Question about Intel Motherboard
Home built 4 yr old pc wont boot
Ausus P4PE motherboard
pc has worked fine for 4 yrs. now it has developed a problem,,,it will not boot up,,,,and gives the voice message > cpu test failed
  • 84 Answers
You have voice message telling you CPU test failed , but does it BEEP at all ? if you have a Beep code then replace the CPU fan ( when CPU gets too hot it will either shut down or the PC will not boot up at all )
Posted on Jul 23, 2008
Displays momentarily and asks for CPU fan connection. I have changed 4 fans and still get the same error message and the display goes off.
You're sure you have the cpu fan connected to the correct socket? sounds like it's not connected, or is connected to a different socket. Does the fan turn?
Apr 22, 2015 | Computers & Internet
How can i boot or reformat using usb in motherboard p4pe-x, or can i boot from usb from that mobo instead? If so, how? I see on boot setup the removable devices, under that after i click removable...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Apr 27, 2011 | ASUS P4PE-X (90-M8LAW1-G0EAY) Motherboard
Exployer 8 download crashed my intel asus p4pe with windows xp . I cant boot up. I get the voice welcome, then when it should boot up, it clicks and starts over. Never ending loop.
I would recommend booting your pc to Safe Mode and restoring your system back to a date BEFORE the crash happened. When you power on your pc, press F10 or F8 until you hear a beep. This will bring up a command function for you to select what you would like to boot to . Choose Safe Mode.
Good Luck
C2Solutions
Feb 13, 2011 | ASUS P4PE-BP Motherboard
Hello When trying to turn on my pc I hear a mesage from the voice genie, saying that there is a problem (your CPU might have a problem, I think). I have amd sempron 2500+ socket a albatron kx18d...
Have you tried removing the Cmos Battery? if not remove it and leave it outside for few minutes (5 mins) and reinstall it (do this while the Machine is off). Boot the system again. It's also important to re-seat all the components like, front panel connectors, usb connectors, audio connectors, hard disk, cd/dvd rom, processor, Ram, fan, power connector, etc... and clean whatever you can and then reconnect or reinstall them. If there's no actual cpu failure or motherboard faulty, your problem will be fixed.
I wonder where's that Genie voice came from :-)
Good luck.
Thanks for using FixYa.
Aug 18, 2010 | Albatron K8T800 (K8X800 PRO LL)...
Motherboard and CPU Frequency
When you power up the computere press F2 or "del" or F5 key towenter in bios then load optimal defaults settings.then save then check.
If still problem arise then pull out cmos cell for 15 minutes from motherbord then it auto reset to factory defaults.
Jul 24, 2009 | ASUS P4PE-X Motherboard
L7VMM2 wont boot (no post) plz help
Sounds like the CMOS battery on the motherboard needs replacing...i would try clearing CMOS first, replace battery and test voltage at the CPU (through the BIOS) If that dosen't help you likely have faulty capacitors.
If you get it to boot, im sure drivers and BIOS will need updates if it's been stored 2 yrs.
Jun 01, 2009 | EliteGroup L7VMM2 Motherboard
Advanced BIOS setting
I would suggest using the set bios default option on the main screen. This should reset everything to factory defaults.
Be sure to exit saving settings. After that, assuming there's no hardware damage, it should start fine.
Hope this helps. Please remember to rate this information.
Thanks
May 13, 2009 | ASUS P4PE-X Motherboard
Power switch notworking ( ASUS P4PE-X Motherboard)
Please refer your motherboard manual and fix the front panel cable including power button. After this if power button is not working than swap the power button cable and reset button cable.
And then start your PC by pressing the reset button.
Else you just recheck all the cable + RAM + CPU.
Mar 09, 2009 | ASUS P4PE-X Motherboard
P4PE Motherboard system hangs on 2 memory banks
you need to check in your bios settings for the amt of physical memory setting. alsoexamin the board for defect. if all that is good then follow the following instructions
1.)Unplug computer
2.)remove memory
3.)switch jp1 to clear ( the jumpewr that clears the bios is called jp1 its located close to the battery and it has 3 pins and 1 jmper) the pin set will be on 1 and 2 , simply set it to 2 and 3)
4.) Hit the power button 5 times to clear all remains of eletricity
5.) REPLACE JUMPER TO 1 AND 2
6.) replace memory
7.) boot up system
8.) on the main boot screel it should say no bios settings enter setup
9.) enter setup and load optimal defaults
10.) save and exit
Dec 31, 2007 | ASUS P4PE-X Motherboard
Asus P4pE not booting.
The beeps you hear are probably BIOS error beep codes. Through a series of long and short beeps the BIOS communicates what type of error is occurring during the initial stages of the start up process. If you can tell me the manufacturer and model number of the board AND the sequence and length of the beeps I can point you in the direction to go.
Dec 13, 2006 | ASUS P4PE Motherboard
Intel Motherboard Logo
104 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
