Texas Instruments TI-83 Plus Calculator Logo
Posted on Feb 10, 2011
I am attempting to transfer programs from My TI 84 SE To a TI 83 Plus. This is returning an "Error in Xmit" message. The TI 83 Plus is new and the cable connecting the two is new. Does anyone else have this issue.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
318
Points
I've had this problem before too. I found out that one of the cables wasn't plugged in all the way even though it looked and felt like it was, so I would suggest giving it a firm extra push to ensure that the cable is all the way in. If you were trying to transfer the OS you will get an error, I'm not exactly sure if it is that same error though.
1helpful
Xmit error message
Error in Xmit meaning one of the next options:
• The TI-84 Plus was unable to transmit an item. Check
to see that the cable is firmly connected to both units
and that the receiving unit is in receive mode
• You pressed ON to break during transmission
• You attempted to perform a backup from a TI-82 to a
TI-84 Plus
• You attempted to transfer data (other than L1 through
L6) from a TI-84 Plus to a TI-82
• You attempted to transfer L1 through L6 from a TI-84
Plus to a TI-82 without using 5:Lists to TI-82 on the
LINK SEND menu
Connecting casio to texas instr
I compared two cables and noticed that they are identical. One insulating part on the TI cable is longer than the corresponding part on the Casio cable. But no matter, let us assume that the calculators share the same 2.5 mm connection.
You can verify the hardware compatibility as follows
  1. Use the Casio I/O cable to connect two TI calculators. The Casio cable wakes up the TI84PLus
  2. Use the TI I/O cable to connect to Casio calculators. The TI cable wakes up the Casio FX9550GII but not the CFX-9750GPlus nor the Graph 35. But that may not mean too much.
  3. Create a Matrix ( a 3X3 ) on one TI8xPLUS and transfer it to another TI8xPLUS using the Casio Cable.
  4. Create a small (3x3) matrix on one Casio C/FX-9750G/PLUS and transfer it to another C/FX-9750G/Plus.
  5. If you have been successful in any of the above you may try to transfer an object from a TI to a casio or from a Casio to a TI and the cable that worked above.
My feeling is that you cannot. I tried it
When I tried to transfer from a TI to a Casio, the Casio kept displaying RECEIVING , AC to cancel. The TI returned an Xmit ERROR
When I tried to transfer from a Casio to TI, the Casio quickly returned a Transmit Error, while the TI kept waiting for a transmission.
There may be other issues of memory organization, naming conventions, systems commands and program commands so on.
For each problem you want to have your students solve try to supply the procedures for both types of calculators. This, in my opinion, is the reasonable way to go. A benefit to you is that you learn the expert use of both types of calculators.
If you care to specify what kind of programs you intend to transfer from one to the other, one may be able to point you to some resources available on the web.
1helpful
I get a access denied error when i try to transfer programs to my ti 84 plus
Here is what the TI Knowledge Base has to say about resolving the problem you have.Hope it helps.
How do I resolve the error "Access Denied" when transferring an App or OS using the TI Connect software?
The error "Access Denied" indicates that the TI-Connect software could not complete the current transfer due to an unforeseen error. Please try the following troubleshooting steps if the error persists.
Perform a manual "Garbage Collect" on the calculator (TI-83 Plus and TI-84 Plus family only):
• Press [2nd] [0] [TAN] [ENTER] [ENTER] [2].
NOTE: A manual "Garbage Collect" can take up to 5 minutes to complete.
• Attempt to transfer data to the calculator.
Uninstall and reinstall the TI-Connect software:
• Go to Start >> Settings >> Control Panel or Start >> Control Panel and select "Add or Remove Programs".
• Locate the TI-Connect software in the list and then choose "Remove".
• Once the software uninstall process has completed, please shut down and power off the computer.
• Wait approximately 20-30 seconds and then reboot into Windows.
• Download and install the latest version of the TI Connect software from the TI Connect Software home page.
• Once the TI Connect software install process has completed, restart the computer before using TI-Connect.
If the above troubleshooting steps do not work, please contact TI-Cares Technical Support for additional troubleshooting.
1helpful
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to [email protected].
2helpful
2answers
TI 84 won't turn on. New batteries installed. TI Connect recognizes device and I installed new OS. Brightness is not the issue. Any suggestions? This is one of student's calculators. Thank you.
Sorry, answer was posted as a clarification request.
Here it is from the horse's mouth (TI Knowledge base)
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
I changed the batteries and now it will not come on
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create backup using TI Connect™ first.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83 or TI 84 Plus family to reinstall the calculator operating system (see below.)
Reinstalling the OS for the TI83/TI84 Plus family
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TIConnect installed on the computer.
Hope it helps.
2answers
Why do some TI83 program work on a TI84 plus and other don't?
Ti 83 and ti84 really have no difference and operate the same. There was something different or you had varibles used by multiple programs that conflicted w/ the ti84 and it would have done the same on the ti83. If you like to rework it and need help email me at [email protected]
Xmit error
You must hit the "receive" button on the receiving calculator BEFORE you hit the "send" button on the sending calculator.
Receiving Apps
That is because the cable directions are wrong. The sending is B the receiving is A.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
