Rinnai dynamo 15
Hy lost my manual can you help me by telling me what to do when the filter light is flashing. Thanks
  • 80 Answers
I DONT KNOW WICH T-STAT YOU HAVE BUT NORMALLY YOU CAN CHANG THE FILTER AND TURN YOUR BREAKER OFF THEN BACK ON AND IT WILL RESET
Posted on Jul 24, 2008
SOURCE:
How do I clean inside my rinnai convector 417?
The owner's manual at http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf on page 10 says to vacuum both filters weekly. It also warns not to wait for the filter lamp to come on since overheating may occur.
May 03, 2014 | Rinnai Water Heaters
After it has been on for a while the filter light start flashing. Tell you tell me why please. It has just been serviced.
Ben, just because the heater was recently service, doesn't mean the filter may have gotten dirty from use, since then. Or the filter was overlooked during servicing.
In either case, turn the electrical part of the heater OFF and unplug it from the wall receptacle. Remove the filter and clean it, if necessary. Reinstall the filter properly, plug the unit back in and turn the Master ON/OFF switch to ON. Start the heater and the Filter Clean Light should not glow.
Hope this helped you solve the problem.
Jul 12, 2011 | Rinnai Heating & Cooling
How do I set the timers on the Rinnai Dynamo 15 gas heater?
Carole, to assist you, I have included a link to your Owner's Manual, in case you have misplaced yours. You can download and print his manual for future reference,
http://help.weber.com/manuals/pdf_files_2011/Charcoal/Assembly%20Guides/OneTouchGold_18n22nHS_AssemblyGuide_30792_080309.pdf
Hope this helped you ... Cheers
Jul 04, 2011 | Heating & Cooling
Hi I have a Rinnai RCE-29H (gas heater) that I just got off a friend and it is working fine however the Filter light comes on from time to time. Once the light comes on it generally stays on for a while....
No, Tina there's only the one filter. However, the filter should never be removed for cleaning while the heaters electronics are ON. If you're still getting the filter light. Turn the heater Off, using the Master On/Off Switch and unplug the electrical cord from the wall outlet. Leave the heater unplugged for 15 minutes. Plug the heater back in and turn the Master ON/OFF Switch to ON, the heater electronics should turn ON and revert back to the original factory settings. After that, you can reset them to what you originally had them on.
As far as an Owners Manual is concerned, I couldn't find one in my Rinnai USA data base, that matches the one you listed. If you don't live in the U.S. that's probably the reason. However, if you can provide me with the country you live in, I may can find one for you.
Hope this helped. Please let me know. Thanks.
May 16, 2011 | Heating & Cooling
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
www.rinnai.co.nz
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
My rinnai 556fa propane heater
I had the identical trouble with my Rinnai 431F just now & read the unanswered posts.
I checked my intake & exhaust & found them connected & intact then went out to check the exterior vent assembly. The "bell" or dome was almost entirely clogged with ice.
I suspect the 60 - 76 lights flashing means insufficient combustion air.
Anyway, I took a hair dryer to it & in 10 minutes it was working as well as ever.
This won't help you October posters but if anyone else has this problem in the future I would start with the outside vent assembly. Get a good look right up inside because I would have missed this ice if I didn't get up close with a flashlight.
Here's a good source for manuals too...
http://www.houseneeds.com/products_rinnai.asp
I'm going back to bed.
M.
Oct 29, 2008 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Rinnai Energysaver 403 FT
I may not be much help here in the states but if you have the owners manual you will find a page that will tell you what the error code represents. Not knowing and unable to find the NZ error codes, most likely it represents a flame failure. You will need to remove the front cover and inspect the flame as it starts. If it starts and goes out quickly, you may have debris attached to the flame rod not allowing it to get the proper signal. Or you may have a spider web in your burner. These units are not eazy to repair and I strongly suggest you call a proffessional. Sorry.
Jun 29, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
350 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
