Question about Philips 9P6040C 60" Rear Projection Television
Philips 9P6040C 60 in. Rear projection
My color is off-balance it went all red all but the picture was still there i messed with the color nobs on the inside of the back of the tv to get the color on the color controls in the menue dont work anymore also i looked in the lights and only the red is showing picture clear and the blue and red lights are showing really fuzzy pictures please help
  • Philips Master
  • 3,459 Answers
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site http://www.TvRepairKits.com . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Posted on Dec 20, 2008
Philips 46PFL3505D picture size to large
You can change the size through either the menu or a button on the remote usually referred to as "aspect". It should give you 2 or 3 choices for the size. Some cable or DTV boxes also have this feature and may be in conflict so try setting from both until you find the right size. Good luck.
Aug 27, 2013 | Philips 9P6040C 60" Rear Projection...
Red Projection Is distorted
Convergence is dead.U know how to solders?Must replaced 2 convergence,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 05, 2010 | Philips 60PP9202 60" Rear Projection...
Tv works good picture is good and clear sound is good but im only getting blue and red colors??? is that the board? or the green bulb?
That is what happened with are tv. My husband took the tv apart and started messing with everything and got the tv to line up better. he just turned the nobs and messed with the coloring.
Dec 09, 2009 | Hitachi 61HDX98B 61" Rear Projection...
Magnavox TV
it is very possibvle that the three lights are not positioned correctly or you may have to change the fluids behind the lights only a technician can do this
Aug 16, 2008 | Philips 9P6040C 60" Rear Projection...
9p6040 c102 philips magnavox rear projection tv
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jul 23, 2008 | Philips 9P6040C 60" Rear Projection...
I have a Phillips maganavox Projection TV I believe it is model 9P6040CI and the color is dull and I believe the red is going or gone. I've tried to tune it but will not let me
May 02, 2008 | Philips 9P6040C 60" Rear Projection...
Everything has a reddish/orange tint
i have the same problem pull off the back of the tv and mess with the color nobs it helps a little
Oct 10, 2007 | Philips 9P6040C 60" Rear Projection...
Convergence
You need to replace the convergence output IC's and possibly some resistors associated with that circuitry. The generic parts for that set if I am correct are STK392-150 and you need 2 of them.
Feb 26, 2007 | Philips 9P6040C 60" Rear Projection...
Philips 9P6040C 60" Rear Projection Television Logo
109 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
