Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker won't stop making ice cubes, ice cubes overflows the bin, also water drips and freezes in long stalagmites and tall stalagtites in multiple places.
  • Whirlpool Master
  • 19,396 Answers
That means that the solenoid that controls the ice maker is defective and must be replaced with a new one.
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
Hi there my ice maker on a whirlpool model#ED25PQ,is making ice but the cubes are clearer looking than in the past also when water fills in to make new cubes it sprays all over refrigerator and water goes...
A) If water sprays like you say then there might be air trap on the line.
b) But most likely your Ice maker fill valve me be not closing and overflowing and creating the freezing mess.
Feb 14, 2015 | Whirlpool Refrigerators
Kenmore icemaker tray leaking water (model 795.51022.012)
Do the old 'KISS" thing first (keep it simple ......thing). Chances are that there are tiny calcium deposits in the ice tray which makes an ice cube stick in the tray. If one ice cube sticks, the water will overflow as it needs all the trays empty for the filling. The water will drip down into the freezer area causing chunky ice and stalagmites. The calcium deposits are very teeny in size but will hang up an ice cube from dropping. If more than one ice cube (basically all the ice cubes) didn't drop then the heater in that unit that initially gets the ice cubes to drop could be bad.
I've taken the ice cube assembly out and used vinegar with baking soda to dissolve the calcium and that worked. I left it in for a couple of days. "Do NOT" use anything like a knife or whatever to scrape the bottom of the tray as it will destroy the finish and keep the ice cubes sticking.
When I had the warranty service come out, the technician explained what happened to the tray (calcium). He replaced the tray but the next time it happened I used the vinegar and baking soda. I eventually bought a new tray for 1/2 the price on the internet when the problem happened later on in life.
Jun 13, 2014 | Kenmore Side by Side Refrigerator
Maytag icemaker drips dirty water onto existing ice ini tray.
please check or install screen filter in the water valve at the back beside compressor
Jan 15, 2014 | Maytag AFD2535
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
Both refrigerator and freezer not cooling properly in refrigerator?
The ice maker not working: ---
Compressor not running on refrigerator?
Water dispenser not working on refrigerator?
Ice maker stopped making ice?
Water Overflows in Ice maker and freezes inside?
How to replace Ice maker assembly?
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
After replacing ice maker assembly, ice is not getting made?
Ice maker is leaking water and causing the ice to freeze?
Ice maker is noisy and not making ice?
Refrigerator ice maker stopped making ice?
Ice maker leaks water into ice bin causing a glob of ice?
Amana Refrigerator leaking water from ice maker?
Ice maker leaking?
Ice maker is dumping the ice cubes out before frozen solid.
Water overflowing ice maker?
Ice cube is getting stuck up hard in ice maker
Icemaker quit working?
Quit making ice
Water leaking into ice tray, frozen glob of ice
Not making ice, and water leaking in freezer?
The ice maker stopped making ice?
Ice maker not making ice?
Ice maker quit working?
Ice maker dispensing black pieces of plastic in the ice?
Replaced Ice maker but its still not making ice?
Ice maker leaked creating an ice block?
Ice tray leaked?
Ice maker stopped functioning?
Ice maker stop working?
Ice maker failed
Old ice maker stopped working?
Old ice maker started leaking?
Ice maker not working?
Ice maker overfills and cause water to flow into ice dispenser and freezes?
Ice maker didn't make ice?
Ice maker was leaking?
Ice maker was leaking after it filled up with water?
These will help.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Leaks into cube bin and freezes up
don't understand what you mean,if you're saying water is dripping into the ice maker more than it should you have a bad water valve,
Nov 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
The water continues to drip after the ice cube maker is full.
Sounds like the water fill solenoid valve is leaking by. You will have to change that solenoid valve if the water continues to drip into the ice maker tray after a normal fill cycle.
Dec 05, 2006 | Jenn-Air JCD2295HES Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
163 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
