Question about Sansui TVM1316 13" TV
Sansui SV21276 Keeps on blowing the fuse on power suply
    Brigadier General:
  • 6,966 Answers
Their would only be a limited number of components capable of blowing the fuse. They would be:
  • bridge diode;
  • filter capacitor;
  • regulator IC;
  • mains B+ capacitor; and/or
  • overvoltage protection (SCR type).
all in the power supply circuitry.
Depending on the PSU design, other load side components can and may cause the fuse to blow likewise. They may include (but not be limited to):
  • horizontal output transistor;
  • flyback transformer; and/or
  • yoke.
Repairs/diagnosis of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 23, 2008
Does the power suply have a inside fuse
yes it does but some off them can not be replaced.some off them are not like a fuse that you can just take out and replace.
mind you if its blowing a fuse its best to replace power supply.
Apr 02, 2014 | E-Machines eMachines Desktop PC
Fuse F1 is blown
You don't give any information about the make & model of the machine, but if the fuse keeps blowing, it's probably due to a short circuit somewhere in the machine. It could be as simple as a cut in part of the wiring, allowing the copper cable to touch another metal part, or it could be the compressor or pump wiring shorted out. If you don't have the experience or equipment to isolate the short, your best bet is to call a service engineer.
Nov 18, 2013 | Kitchen Appliances - Others
MY MAGNAVOX TV MODEL#30MF301B FUSE BLOWING UP AS SOON AS I PLUG IN
The power suply board has a severe short and will most likely need replacement. You can get replacement power boards fom www.tvcircuitboards.com
Feb 06, 2013 | Magnavox 32MF301B LCD TV
Power window fuse keeps blowing
If a fuse keeps on blowing there are broken wires or a short in the circut controling them.
Nov 02, 2012 | Pontiac G6 Cars & Trucks
Yamaha dsp a1000 won't power up
Your power suply is defective and needs repair.
Or the power amp is shorted will blow inside fuse power line
distribution.
May 15, 2012 | Yamaha DSP-A1000 5-Channel Amplifier
Does not heat
There is a slo-blow 20 amp fuse inside of the ac power panel. You will have to remove the front and locate the fuse inside. This fuse suplies the power to the Traveling Wave Tube that spplies the microwave energy.
Mar 08, 2011 | Whirlpool WMH1162XVS Microwave Oven
Watching the TV and heard a "pop", it went dead. Opened up the back and found a blown 4A 125V fuse. Replaced fuse and plugged in TV. Fuse blew instantly when I plugged in the TV. Sylvania...
The power suply unit may be dead......if the fuse blows instantly it means that the main input is short.
possible parts damaged :the diodes from the mains, the power tranzistor and the ic from the primary part and other components around them.
First unplug the tv, unload the mains capacitor (using a light bulb) check all the diodes from the rectifing bridge, check for any shortened semiconductors or blow resistors.
BE VERRY CAREFUL !!! THERE IS A RISK OF ELECTRIC SHOCK ,IF U DON"T KONW ANY ELECTRONICS TAKE IT TO A SPECIALIST
Feb 19, 2011 | Sylvania LC370SL8 37 in. LCD Television
Power problem fuse keep blowing
hi
short in power suply module
Oct 02, 2010 | LG 37LC2D Television
I have a 1998 caddilac deville no air will blow out at all what may the problem be?
check all your fuses first. if they are all good replace the blower motor resistor. this controls alll the speeds for the blower motor and also suplies the power to it
Mar 05, 2010 | 1998 Cadillac DeVille
Fuse keeps blowing
Have him check power suply link, from fuse to wall plug, theres a short some where between the plug and the fuse.
Jan 13, 2008 | Kenmore 19001
Sansui TVM1316 13" TV Logo
145 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
