Question about Philips Magnavox 51MP392H Rear Projection Television
Color convergentce my projection tv will not let me move the red convergence marker. the blue is fine. how is this fixable and about how much will it cost?
  • creightonw75 Jul 27, 2008
    It appears my red "lines are moving up and to the left of the screen. The convergence won't move them back
  • Philips Master
  • 8,617 Answers
The convergence ICXs need to be replaced as well as a couple of the 6.8 ohm 1watt resistors. You can get new STK392-120 ICs you need two and the resistors at the following link and they provide free instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 23, 2008
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Color converger
Yes it fixable,Must replaced 2 convergence ICS,and some or all it resistors are dead.The shop will cost U $300-350 for parts and labors.All DLP Tvs have these Convergence problems sooner or later.Just how long u use the tv hours a day.
Apr 02, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
I have some distored blue color across the screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Mar 27, 2010 | Panasonic PT-53TW53 53" Rear Projection...
My hitachi tv's picture is distorted red and green like a 3-d pic
  • Screen looks 3D
Feb 08, 2010 | Hitachi 57F710 TV
I have a hitachi tv and I have been trying to get the colors even, so that I don't have a lot of red shadow on the tv
If it is a Hitachi projection TV and the convergence will not adjust in any way; if red or blue will not move up/down AND left/right you have a bad convergence IC.
Most of these sets use two chips--this kind of problem is usually fixable in the home.
I do this here for free so if this has been helpful give me a vote.
If you need any direct help or have questions:
etower.766@netzero.net
Aug 20, 2009 | Televison & Video
Blue Shadowing on Flat Panel 50"
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jul 26, 2009 | Sony KP-41T65 41" Rear Projection...
Screen lookes like colores separating
This is what is known as convergence. a projection tube ussally has three picture tubes.. red green blue. they all have to align. the concave picture indicates complete loss of convergence or convegence power supply. First question on these sets Do you have the convergence option in the customer menu under setup. if you do not this is a indication of the common "FL231 fuse problem" and inexpensive simple repair. I have wrote and artilcle on this under my tips and trick section. If you do have the option then next does autoconvergence work. in you case i would not think it work. under blue and red manual convergence does the crosshairs move. if not then this is indication of convergence power supply board. if they move at all this may indicate a convergence amplifer problem.
Sep 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
Seeing double image in three colors
Its a convergence problem for sure ,,,if you cant move the red or blue (green is stationary) then your problem lies on the convervence module.. requiring ....mostly new output ICs like STKs your going to need a tech, for convergence is a common problem with rear projectors and requires patience and a expert to get it back just right. good luck
Sep 01, 2007 | Akai PT4298HD Rear Projection Television
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
