Question about Ricoh Aficio 2035 Copier
Error s c541 - Ricoh Aficio 2035 Copier
    Sniper:
  • 59 Answers
ERROR CODE C541
PROBLEM: Fusing thermistor open
the fusing temperature detected by the thermistor is below 7 celsius for 35 seconds.
POSSIBLE CASSES: The center thermistor non-contact or abnormal position
The thermistor open (you can check with Multi meter)
The thermistor connector defective
The thermistor damaged or warped
the fusing temperature -15% less than the standard input voltage
SOLUTION: you check very carefully if the thermistor is out of order then replace the thermistor with the same one and if you check heater unit and there parts lamp thermistor are ok then reset the heater code
press all clear (yellow key)
press (1) and (0) and (7) from key pad
press and hold 5 second clear stop key (red key)
enter service mode
then power OFF and then ON if the heater section is ok then machine get ready
Posted on Feb 10, 2011
SOURCE:
My konica minolta c541 printer is show error code 4501
mam, Open close front door. to reset. if code comes back your Print head is bad. The print head houses the LASER for each drum. ITS ONE UNIT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 13, 2017 | Konica Minolta Office Equipment & Supplies
RCA L46WD22 picture flickers like watching through a fan
Replace C540,C541,C542,C543 1000uf 35V and C544 680uf 35V in power supply
Feb 11, 2011 | RCA L46WD22 Television
Dont play,the tray dont work
Please check the mechanism on its motor and gears for malfunction. Please get it repaired or replaced if defective.
Feb 06, 2011 | NAD C541 CD Player
NAD C541 tray does not open.
if i'm right it will have the sony mechanism so if you take the lid off and unscrew the 2 screws, 1 at either end of the cd clamp and remove it, you should see part of a large cog just under the front of the cd tray, try turn this clockwise and the tray should open.
once open, you should be able to see a small plastic cover, loosen this slightly and replace the belt as this is prone to slipping on this mechanism stopping the cd tray from opening and also clamping the disc properly when closed.
hope this helps?
Mar 11, 2010 | NAD C541 CD Player
SONY WEGA, KV36FS70
replace r533 and c541.you need a qualified tv technician to solve this problem
Nov 16, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Ricoh 1075 with code C541 will not clear ,thermistors have been replaced
you need to enter SP mode then turn the machine off and back on and it should clear the error as long as the parts have been replaced for new parts!
hope this works!
Oct 21, 2008 | Ricoh Office Equipment & Supplies
NAD C541 CD Player
I wouldnt buy another one from NAD.
I've worked on their stuff cant say anything nice, Sorry.
Aug 25, 2008 | NAD C541 CD Player
Dvd player
It is only a CD player, Will not play DVD's
Jan 01, 2008 | NAD C541 CD Player
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
Won´t read any Disc
I have the same problem since the early beginning after purchase. I'm very upset with NAD for the zero-value technical service in Italy. After 2 months they gave me back my C541 with new defects (the tray now doesn't work properly). They have tried - they said - different optics without fixing the problem. Does anybody know if a compatible optic / tray exists?
Thank you
Marcello
mcl.vlb@tiscali.it
Ricoh Aficio 2035 Copier Logo
352 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
