Question about RCA F27650 27" TV
Horizontally Outstretched So my RCA F27650 27" TV thinks it's a wide screen. It annoys me very much, because when playing the Playstation 2 on it everytime, it's frustrating to know what I'm doing and where I'm going. I've gotten as far as into it's Service Mode and was very disappointed to see that it did not have any adjustments on how to shrink it. I've corrected all of it's Vertical problems, but it just seems that there is absolutely no way to adjust the Horizontal view. I'd be sad to throw it away because of this one problem. I've picked it up from a yard sale, for free, and the sellers told me that it was just fine until somehow it went like this. The original remote to the TV is long-lost, the manual too, it was just the TV itself. I hope there is someway to correct this, there must be a way. Is there something I'm missing? I cannot afford a repairman to come over and fix it, I'd just like to gather more information and get this fixed myself.
    Genius:
  • 1,139 Answers
Hello Toasty07,
This problem is called blooming it is caused by poor high voltage regulation. To fix this problem I would suggest that you take the TV to a TV repair shop because the section requiring the work contains very dangerous voltages and a great shock hazard exists. Just tell the TV repair person that you believe the Tv has a HV regulation problem and to concentrate on the HV section of the TV.
Thank you,
Shuttle83
Posted on Oct 06, 2008
I am having issues with my RCA Scenium D52W135D (playstation 3 connection). Recently, I have been having a very specific problem with this combo. I have it connected using HDMI to a Pioneer receiver...
Had the same problem. With mine the other day you probably moved your Playstation 3 too another tv and set your 1080i,720,480 to high deaf on settings in Playstation. You have to change them back to automatic that TV says HDTV but it only plays Playstation 3 on 480 checked in settings of Playstation. Played mine for 4 years on that TV moved and got a 3d wifi then dad got him one And was going to trash that RCA but I told him I would take it for now too keep from buying another TV at this time got it in my new home wouldn't play video but it. would sound tried different cables but still now change. But remembered i changed all of my settings over when I got 3D TV. Playstation 3 hadn't been on know other TV. Since I owned it but that RCA now won't work then came to me last night and playing it on both TVs but you have to change the settings on it before moving it or you cant see the screen to fix it do that guarantee it will fix it. Like you said everything else works PS 1,PS 2,DVD, cable,but PS 3 won't its the settings in theme,and audio.
Nov 10, 2012 | RCA D52W135D 52 in. TV/DVD Combo
I don't think i have the right remote for tv and I want to play playstation but can not get the tv off of tv or cabletv setting. need to get it to video setting. how do i do that?
Hi, Unplug the TV for 30 minutes and then try again. Go to menu settings and select video 1 or 2 but make sure you have it connected to V 1 or V2. If your play station has HDMI cable connection use that. If not use RCA jacks on the back of your TV and PS. Good luck.
Aug 04, 2011 | Televison & Video
TV made a buzzing noise then turned off. Now power light flashes
You have a very Technical problem with this TV. you may have 2 big problems, ballast and dmd. but it could be something else. If you decide to repair it, honestly you will spend more than 300dlls on it, if you like to, go to fixyourdlp.com
Sep 03, 2009 | Samsung Televison & Video
Dvd's aren't fitting my screen, the sides and top/bottom is being cut of. I've tried the display menu, zoom, and making it widescreen, and it doesn't work.
Are you playing wide-screen movies on a 4x3=1.33:1 (standard=SD) TV? DVD output by default is SD. Even 16x9=1.78:1 (HD) movies with have top and bottom bars. Many "wide-screen" DVDs are squeezed horizontally so that you have to stretch them. Many theatrical releases are up to 2.7:1 or so. Side bars indicate you have the DVD output set for 4x3 and your TV is HD-like. There are usually controls for the screen format on HD TVs--no controls on SD TV. Hey, early movies were 1:1--take them side bars. More on aspect ratio (AR) in Wiki, I bet. With letterbox of SD you can get "pillar box" with black on all 4 side. Get a better source and/or choose a different AR. -Ken
Jul 15, 2009 | Pioneer DV-400V DVD Player
Color lines.
Readjust screen control drives on screen and focus control R/G/B.
