Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
  • 101 Answers
You are copy rhe data is more than the limt of pen drive so please go to removebale dard drive and right click proprtes check avalable space than you copy the dat according to the space avlabale in the drive
Posted on Jul 23, 2008
I Guess This problem is w.r.t Directories / Subdirectories and file path.. The Total Characters in the file path (Including File name) Should not exceed 256 Characters including Spaces...
assume some file in C:\ trying to copy to x:\ (your Memory Card)
File on c:\..\..\..\..\rhjurhi.jpg should not exceed 256 characters.. like x:\..\..\..\..\rhjurhi.jpg
May 28, 2010 | Kingston 4GB Secure Digital High Capacity...
It gives a cod 10. What can I do
If you received a (Code 10) error and have more than one USB device inserted, remove the devices and insert the Kingston DataTraveler by itself. This error may be an indication that your particular system cannot support more than one USB device at a time.
Mar 02, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Power Surge on Hub Port
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
I have Hp Compaq nx 6110 Laptop everything is ok boot system normal no any error but just laptop move any where then system stuck and only way of power off and second problem is "power surge on hub port: a...
1st prob. - I appears there is a loose connection problem somewhere - try reseating your RAN and hard disk.
Try to determine which part of the laptop is causing the problem, not moving the laptop around the room but by flexing different parts of the laptop and power cable etc. while it is on your table.
2nd prob -
Some USB devices draw more power than the USB port can provide and you get the error message - "exceeded power limit".
In these cases you will need to purchase a powered USB hub, connect this hub to the laptops USB port and connect the offending USB device into the powered USB hub.
Mar 31, 2009 | Compaq NX6110 TFT XGA Notebook
Pendrive problem
Try with another usb port ensure that port is enabled .
1.Go to Run and type "Devmgmt.msc" and press Enter.
2. Go to Universal Serial bus Controller. See if there are any red colored cross? If yes, right click and enable those USB Ports.
Hope this helps.
Mar 04, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
You try another systems like defrent oprating system and difrent congirations some times some of the os are not suported to run the pendrives. check the pendrive when you fit the usb port.
Jul 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
MFC application in kingston data traveller encountered problem and needs to be closed
how did you try to format ?, try to unistall the driver when complete put the drive back in usb port. if that doesnt work keep the drive in port and open my computer right click on your thumb drive and go to properties click on tools and try error checking. this is probably where you try to format. once test is done pull drive out and reboot then put drive back in
Feb 27, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Power Surge error message
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
48 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
