KONICA MINOLTA C450 VXL Printer - When stapling multiple copies it staples all the copies together rather than each one separately as required. I use vista operating system.
  • Anonymous Jan 07, 2009
    Even if you specify "collate," when you tell it more than one copy it puts one staple in the whole stack of copies.
  • Anonymous Apr 20, 2009
    Same problem only on a minolta C253. I think it has to do with the FS-519 feaure.
There is an issue with the Konica Print Driver and the MS Print Driver. If Collate is turned on in both the drivers, you will get this problem.
The solution is to turn off Collate on one of the Drivers. Usually you will have an initial Print Dialog window that pops up when you can select your printer, how many copies and if to collate or not. De-select Collate. Then you should also see Preferences Tab. If you select that tab, select Collate and Staple, your print jobs should now Collate and Staple correctly.
Posted on Dec 08, 2009
Konica monolta c650 wont fold
Saddel stich (Church program and staples in the middle)? or corner? Or booklet with two staple on the on left hand side? Saddel stick requires paper in landscape.. Check the staple cartridge. ensure both cartridge are securely installed.
Aug 29, 2014 | Konica Minolta bizhub Office Equipment &...
Why do multiple copies sometimes staple together as one set instead of multiple sets?
I don't know how/why, but if you set the Print settings (main print screen) to non-collate and the Printer Properties (clicking in to get to the staple option) to collate, it works correctly, stapling each set individually.
Oct 28, 2010 | Konica Minolta bizhub C450P Laser Printer
Biz c 650 photocopier does not sort and staples all the sets together when print frm pc
When printing multiple stapled sets from Microsoft® Word all the sets are stapled together.
Solution:
CAUSE: The Collate option in the Microsoft® Word dialog box is selected.
SOLUTION: When printing and stapling multiple sets, the Collate option in the Microsoft® Word dialog box must be deselected. Please
Feb 23, 2010 | Konica Minolta Office Equipment & Supplies
I am trying to print a booklet with eight pages front and back from publisher 2007 on a Konica Minolta Bizhub C550 and when I print one copy it folds and staples fine. When I print two or more copies the...
first change driver, second print to hdd in printer, and then call this job from hdd and change copy amount. if this is not helping, then maybe the firmware is faulty, fw update is good idea
Oct 15, 2009 | Konica Minolta bizhub C250 All-In-One...
Folding and Stapling a Booklet on Bizhub C250
1)The print driver has two collate buttons and you only need to uncheck the first one (which is the windows driver not the Konica Driver) or
2) Install a new driver
Oct 02, 2009 | Konica Minolta bizhub C250 All-In-One...
After replacing black toner cartridge printer displays Drum Low
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
May 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Can't fold and staple multiple booklets
when you click on file then print in the window that pops up look at the lower right corner and you will see a box that says collate uncheck that box and it will staple correctly
Mar 05, 2009 | Konica Minolta Office Equipment & Supplies
Biz pro 920 staples multiple booklets together.
Not sure on an Apple set-up but with windows if the the collate box is checked on the first page of the print properties window it will staple all sets together as one. I'm sure it is a similar setting on a Mac.
Jan 31, 2009 | Konica Minolta DiALTA Di200 Copier
WHERE ARE THE STAPLES?
If you have the User Guide - you can find the diagram on page 11-50
Slide the finisher away from the machine and it's under the duplex unit in the finisher.
Dec 04, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
1,862 people viewed this question
jasbo
jasbo
