 RM 3U...
Problems
must be either low main power or cable damaged or not inserted properly
Jul 23, 2008 | APC Back UPS 650 (APWBK650MC) UPS System
Problem
need to checked by expert
Apc
1) Switch Off the UPS and unplug all Loads (like System, Monitor etc.) from UPS.
2) Switch Off the AC Power (Input Power to UPS).
3) Press the UPS Power Switch constantly unless you hear 2nd BEEP Tone. As soon as you are hearing 2nd BEEP Tone, Release the Power Switch.
4) This is COLD START of all APC UPS that will reset any internal problem.
5) If, however, the problem persists, contact APC.
Jul 23, 2008 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
APC Back-UPS ES 725 Broadband (BE725BB-TU) UPS System Logo
358 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
