Distorted graphics Last year I purchased a 7600 gt agp nvdia graphics card. My mother board only has support for agp 4x and the card is agp 8x. I was told that should not be a problem is it? Anyway there are certain games that the graphics gets distorted. thanks Aaron
    Problem Solver:
  • 16 Answers
The 7600 gt can work on an agp 4x motherboard only in a 4x bus speed, if your just using the cd driver that comes with the video card try updating it by downloading the latest driver in www.nvidia.com, first uninstall the driver then restart the computer then install the latest driver you downloaded
Posted on Jul 23, 2008
Will a NVIDIA GeForce FX 5500 video card work on a P4B533-E motherboard?
HI Lau_kua08,
First off, your motherboard is a AGP 4x slot, and the Card is a AGP 8X card. However, NVIDIA based graphic cards which support AGP 8x mode (Accelerated Graphics Port) follow the AGP 3.0 specification. The AGP 3.0 specification retains backwards compatibility with older AGP 4x technology. All NVIDIA Geforce and Quadro GPU's which support AGP 8x mode are downwards compatible with AGP 4x motherboards. When a graphics card which operates at AGP 8x mode is installed on a motherboard which only supports up to AGP 4x mode, the card will automatically switch to AGP 4x operation.
So, yes it will work.
Good Luck,
Mark
Oct 27, 2009 | ASUS P4B533 Motherboard
For adding an additional graphics card
Your board only supports AGP 4x graphic cards. You should be able to use any AGP 4x card or even some AGP 8x cards. Some of the 8x cards are backwards compatible but will run at the slower 4x speed. You can try places like TigerDirect.com or Newegg.com to see what they have available. Hope this helps & please remember to rate my answer. Thanks.
Jan 24, 2009 | Computers & Internet
Looking to upgrade video. is there a limit to uprade old mboard
Only cards that work with this board are AGP 4x graphics cards or possiblly AGP 8x cards that are backwards compatible. If you buy an 8x card do your research to make sure it's backwards compatible before purchase. Newer graphics cards are pci-express x16 or pci-e 2. These will not work with your board. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Matsonic MS9327E (MS9327E+(USB))...
Bad graphic
Your motherboard only supports AGP. You can use any AGP graphics card that supports up to 4X AGP. nVidia and ATI make great cards as well as other manufacturers that mak boards using nVidia and ATI chipsets. I would recomend a card with at least 512MB of memory onboard. I hope this helps.
Lou
Sep 04, 2008 | VIA ASRock K7VM3 Socket A/...
I could have swore I purchased an apg 4x video card, that's what my V2 premier,( L4S5MG3 mother board)requires.The nivdia Gforce6200 is 8x/4x will this work? Don't want to open, till sure.
8x and 4x means that the video card is an AGP ( not apg) typo i guess.
If it was PCI or PCI Express, it would say so on the box. Look at *********** board, the video card slot will usually have AGP prined next to it. Also, your old video card may have a sticker on it that says its a BLAH BLAH card with SUCH AND SUCH Megabytes of ram and thats its a AGP or PCI, PCI EXPRESS.
Once you know for sure that the card will work, open her up, install and enjoy.
Jun 12, 2008 | Computers & Internet
Intel P$ 1.8 mhz on a D845HV/D845WN board
Before removing your current card swap video outputs on the PC. If currently connected to the VGA output switch to the HDMI connector AT the video card. Use the HDMI to VGA adapter that came with the video card. Check & see if the display loads Pc starts. Taking the information directly from your motherboard manual pg. 25, your AGP video can only run at, AGP supporting 1.5 V 4X AGP cards. The 9600pro runs at 8x & it is not backwards compatible. (able to run at either 8x or 4x). You could run the Sappire ATI Radeon 256MB 9550 DDR AGP 4x/8x 1.5volt card.
Here is one site: http://www.colordrives.com/sapphire-ati-radeon-9550-256mb-ddr-agp-4x-8x-video-card---retail-box.html
When you do get the video card be sure to set your bios AGP to the correct size as listed in your manual pg. 109 subsection 4.4.7
I hope this helped.
Feb 20, 2008 | Intel Motherboard
Agp 8x vs agp 4x
the 4x card WILL work in an 8x slot but it will only run at 4x speed because of the card limitation. also, the 8x card WILL work in a 4x slot but it will only run at 4x speed because of the slot limitation. i've done it. peace
Nov 05, 2007 | Palit Microsystems GeForce FX5500, (256...
Installing GeForce 5200 on Dell Dimension 2400
I suggest that better check that graphic card in another machine and make sure it is working.
Also find out the data transfer speed of your mother board through the AGP slot is compatible with your graphic card. (e.g. 4X, 8X, etc.)
If you are sure that your system really has an 8X AGP port (A choclate colored slot) then you could deffinitely install the card and work with it.
With the information I received the Dell Dimension 2400 deos not features an AGP 8X port, in that case it is not possible to install the card.
Then you should buy a new motherboard with AGP 8X Port to be able to install the Ge force FX 5200.
Nov 03, 2007 | PNY Verto GeForce FX 5200, (256 MB) PCI...
Compaq s4020WM AGP Questions
I don't think there's a 8x AGP card made that would not work at 4x, and any 4x capable AGP slot should handle an 8x card. AGP 1.0 (x2) signals at 3.3V AGP 2.0 (x4) signals at 1.5V AGP 3.0 (x8) signals at 0.8V
Apr 05, 2007 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
