Question about Dacor MCS130 Millennia Electric Single Oven
Simpson 2001 wall oven lamp cover has broken where to find replacemnet
  • dgcrooks May 11, 2010
    Cannot find a 10W 120V bulb for the twin lamps
  • 93 Answers
Phone 131350
Posted on Aug 29, 2009
I need a owners manual for Simpson Concorde fan forced oven?
I recently helped a friend fix the oven in his secound home, turned out the timer was shot. But, in order to find this out, we had to pull the oven from the wall, and there was a wiring diagram in an envelope on the back of the oven. That is all that it took to figure out the problem.
Dec 14, 2014 | Ovens
Have a bulb broken off inside socket in gas oven..cannot remove..need help
power down at the breaker or unplug the oven,then if possible you can remove the lamp cover and shell from the rear oven wall,then most lamp bases have spade terminal connections unplug these remove the whole lamp base with the broken lamp,remove the broken bulb base,then check the center power tab inside the lamp base to make sure it isn't flattened out too much,otherwise carefully bend it upwards to make sure it makes contact with the bulbs base then re-insert the terminal connections and new bulb into the opening at the rear of oven,then replace the bulb,but,do not over tighten new bulb as this leads to non operation due to heating
Jan 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
What are the dimensions of a Simpson 2001 wall oven
4 burners. 540mm wide x 600mm. Oven is 1040mm high at rear and 890mm at front. Good condition. Only selling because I am upgrading.
Just to confirm is youre stove a Simpson Riviera ?
I hope this helps
Feb 20, 2012 | Ovens
Simpson wall oven 2001 wont turn off unless its turned to automatic.
Oven thermostat is faulty. needs replacing.
Feb 17, 2012 | Ovens
I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
Jul 31, 2011 | Ovens
Simpson Evolution 906 Oven light. how to replace it?
I have just replaced mine & had the same problem. I couldnt remove the cover. I found that I just couldnt grip the cover well enough. I got some rubber washing up gloves & used them to grip the cover. It was still tight but it un skrewd quite easy this way.
Jun 28, 2010 | Ovens
Simpson Evolution 904 Wall Oven. The grill doesn't always work
It sounds like you may have a faulty switch. Write down the appliance name and model number. Using your computer go to repairclinic.com you will be able to search for your switch. They are very reasonable on prices and give fast delivery. Hope this helps.
Nov 08, 2017 | Ovens
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Dacor MCS130 Millennia Electric Single Oven Logo
484 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
