Question about Dishwashers
Dishlex DX302SB Dishwasher water not heating, have changed the heating element without any success.
  • mongambrell Aug 09, 2008
    My Dishlex DX302SB is not heating the water, dishes are not being cleaned during cycle...how do I fix?
  • Anonymous Dec 21, 2008
    Ive changed my element and still have the same problem.
    Suppose it could be the stat or maybe even the controller unit.
    One other issue which I dont think it related is the catch on my detergent dispenser is broken meanign the lid does not stay closed.
Who posted this comment I am really appreciative. I have had the same problem with my dishlex. I disassembled the plumbing and removed a chunk of plastic wrapping from inside the pump. Then I checked the heater with a multimeter. It measured fine.
The next day I read this post and have since removed the controller. I found the burnt solder joint mentioned. I have since cleaned up the mess, repaired the circuit board, re-soldered the effected component and the dishwasher is now working better than ever.
I have read elsewhere that this problem arises when the door is opened while the heater is on and the program hasn't been paused. I don't know if that is the exact cause but in my house we will be more careful about that from now on.
The damage to the circuit board was on the Normally Open terminal of the relay used to control the heater. The heater is marked as being about 2100 watts. The relay is marked as being able to switch 125Vac. Which is interesting because power here in Australia is 240Vac. At 240Vac the heater will draw a little under 10 amps when operating.
Anyway the circuit board trace is possibly a little narrow at the point where the burnt connection was and I can see why it would have burnt out. The other terminals on the relay were showing signs of becoming dry joints too. The repair was effected by completely removing the relay, cleaning all the joints, re-soldering the relay and laying a loop of tinned solid wire around the burnt terminal to replace the missing piece of circuit trace.
Anyone who has a little skill with a soldering iron could perform this repair. The worst that could happen is you could lift what is left of the circuit trace from the board. Since the controller is already broken you can have a go and probably save yourself the cost of a new controller.
Posted on Apr 08, 2009
  • schmigma Apr 28, 2011
    This post is awsome, i haven't fixed the problem yet but as you said, i flipped over the controller main board and there it was a burnt joint, its burnt back around 8mm back from the wire, but i think i will be able to fix, many thanks of around 232 dollars worth, my rank for you is guru, awsome
Mine too displayed the same problem - not heating, therefore not cleaning or drying properly (door still cold 20 minutes into cycle). I've found that there is a common (yet not often talked about) issue with a point on the controllers circuit board. If you remove the controller (simple to get at), remove the circuit board from the controller and flip it over you will see a 'burnt' solder joint on one of the legs to a black box component - resolder that joint and all should be well. Don't pause or open the door during a cycle as this seems to cause the joint to blow.
Posted on Jul 23, 2008
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
I have a dx302. its not heating the water or drying.
download this manual...
http://epubl.luth.se/1402-1617/2006/118/LTU-EX-06118-SE.pdf
Aug 22, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Hi I have a Dishlex DX302. After an intense wash it leaves a film of scum / powder on the dishes and sometimes does not wash properly. I have tried using various soaps and also tried to use a dishwasher...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 17, 2011 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex dx302 not drying dishes. Doesn't seem to be as hot as usual when opened immediately after finished. Steam not present.
Check your heating element..
How to Replace the Dishwasher Heating Element
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 04, 2011 | Dishwashers
No drying cycle on the electrolux dishlex 302 any idea's
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Nov 10, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex 302 water not heating
My son fixed this problem with our DX302 dishwasher only this morning. Now works fine and hot. Found the solution on this site posted 11 august 2008 from dishwasher dishlex dx302wb no hot water. There are photos to help you. Take out the circuit board in the top of door and resolder the points on left hand side of green board there are 2 long solders and a half moon. The problem is at the top of the 2 long solder lines. Do not replace your element. There is a fault with the circuit boards on this model 302. I want to thank all the posters for helping me fix my no hot water problem.
Jun 26, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
No heating in dishwasher
Do not plug it into hot water UNPLUG. It needs cold water going through the system.
It may be the heating element or just a loose connection on the computer panel.
If you have any Questions plese do not hesitate to ask
Dec 03, 2008 | Dishwashers
Vulcan dishlex 750 eco taking alot longer to complete wash cycle.
How is the water flow into the machine. Are all your inline filters clean?
Apr 05, 2017 | Dishwashers
Dishwashers Logo
728 people viewed this question
Top Dishwashers Experts
