Question about Toshiba Satellite Pro 4600 Notebook
Satellite Pro P30 beep codes
My laptop on startup has the following beep code, 3 beeps 3 beeps 1 beep and shuts off
Doug
    President:
  • 2,692 Answers
I have a quanta 3082 MB in a HP Pavilion zd8230us laptop when I startup it beeps constantly got any ideas? anyone
The beeps with have a pattern to them. Listen closely when you first turn the laptop on and listen for the pattern. It might be something like 1-3-2 (1 beep, wait, 3 beeps in a row, wait, 2 beeps) It will repeat for listen for a bit to make sure you have the correct pattern. Once you have that pattern got to the HP webpage, in the support section, in the search type in "beep code errors". It will give you a list of beep patterns and tell you what the problem is. It could be the RAM, it could be another problem with the motherboard; those codes are what you need to have first.
Dec 24, 2014 | HP Computers & Internet
3 beeps on startup
Below are IBM BIOS Beep codes that can occur. However, because of the wide variety of models shipping with this BIOS, the beep codes may vary. Beep Code Description Document No Beeps No Power, Loose Card, or Short. CH000312 1 Short Beep Normal POST, computer is ok. No problem 2 Short Beep POST error, review screen for error code. See screen Continuous Beep No Power, Loose Card, or Short. CH000607 Repeating Short Beep No Power, Loose Card, or Short. CH000607 One Long and one Short Beep Motherboard issue. CH000607 One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. CH000607 One Long and Three Short Beeps. Video (EGA) Display Circuitry. CH000607 Three Long Beeps Keyboard / Keyboard card error. CH000304 One Beep, Blank or Incorrect Display Video Display Circuitry. CH000607
Mar 26, 2013 | IBM ThinkPad Computers & Internet
Dell beep code meanings
If an error occurs during startup that cannot be reported on the monitor, your computer may emit a beep code that identifies the problem. The beep code is a pattern of sounds: for example, one beep, followed by a second beep, and then a burst of three beeps (code 1-1-3) means that the computer was unable to read the data in NVRAM.
YOu can find complete table on Dell support site.
Most of such errors can be fixed with a system utility software RegInOut
Dec 14, 2011 | Dell Computers & Internet
Toshiba Satellite P300 makes loud beeps (alarm) at startup and could not move files on the desktop
If your experiencing beeps. Heres what you must do.
  • Count the number of beeps
  • Beware if its long or short beeps.
  • Also take note if its a continous beep
Now after knowing this things. Go to this site. BIOS BEEPS
Now on that page you will see all the bios beep codes. Remember what you did before going to this site.?Take a look for that beep code and at the description of it. you will see what device or what problem you are facing right now.
Good luck, Hope i help. Please give me feedback regarding my solution.
Jul 05, 2011 | Toshiba Satellite Pro P300 Notebook
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
Error Code: Faulty Component:
1 short beep None (Normal Boot)
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Toshiba x205 Sli1 suddenly died. Got 3 beeps.
3 beeps usually means that either the chipset or the processor is dead. Nothing you can do, take it to a repair shop.
Nov 06, 2009 | Toshiba Satellite X205-SLI1 Notebook
Will not boot
You can find an error code key but if all you want is the hard drive, why not follow these take apart directions.
It looks like it's a normal process: one screw on the bottom and then pulling the drive tray out. If you find that this isn't the case, you might have to take it apart to remove the hard drive. Drop another note here if that doesn't work.
I think the error code you are getting is a memory code. I'm supposing that you haven't tried replacing the memory because you would have mentioned that to save us the hassle of eliminating options you've already tried. I'd try reseating the memory first and then, if that doesn't work, try cleaning the memory chip connections with a pencil eraser to remove oxidization and dirt. Then, if that doesn't work, borrow, steal or beg a matching piece of memory. Sometimes satellites have one piece that you can access under the memory door (on the bottom of the machine) and another piece under the keyboard, so you'll have to look into that.
good lucks.
Jan 17, 2009 | Toshiba Satellite M35X-S161 Notebook
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
Beeps
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
Toshiba Satellite Beep Codes
memory - try different memory chip or new chip - it worked
Nov 28, 2007 | Lands Phones
Toshiba Satellite Pro 4600 Notebook Logo
851 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
