Question about LG Televison & Video
I have an LG RT-32FZ10PX 32" Flatron Wide Screen TV and having problems changing the menu back to English (Its currenty in German)? When I press the Menu button on the tv or remote the menu shows up. However I can't move the selector up with the tv or remote to the STATION Menu which has the Language Setting for English? I can move the cursor to the other 3 Menus but not the important STATION Menu? Any suggestions. Cheers
5 Suggested Answers
TVtechmaniac
  • 140 Answers
SOURCE: Buttons dont respond correctly
Sounds like one or more of the keypad buttons are sticking - That would also cause the remote control to stop functioning.When you saw "P:0 V:0" you somehow managed to put the tv into the service menu. Pull the keyboard away from the plastic buttons and make sure nothing is in the way.
Posted on Aug 23, 2007
MikeNJ1964
  • 398 Answers
SOURCE: Menu Language
According to Hitachi themselves, there is no such set with model number C29-F100. The closest one they have on file is the C29-F800. Perhaps your set is an over-seas set, originally sold in Japan? The original remote has a MENU button surrounded by 4 "arrow" buttons - arrow up, down, left and right. For the C29-F800, using the original remote, press the MENU button 4 times or the SETUP button once. There should be 4 choices on that page and the first one, the one on top, is LANGUAGE. Highlight the first one using the "arrow down" (also labeled P-) button and select the language ENGLISH using the left or right arrow buttons. Exit the menu by pressing MENU 3 more times or SETUP once. I believe I can download the owner's manual for the C29-F800 and send it to you if you need it.
  • 476 Answers
SOURCE: setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Posted on Feb 24, 2008
  • 319 Answers
SOURCE: tune in an older (1996/1997) model Philips tvwithout a remote
Most TVs have features that cannot be accessed w/out remote. Make sure you copy exact model number on TV then go online to seach replacement remotes
Posted on Apr 21, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 8560 - Changing Menu from German to English Language
To select the default language on the Control Panel:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Control Panel Setup], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Language], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select the required language, and then press the [OK] button.
  5. Press the [Back] button, located to the left of the 'Up' and 'Down' buttons, three times to return to the Main Menu.
To select the default language using CentreWare Internet Services (CWIS):
  1. Open an Internet web browser on the workstation.
  2. Enter the IP Address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  3. Click on [Properties]. The Properties window will be displayed
  4. Click on the [General] folder on the left, and then select [Printer Defaults].
  5. Under the User Preferences section, select the language from the Set Control Panel Language pull-down.
  6. Click on the [Save Changes] button.
  7. Click on the [X] in the upper, right corner to close
If you are talking about the driver menu you have to delete and reload the driver with the english
Posted on Jul 22, 2008
Need change english german
simple just press language
Oct 10, 2013 | Thomson Televison & Video
LG rear projection colours out of alignment
I have a similar problem with an LG (except my red is the one that is fine) and was able to talk to a tech in some detail about it. The tech prefaced by saying that he had done a hundred or so of these with exactly the same issue. This is very common and the life span of rear projection televisions is not great. Having said that, plasmas and LCDs are also limited in life span mostly due to modern high performance gaming machines which shorten the lifespan of monitors both plasma and LCD alike.
From what I have gathered, this is not a problem that you can easliy sort out. (Of course they would say that though) It involves replacing the digital board which means soldering followed by aligning the lamps which requires quote a lot of expertise.
The part itself apparently costs around $200 Australian and the labour will vary for the cost of the technician but I was quoted that the labour was about the same cost as the part.
Not sure if I would call this solved but I hope it has been at least a little helpful.
May 26, 2009 | JVC AV-56P575 56" Rear Projection...
Unable to access subtitles whilst watching digital channels
Contact your TV service supplier to be sure that subtitles are available in HD ...
Jan 07, 2009 | LG Televison & Video
On wide screen mode screen flickers at top
hi there,i spoke to samsung direct and they said switch tv to standby,then press info,menu,mute then standby wait 15 seconds. then switch tv back on a secret menu appears on the screen arrow down until 12.reset arrow right on remote and follow instructions very easy hope this can help.
Jul 14, 2008 | Televison & Video
Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 30, 2008 | Televison & Video
Need to reset lamp life indicator on lg rear projection tv model no 525sz812-tb
9) To Check if it was a success
Jun 21, 2008 | LG Televison & Video
I have a Toshia TV - Model 19A24 - Made in Thailand - Dated Nov. 2004 # 7961C2877 A. With it, I have your manual control unit: CT-859. I accidentally pressed "menu" on the control unit. ...
Your closed caption is turned on. Go into the menu and set captions to off or look for captions button on remote. Sometimes identified as cc. Press it until "captions off "appears on screen. That should do it. Good luck.
Jun 02, 2008 | Toshiba Televison & Video
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Televison & Video Logo
156 people viewed this question
