Question about Microsoft Windows 2000 Professional for PC
Slow booting & low performance
Win2k desktop takes almost 10 minutes to start up and the performance is also very slow plz tell me some solution on it
  • 81 Answers
When you start to shut down Windows XP, it has to quit, or "kill," any live
applications or processes that are currently running. So close all applications first.
However, some applications and processes are always running in the background.
You can reduce the amount of time that Windows XP waits for those applications and
processes to close before Windows XP kills them.
1. Open registry editor
2. Navigate to HKEY_USERS\.DEFAULT\Control Panel\Desktop. Set the
WaitToKillAppTimeout and set the value to 1000. Select the HungAppTimeout
\newline value and set it to 1000 as well.
3. Navigate to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control.
Select the WaitToKillServiceTimeout value and set it to 10000.
4. Close the Registry Editor.
Memory Tweak
1. Start Registry Editor (Regedit.exe) and locate the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SessionManager\
MemoryManagement\PrefetchParameters
2.On the EnablePrefetcher value, change the setting from 3 to 5 (decimal).
3. Close the registry editor and restart your computer    Apart from this delete temp,%temp%,prefetch and increase virtual memory.
Posted on Jan 19, 2009
  • 22 Answers
YOU MAY NEED TO UPGRADE YOUR MEMORY BUT 2000 PRO CAN RUN ON VERY SMALL AMOUNTS OF RAM.I THINK THAT YOU MAY HAVE A HARDWARE PROBLEM POSSIBLY A DISK OR MAYBE EVEN A BAD STICK OF RAM INSTALLED.COULD ALSO BE AN VIRUS OR INFECTION OF SOME SORTS.10 MINUTES IS AN ETERNITY FOR 2000 TO BOOT UP.IT SHOULD ONLY TAKE AT THE MAX A COUPLE OF MINUTES OR LESS.IF YOU HAVE THE INSTALL DISK,I SUGGEST RE-INSTALLING 2000 AGAIN AND SEE IF THAT SOLVES THE PROBLEM.YOU MAY HAVE CRITICAL FILES MISSING OR CORRUPTED THAT ARE CRIPPLING THE BOOT PROCESS OF WINDOWS 2000 AT START-UP.
Posted on Aug 17, 2008
  • 51 Answers
It may be a disk related problem.Repartition may be useful on your hard drive.
Regards
ucp_pru
Posted on Jul 23, 2008
Slow Windows Launch
Many causes for slow boot up or response is from malware and viruii.
Download and install Malwarebytes (Free version) from: http://www.malwarebytes.org/ You can allow the free 30 day Pro mode if you like (this program is ~$20 for a lifetime license and is highly recommended!).
Let it update the malware database. Then select "Quick Scan" and let it run. Depending on size of your HD, it may take up to 10 or more minutes to complete. You should delete everything it finds - except for cookies (if you want) and anything you recognize as "safe".
Check your antivirus software. Is it running? Is it up to date? If not, start it & update as needed. Have it perform a memory scan / quick scan / etc. and delete its findings too.
Reboot. If still slow, you might want to do a Safe Boot or boot from a Start Up disk and re-run those tests - possible selecting FULL scans instead.
Apr 06, 2014 | Computers & Internet
Very slow boot on 660 inspiron
The first thing you can try is to start up your dos shell, Inside the dos shell type chkdsk /f this will run a check on your registry etc and will fix any issues that it may have, Please note that it will get so far and tell you that it could not perform an action as windows is currently being used do you wish to run this check the next time windows start, Tell it yes by typing y press enter and restart it will perform it's checks and if it finds any problems it will fix them and generate a report at the end to tell you what it fixed. If this does not work, Try updating your BIOS from the Dell website this can be found under the driver and support section you can download it or do it on line ( Best Off Downloading as it will restart your system into a setup type screen and you will loose your internet connection. If after all this and it is still very slow at startup contact Dell support for further technical assistance. I hope this helps.
Sep 04, 2012 | Dell Computers & Internet
When i turn on my lenovo 5000 y500 laptop very slow booting takes place
There are so many reasons can cause a Lenovo computer running slow at boot up, it is hard to identify just what might be dragging down your Lenovo's performance, let alone implement the necessary technical adjustments to fix it.
So if you want to address the issues more easily, I'll recommend you try a Lenovo speed up software, available here: http://www.speeduplenovo.com/
Over 10+ small utilities packed into one to help detect & fix all slowdowns in 1 click.
Aug 04, 2012 | E-Machines eMachines Refurbished EMA...
My W3410 eMachine desktop won't Boot at all!!!!!!
Sounds like a harddisk failure unfortunately. You might want to boot your original OS disc and perform a repair (non-destructive), this may either confirm an HD crash or fix the problem.
Jul 03, 2009 | E-Machines W3410 PC Desktop
SYSTEM IS SLOW
Try running a disc cleanup and then defrag. They should be located in your control panel under the maintenance & performance tab. Doing this regularily will help keep your system running smooth. Hope this helps.
Apr 19, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
A an Emachine T1090 with 128mb of RAM. System takes forever (10 minutes) to boot up. Once up and running it performs much better. Are there any known cures? Would adding RAM help?
Adding RAM would definitely help. What operating system are you running? You could run msconfig and try starting with a diagnostic startup. If the computer loads much more quickly, you could remove some of your startup items. Ask someone before removing anything though!
Jan 24, 2009 | E-Machines T1090 PC Desktop
Computer is very slow to boot up
try and delete files you do not need. and clean up your c and d drive on your computer and defragment the files. that should help. or it may be a virus
Dec 13, 2008 | Computers & Internet
Lenovo booting problem
so u;re saying that the BIOS tests are taking 10 minutes ?! Usually that happenes when the computer shutes down brutally (after power surges, by removing the battery ... by forced shut down). Try doing a BIOS update, and also set it so it will skip some tests or not to do through testing ....
Aug 08, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Start up and shut down
Extremely slow operation can be the sign of many issues. The first of them is the hard drive failing. (I suspect this as the most likely reason.) You should be able to run hard drive diagnostics from the F12 menu. If they fail, replace the HDD.
If the diags pass, then next thing I would look at is free space available. At a minimum, you should have 10% OF THE HARD DRIVE free for Windows to cache data. Dropping below 5% usually effect dramatic slow downs and below 2% can prevent internet access too.
Other possiblities include Virus/Spyware infection
Jul 29, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Monitor or Desktop itself problem?
that status line was designed together with your OS, it seems that your PC was getting slow in boot..
A number of factors, having little to do with the age or capabilities or your system, can create excruciating system slowness. They include the following:
Operating System
File System (how you've organized files on your PC)
Applications
Hardware
The Windows OS (operating system) is notoriously inefficient, which can affect performance. The file system also impacts Windows and hardware performance. How you work with applications can improve system speed, as can some basic hardware updates.
Jun 18, 2008 | Computers & Internet
Microsoft Windows 2000 Professional for PC Logo
85 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
