Question about Panasonic Panafax UF-550 Plain Paper Laser Fax
Error 401 & 634
None of our faxes are sending. They keep coming back with either Error 401's or 634 but we dont know what these mean. Some of them when they try send comes up Incomplete Number but again, the fax numbers are correct.
  • Anonymous Mar 28, 2014
    I have fax model # C3781A and when I attempt to send a fax it says error 4756638400011A4 - as I have no manual I do not know how to correct this
    Scholar:
  • 115 Answers
Error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Posted on Sep 28, 2009
    Genius:
  • 2,120 Answers
Press the monitor key and listen for the dial tone or Plug a regular phone into the wall jack to listen for a dial tone, then dial the fax number and listen for fax tones.
If someone says HELLO...HELLO!!. It ain't a fax machine.
Posted on Sep 05, 2008
I have an hp officejet pro 8500 fax, scanner, copier and printer. I keep getting an error message 350 when I have repeatedly tried to send a fax. What do I do and what does error 350 mean? Thanks in...
error 350 means a disconnection, from your machine to that of the remote fax machine. Disconnection can either come from a power shortage, defective or not so good telephone lines, a call-waiting mode on the telephone, a defective fax machine or manual interruption.
Sep 12, 2010 | Computers & Internet
Can't fax multible pages
Your fax machine reads multiple pages into memory before sending the job, this is the pool memory. Two things can cause this error.
  1. Corrupted memory, which keeps the job from transmitting because the data stored is scrambled and lost prior to transmission.
  2. Line static, which makes the connection so unstable and slow that the fax can't get enough pages out of the queue fast enough to make room for the next pages entering the buffer.
If you checked the line and it tested good (not just listening for a dial tone), then it is probably a memory issue.
May 06, 2010 | Brother MFC 420CN All-In-One InkJet...
We have a HP 1050 fax machine. Usually when we send something, it displays send ECM and the number of pages. Occasionally it displays send G3 and the number of pages. I can't find anywhere in the user...
this is just the transition speed and line condition and you dont have to worry about it , the machine will give you an error code if the faxes dont go through alturnativly contact the reciever of the fax to check that they have recieved it
G3 means poor line condition
Apr 09, 2010 | HP 1050 Plain Paper Inkjet Fax
Our HP Officejet 5600 won't receive faxes.
Here is the answer to your question.
Error code 244 can mean any of the following things: :
1. You or the person sending the fax pressed the STOP key , causing the session to stop before completion.
2. The fax machine on the other end determined that there is an incompatibility with your machine and the one you are sending to and stopped the fax session.
To fix this you can try the following things. Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Make sure the fax machine you are sending to can accept and use polling.
  • Select a slower "receive" speed.
  • Enable or disable the ECM setting.
Error Code: 232
1. Can mean that a communication failure has happened between the two machines.
2. It may also mean that the user of the FAX machine you are sending to has pressed the STOP key
3. If call waiting is enabled, it may cause this error. Disable call waiting on your phone line, if you have a fax machine connected to it. The click or beep on the line that indicates you have a incoming call, can STOP a fax session.
4. Another cause of this error code is that the power was interrupted to the machine you are attempting to send a fax to.
Things you can do to solve this problem: Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Try disableing ECM. However, this may reduce the quality of your faxes.
  • Ask the person you are sending the fax to to set the machine to receive at a slower speed.
  • Try the fax again at a different time, incase it is a problem with the phone line.
  • If you phone lines are old, or there is static on the line it may cause trouble sending a fax.If this is the case you will need to contact your local phone company or whoever is responsible for servicing your phone lines.
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Error #1203.
Ok this some times works.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 01, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
NEED ERROR CODE TRANSLATION
I do not know what the error code means but try this http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
They should be able to fix your problem
Jan 09, 2009 | Sharp UX-B750 Inkjet Fax
OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Error Codes
Hi Sir
this is very common error that happens in fax
i am sending a link which has all the things of hp
please follow that arcticle it is going to resolve the issue for you
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=bpu02549
Jun 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
3150 fax machine outputs a blank page when my fax sends to it
(05) Would you, please, SEND a fax from the machine that blank faxes are being received from to a different recipient on a different fax machine all together, please?
This will enable us to pin down which machine is really experiencing the issue.
Thank you
BJ @:)
Apr 17, 2008 | HP LaserJet 3150 All-In-One Printer
Sending fax
NG STANDS FOR NOT GONE , TYPICALLY THIS MEANS THAT THERE IS A COOMMUNICTION ERROR AND THERE IS ALINE DISTURBANCE /NOISE DURING THE CONNECTION WHILE SENDING THE FAX MESSAGE. TRY CHANGING THE TELEPHONE LINE IF IT IS AVAILABLE. HAPPY FAXING OMNIPRESENT
Oct 02, 2007 | Brother IntelliFAX 4100 Laser Fax
Panasonic Panafax UF-550 Plain Paper Laser Fax Logo
1,610 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
