Question about Fuji Cameras
Dropped camera. when switching camera off, optical zoom lens will not completely close. also camera is out of focus when taking picture.
  • 188 Answers
Lense assembly stucked. Needs repairs.
Posted on Jul 25, 2008
Picture are out of focus Is lens housing suppost
There's a slide switch on the end of the camera, near the USB socket. Make sure it's in the proper position. The flower position is for taking pictures of objects close to the camera, the mountain position is for other pictures.
Feb 09, 2011 | Vivitar ViviCam 5024 Digital Camera
Wont allow me to take pictures
The camera's firmware will need to be updated. You can sometimes get lucky enough to find a free download on the web. Others have to send in their camera's to the manufacture and they will repair it for $50
Sep 28, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Canon Eos Rebel xti won't take a picture when zoomed in
Try a different lens just to check out the lens focus sensor. or put it in manual focus.
Sep 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Pictures are extremely bright
Over exposure due to the shutter not closing over the lens. try taking video and see if that comes out ok. Another way to test the theory is to put your camera into full optical zoom and turn the flash off so as not to blind yourself and turn the camera to face you and angle the lens so that you can see into it without reflection. now take a picture and watch the shutter closely. In full optical zoom it should bring your internal lens right up to the front end of the lens so that you can see it clearly( this would depend on your camera though). Does the shutter cover the lens completely? it should do. If it doesn't then something is sticking it or obstructing it.
The video is a good indication of a faulty shutter as this does not use it so should work ok.
Only way to solve it completely is to strip it down and clean it.
Apr 04, 2009 | Cameras
Blurry pictuers
First of all, tele-multipliers or tele-converters do not have the greatest optics in the world, and are usually fine for close up images but not much else. Secondly, they do restrict the amount of light coming into the camera which could interfere with the internal metering. Third, you have additional lens surfaces to get dirty. To fix the problem, start with the easy one, and clean all lens surfaces meticulously with a soft lint free cloth. If that doesn't fix it, try shooting non-moving objects in brightly lit areas. If you are still getting blurry pictures, try using the tele-converter on a close-up image within the focal length of the lens combination. If that doesn't work, give the teleconverter to someone you don't like and go buy a good quality 50-135mm zoom lens. Vivitar, Sigma, or other similar lenses are good quality and are very reasonably priced.
Mar 02, 2009 | Digital Optics 52mm Camera/Video 2.0x...
Repair lens PDX10
It sounds like the optics in the lens are no longer calibrated. It needs to be looked at by a professional.
Oct 10, 2008 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Quality of pictures, camera does not focus
Has this has a knock or been dropped? Whether it is fixed lens or motor Zoom only such treatment would make the lens shift out of the focal plane Try technical support of the makers website. If it is failry new there may be an exchange option.
Jun 22, 2007 | Concord Camera Eye-Q 4060AF Digital Camera
Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Olympus FE-140 Digital Camera
Zoom and shutter not functioning
that is a symptom of being dropped and stuck in a mode.
it requires total dissemble of the camera to fix or replace the lens. your lucky it takes pictures at all. most cameras refuse if the lens is stuck.
Jul 28, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Cameras Logo
37 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
