Question about Durabrand DWT2405 24" TV
Picture Tube We have an issue with our picture it is 1/4 the size it should be and there is a 3 inch gap between the picture and the frame and it is only 2 years old.
Hi. Thanks for writing this posting. Saturday, my 19" Durabrand tv literally stopped working. Before it shut down, I had a partial screen and when I turned the tv off (hoping that the problem would somehow rectify itself), it wouldn't turn back on. I had it for only *four* months. Comcast gave me an 800 number but it rang to a fax signal. When I saw the posting here, I clicked on the Lenoxx site and called their 800 number which did not even ring. I called information and received a number, 877-874-8394 for Lenoxx Manufacturing but the person who answered said that they are Plaza Wire Design with Lenoxx being one division - but they manufacture towel racks. Ugh!
Unfortunately, this all happened one month after the 90 day return policy at Walmart *and* they don't even carry the product anymore. (I don't know whether it is because of defects or turning over to LCD.) One year prior to this, I purchased a cd/radio which also stopped working (the cd player). Luckily, it *was* within the 90 days of purchase and I returned it. They stopped selling that product as well.
What recourse do people in our situation have?
Posted on Aug 04, 2008
What things should i consider when buying a digital picture frame?
1. resolution of 640 by 480 or higher
2. screen size and aspect ratio that you like
3. features: video playing? accelerometer
? pictures from internet? facebook pictures?
4. novice or sophisticated user? simpler or fancy web features?
good luck.
Feb 11, 2013 | Photography
You are framing a rectangular print that is 10 inches wide and 34 inches long. this wall space has an area of 640 square inches. what is the width of the frame so that the framed print fits perfectly in...
If we assume the width of the frame is X. Then the one dimension of the framed picture will be 2X + 20 and the other dimension of the picture will be 2X + 34. We know the total area of the framed picture should be 640 in^2. Therefore:
(2X + 10) * (2X + 34) = 640
If you multiply this out you get:
4X^2 + 88X + 340 = 640
Subtract 640 from both sides:
4X^2 + 88X - 300 = 0
Divide both sides by 4:
X^2 + 22X - 75 = 0
Use the quadratic equation to solve for X, with A=1, B=22, C=75
X = [-22 +/- sqr(22^2-4*(-75)] /2
This reduces to:
(-22 +/- 48) / 2
The negative solution doesn't make sense in this case. Therefore: X = (-22 + 28) /2 = 6/3 = 3
Therefore the width of the frame should be 3 inches.
Feb 16, 2011 | SoftMath Algebrator - Algebra Homework...
Only stores about 200 pictures on it.How do I get more pictures on?
Make the Pictures smaller in size, lessen the colour depth, save as JPG, use a lower resolution image.
Feb 04, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Images scan set at 300 dpi, end up 72 dpi
It depends on the physical size of the images. Size and resolution are related to each other. Let me explain:
You have an original, say, 2 inches by 2 inches.
You scan it with resolution of 300dpi (dots per inch).
You will get a file that's 600 by 600 pixels, right?
Then you look at it on screen, which has a resolution of 72dpi - if it's displayed without magnification, what size the picture will be? 600 divided by 72 = 8 and 1/3 of an inch, so on screen it will be 8 1/3 by 8 1/3 inches.
So, there's no such thing as a picture file's "real" resolution - we can talk about a resolution at a given size, because it's the horizontal and vertical size in pixels what's "real".
Therefore you have to ask what size the scanned picture is, and then look at the file you receive; in it's properties you will find it's number of pixels horizontally and vertically, and from that you can easily calculate (dividing the height in pixels by the height in inches) the actual resolution the file has been scanned at.
Then you'll know for sure if need to complain to the friend ot not :)
Nov 13, 2009 | Epson Stylus CX4700 All-In-One InkJet...
Screen has borders when watching tv
This is common issue of the channels that use 4:3 format while TV is designed for 16:9. To get it disappear, you just go to picture option, choose WIDE FIT, this fuction will widen the picture to whole screen. Of course, you have to accept the picture is blur a bit.
Aug 14, 2009 | Samsung LN32B360 32 in. LCD HDTV
I have a Brookstone digital picture frame that refuses to complete the boot cycle. It appears to get about 3/4 of the way through before locking up with the status bar and the big Brookstoneon in white on...
cheap **** - Really Brookstone? No reset? No way to format? Crappy warranty? Poor workmanship? No software that resizes your images so they won't crash your picture frame? screw you guys, I'm never shopping here again
Jul 14, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Wide black area top of the screen.
More than likely it's not the crt. If the picture has "foldover" at the top of where the picture is currently, then more than likely there are bad caps. in the vertical scan circuit. If not, the vertical sizing probably just needs to be adjusted. You will have to get in to the service menu to do that.
May 26, 2008 | Philips Magnavox 27MT5405 TV
Toshiba 35 inch picture tube problem
HELOO THE SET IS HAVINGA VERTICAL FAILURE ,REPLACE THE CONDENSERS AND ANY BURN PARST IN VERTICAL SECTION.AND AT LAST REPLACE VERTICAL IC IT WILL BE OKKK.
May 21, 2008 | Televison & Video
Standard CRT Toshiba TV - 4inch tall picture in middle of screen...
Not familiar with your actual model.
But a comon problem with older Tosh sets is the 2.2uf electrolytic caps from memory they are usually red there is 1 next to frame Ic & the second is near Psu.
Allso check frame o/p IC for dry solder joints this is easy to test for.
Tap the tv while it is on if the the frame suddenly pop to full size picture you know its dry joints so resolder frame IC.
http://dysonmanuals.inc.io/
Oct 13, 2007 | Televison & Video
Picture tube doesn't seem to stay in place (standard tv)
A very good chance this tv was dropped or bumped. Sounds like the internal plastic frame is broken and will not support the picture tube. Find someone with tv experience to fix this. I would suggest they use a putty found at an auto parts store. To glue the tube and the frame together. This putty is in a plastic tube. You tear off a piece and fold it several times to activate. It will surely do the job.
May 30, 2007 | Durabrand DWT2405 24" TV
Durabrand DWT2405 24" TV Logo
63 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