Feb 11, 2009 | Mitsubishi Televison & Video
Went Wide Screen - how do I get it back to normal?
All TV stations in the US are going digital in the next 11 months, and the format most have adopted is exactly what you describe...accordianman
Feb 27, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
How do I set the DVD picture to Full Screen as opposed to Wide Screen?
That is the way the DVD makers intended it to be. The TV cannot be adjusted to change that if it is a widescreen or "letterbox" movie.
Dec 12, 2007 | RCA TruFlat 27F520T 27" TV
RCA 52" projection Model no. D52W19 produced 9/04
make sure you do not have the automatic screen mode set to wide screen on tv menu .Also if you have cable box set to wide mode only then the tv will only display wide mode.
Dec 05, 2007 | RCA P52937 52" Rear Projection Television
Trying to get ps2 to play on new tv..
USE a VCR between the PS2 and the Sylvania TV.  Hook the PS2 A/V cable RCA connectors( Red, Yellow, White) to one of the the Video input RCA connectors( Yellow, Red, White) on the VCR. Hook the VCR Cable output to your Sylvania Cable input. Set the Sylvania Tv to channel 3 or 4.  Set the VCR channel to Line 1 or Line 2.  This should work. I hope it helps you.
Oct 12, 2007 | Sony PlayStation 2 (PS2) Console
Open Questions:
Letterboxing: The top and bottom of the screen are cut off I originally obtained this TV from my Bro who passed away from cancer at age 31 a few years ago & I was never able to find out what he did with the manual. However, I was able to find a manual online but after viewing it, I still wasn't able to find the info. that I am trying to obtain for the correct settings to get rid of these black margins at the top & bottom of the screen. I am trying to find out what video output format is supported by this TV model, as far as the resolution and output format, specifically for a Cisco or AKA Scientific Atlanta 500GB HD-DVR through Cox cable? My available settings with Cox cable & the DVR I have( Cisco or Scientific Atlanta 500GB model)are the following-Resolution:480i, with output format of either:Zoom 16:9 Pic or Letterbox 16:9 Resolution:480p standard, with output format of either:Zoom 16:9 Pic. or Letterbox 16:9 Resolution:480wide, with either output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic Resolution:720p wide, with output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic and finally, resolution:1080i wide with output format of:Stretch 4.3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic? Everything worked fine with the screen size when I had a 160GB Motorola HD-DVR with Cox under the video output settings of:resolution:480i and video output of:Zoom 16:9 Pic until, I grew tired of constantly running out of space & had them switch me to a 500GB HD-DVR. They were supposed to install another Motorola HD-DVR but just with 500GB version but when the Cox maintenance employee showed up to swap them out and install the 500GD HD-DVR, he only had a Cisco/Scientific Atlanta 500GB available on his truck, which is I guess what they use for the Contour service but he attached a filter to the back of the coxial cable to make it a regular HD-DVR without Contour(even though they tried charging me extra for contour for 3 months before I finally got that straightened out since the maintenance workers & billing dept. are often not on the same page as I found out at Cox. I have tried calling Cox for support & they say that I need to find out & know my TV's video output settings. I explained to them that it worked perfectly fine just weeks ago with 480i resolution and output format of Zoom 16.9 Pic before they switched to the Cisco/Scientific Atlanta HD-DVR from the Motorola DVR and that I didn't have the manual and I stated why and they basically said, too bad, figure it out yourself. Can someone please help me out? I have the TV set up for the correct zip code, cable box-Yes, the cable box output channel-video 1/Aux (since that is what the TV manual I read online said to use if you are using the 3-color coded cables instead of the coxial cables to plug in from the TV to the HD-DVR) & I have the Cable box remote control code set to code 008 (Scientific Atlanta) that I verified to be correct by checking it through the TV's automated code search. The serial # for the TV is:C306B2084 and the Chassis # is:ATC113BB1 and its the 27" RCA Entertainment Series Guide Plus Gold Gemstar that is X-Box ready. Thanks so much, Todd
Feb 26, 2017 | RCA F27650 27" TV
RCA F27650 27" TV Logo
154 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
