Question about GE Dishwashers
We have just installed GE Model GLDL560NSS. It fills with water and it emptys the water but it doesn't actually wash or rinse. The water just sits at the bottom of the dishwasher tub
I had the same problem running the dishwasher the second time. The first time worked perfectly. I thought the problem was from the sensor not reading enough water to actually start the wash cycle. It sure uses less than any dishwasher I've had before. When I tried to restart it the machine drained the water that was in it. I later found out it does this automatically when you push the restart button. I poured water from a bucket into the dishwasher and tried this a few times and found that on the fourth try it ran fine and haven't had a problem since. I didn't know how much to put in and did overfill it once. Maybe the sensor float or whatever was stuck and overfilling it helped.???
Posted on Aug 03, 2008
GE Commercial Washer Model WCCB1030J1WC. when it gets to rinse cycle to fill, the water just runs in and spins out. Is this machine suppose to have a rinse cycle where it fills and you put downy in.
as too the actuall program of this machine , I cant say for sure , but I can say the action you describe as (wrinse cycle) is supposed to do exactly as you described , Now "soak" is a different action entirely , this step it fills then holds for a time , then spins out . this is the action I like to use downy in seems to work better for me .
Jan 18, 2017 | GE Washing Machines
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
It spins, but doesn't pump
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
It doesn't spin or pump
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
Machine fills with water, sits for a couple of minutes, agitates for 15-30 seconds, stops for 3-5 min. agitates for 15-30 secs etc... When rinsing, empties water starts to spin, kicks into high gear for a...
Your motor/clutch combo is on the way out. The motor is overheating and turning off. Cools down and restarts.
You need a new motor/clutch combo or a new washer. I do not recommend another GE.
Jul 07, 2009 | GE Washing Machines
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
Ge prodigy wpse4270aoww won't rinse or spin
try to clean out the water pump lines from pump to out to the drain
Feb 25, 2008 | GE Profile Prodigy WPSE4200A
Dishwashers Logo
210 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
