Battery wire my battery wire keeps fallin out. can i take it back to best buy to fix?
  • T&N Family Electronics Dean and Sherrie Terrell
    Do you mean power wire to power supply? You can bend the prongs a little to make it tight. Explain more if this is not it, please...........
    Sergeant:
  • 458 Answers
Best Buy should be able to repair that for you. It is a little complicated for a regular person. I have the steps but they are not easy. Let me know if you want them.
Posted on Aug 20, 2008
Yeah the wire connects to an outlet then to the side of the laptop power supply i guess
Posted on Jul 24, 2008
    Genius:
  • 1,011 Answers
Dear its a great job to do. you have to soldered it. or fix it by inserting the open clips to the remaining ones and finally fix the battery. use some tape or other to keep it fix.
If 3 volt battery is bad
It will not remember the time or date and keep asking you to confirm them.
Apr 18, 2014 | Dell LATITUDE Computers & Internet
Im trying to hotwire my blower motor directly to my battery and a toggle switch. the problem is the wires keep geting so hot they start to melt the insulation. what can i do to wire it correcty?
go to any auto parts store and buy a heavy duty wire. this should fix the problem. because the blower motor, is pulling to much power when its on. the best way is to put a fuse in the line between the battery and toggle switch. this way if it shorts out, it will blow the fuse try a 20 amp fuse if this is not enough. go to a 30 amp. Good-day !
Aug 25, 2011 | Dodge Dynasty Cars & Trucks
I have a 2001 lincoln ls, the driver's side window has fallin down and can not get back up. How do you go about fixing it?
Have to remove door panel,to get to the Door Window Glass Regulator
I don't know if you want to do this job yourself. There is an inner door support brackets,module assy,and more,that has to come off,just to see into the door cavity.
May 17, 2010 | 2001 Lincoln LS
Chain keeps fallin off!
Does the rear wheel go on such that you can adjust it to take any play out of the chain? If so, turn the bike upside down or put it on a bike stand. Loosen the back wheel and pull it so that the chain is tighter and then tighten the wheel. There are other possible causes but I suspect this since you recently removed the wheel. Also I'm not sure how often the chain falls off. If this doesn't work, ask again and let us know how often its coming off. Good luck!
Mar 15, 2010 | Schwinn Windwood 26 Women s Cruiser...
Gilera runner 50sp 06 (New shape) keeps bogging out when acc
why is my gilera bogging out when i drvie it on the flat
Nov 24, 2009 | 2006 Gilera Runner VX 125
My crib is broken how can i get it fixed? the rails will no longer stay up and when applied pressure they fall
REPLACE THE HINGES OR PERMINANTLY SCREW THEM TOGETHER BUT PLEASE FIX ASAP FALLIN RAILS HAVE CAUSED MANY BABY INCEDENTS
Jul 14, 2009 | Baby Gear
Remote key will not lock doors
there is a alarm mechanism inside the drivers door that has fallin off if you go the the passenger door and unlock it first the alarm will be disabled. what you would have to do is take the drivers side door panel off and look at the lock mechanism there should be a triangle shaft comeing out the back of it and there should be a black peice attached to a wire dangling in the door that needs to be glued back on but make sure to no glue the part of the peice that needs to rotate then test to see if it works before installing the door panel back on.
Mar 09, 2009 | 1996 Jeep Grand Cherokee
Laptop Monitor keeps going blank or near blank. When the monitor is moved into a different position it may turn back on or it may not.
Sounds like the back light of the screen is playing up or there is a loose wire. Either way the screen will stop completely and will not keep working. The best thing to do is try and buy a new back light for laptop screen and replace it, or take it to a professional to look at and repair for you. It's not a simply fix. Thanks igi_57!
Aug 11, 2008 | Computers & Internet
Replacement Battery
Hello kstnf,
The battery for the Insignia Pilot MP3 player appears to be available from Best Buy Parts Search for $41 plus shipping. Go the Best Buy Parts search website and search from the Model number of your MP3 player (which I believe is NS-4V24). Or you can call 1-888-BestBuy to order.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 27, 2008 | Olympus m:robe MR-500i MP3 Player
Computers & Internet Logo
299 people viewed this question
David Payne
David Payne
