Question about DeLonghi Heating & Cooling
Thermostat broken on delonghi heater - DeLonghi Heating & Cooling
  • 143 Answers
I think replacing the thermostat is the right thing to do.
Posted on Jul 24, 2008
Can you replace the wheels on a delonghi DL1001t oil heater
sure id think that any well stocked hardware store could help you select a replacement wheel
Aug 09, 2014 | DeLonghi Heating & Cooling
Problem with thermostat
Try this. Do as you already did above, but this time turn the thermostat slightly clockwise till it comes on again, and leave it at that setting for a while. Does it control now?
Jan 01, 2014 | DeLonghi Heating & Cooling
Thermostat Problem
The thermostat may have failed even though the unit is new.
How do I use the Delonghi trv0715 1500w Vento High speed convection heater
The owner's manual is available as a PDF here: http://www.delonghiusa.com/index.php?product&nid=107 .
Many recommend you plug the heater in and turn it on in a well-ventilated room (like a garage) for the few hours of use. If you are using the heater to warm a room, plug it in with the thermostat set to maximum and set the power selector to 3 until the room reaches the desired temperature. Then rotate the thermostat clockwise until you hear a click. You can set the power level to 1 or 2 to conserve energy while maintaining the current temperature settings.
If you are trying to avoid frozen pipes in an area, plug in the heater and set the power selector to 3 and thermostat to *.
Always remember to keep anything flammable away from the heater (loose drapes etc.) There is an overheating protection circuit built into the unit. To reset it, you need to call the DeLonghi service center.
I hope this helps.
Mar 05, 2011 | DeLonghi Heating & Cooling
My Coffee from my DeLonghi Magnifica does not seem to be hot enough.
Possible weakness in the thermostat which make the heaters cut off at a earlier state. So try to check the machine for any loose connection to the lines, the heaters or else the switch and thermostat must be looked into .
Jan 24, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
My Delonghi DE60PYROS needs a new thermostat, are
Ok get a Service Manual, and the Sensor, and it is not too hard.
Mar 29, 2010 | DeLonghi AS1070 Electric Single Oven
Heater stopped working suddenly
In the past I have nothing but problems with DeLonghi heaters. I replaced them with Pelonis heaters and have had no problems since. Pelonis heaters are availible from Home Depot at a very reasonable price. This is based on my experience only. Hope it helps.
Ray
Dec 05, 2008 | DeLonghi Heating & Cooling
Delonghi DR18T Timer Replacement
before you replace the timer, check and see if the timer has a battery in it. if it has, then change the battery. it will work fine.
Jan 25, 2008 | DeLonghi DR-18TG Oil Filled Radiator...
Heating & Cooling Logo
128 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
