Question about Samsung DVD-R130 DVD Recorder
Copying video to dvd
We have bought a Samsung Recorder R130 unfortunately no manual came with it and the shop cannot find it. How do we set up the recorder so we can copy our holiday videos to dvd?
  • muzon Oct 16, 2008
    copying video to dvd
  • Anonymous Nov 25, 2008
    I just bought brand new dvd-rw ( FUJIFILM ).
    The Recorder rejects the disks
    The message to INITIALIZE the disk does not come up.
    What are the recommended disks ?
    Other suggestions would be appreciated.
    Bernard
Recording from external equipment:
1) Place disc in disc tray (this always helps)
2) Wait until "LOAD" disappears from the front panel display. If unused DVD-RW disc is inserted, the message "Uninitialized Disc Do you want to initialize this disc?" will appear. Follow the onscreen prompts.
3) The audio/video inputs are located on the front panel. The audio/video outputs of your vcr are connected to these inputs through rca cables. Press the INPUT SEL. button to select the input. The front display changes in the following sequence: CHANNEL NUMBER - AV1- AV2 - DV
(DV is for a digital camcorder)
4) Press the REC MODE button repeatedly to select the recording speed (quality) SP - LP - EP - XP
5) Press the REC button
6) Press STOP when done
When using DVD-RW/DVD-R discs, the message "Updating the information on disc. Please wait for a moment" is displayed
7) Go have a shot of whiskey
Good Luck!
Posted on Sep 12, 2008
  • 135 Answers
1st, does it come with a driver...if it doesn't, just make sure it is installed properly in your PC, then you just need to install a dvd writing software in your PC e.g. NERO Pro (v7 or later)...then, all will fit in...
Posted on Jul 23, 2008
Samsung DVR-R130 wont release the disc.
Most players will have a small hole on the front panel where you can access the manual release using a paperclip. I checked your Owner's Manual, and didn't see any mention of it, but most every DVD player I've ever seen has one. Hope this helps.
Dec 24, 2007 | Samsung DVD-R130 DVD Recorder
How do i connect dvd recorder to satelite receiver
PLUG RED WHITE YELLOW OUT FROM SATELLITE TO RED WHITE YELLOW IN DVD RECORDER SELECT L1 YOU WILL SEE THE SAME PROGRAME ON TV IF YOUR SATELLITE HAS S-VIDEO REPLACE THE YELLOW CABLE WITH S-VIDEO RECORDING QUALITY WILLL BE SUPERIOR
Dec 14, 2010 | Samsung DVD-R130 DVD Recorder
Samsung dvd r130 won't keep correct time
YO MUST DO FIRMWARE UPDATE REGISTER PRODUCT ON SAMSUNG YOU EILL BE ABLE TO HAVE FIRMWARE WITH INSTRUCTIONS
Sep 04, 2010 | Samsung DVD-R130 DVD Recorder
Hola como esta quisiera saber como hago para programar mi DVD SAMSUNG R130 ya que me aparece con la palabra SAFE y no me deja hacer ninguna fucion le agradesco de antemano su colaboracion Att: Jorge...
Gracias Jorge Sanabria por darme la oportunidad de responder tu pregunta.
Chequiando el internet me doy cuenta de que el Samsung DVD-R130 DVD Recorder no es un producto que lo recomiendan por clientes .
Esta es la informacion que encontre. http://reviews.cnet.com/dvd-recorders/samsung-dvd-r130/1707-9141_7-31738526.html?tag=mncol;lst#manDesc 3 de 10 compradores no recomiendan este producto. Mi opinion personal es de que si lo puedes regresar eso fuera lo ideal pero si no se puede asmelo saver y buscamos una solucion para este problema.
Si esto soluciona tu problema x favor as grado mi respuesta. gracias
============================ Thank you Jorge Sanabia because you give me the oportunity to answer your question.
Checking the internet I notice that Samsung DVD-R130 DVD Recorder is a product that is not recomended by the customers.
This is the information I found. http://reviews.cnet.com/dvd-recorders/samsung-dvd-r130/1707-9141_7-31738526.html?tag=mncol;lst#manDesc
3/10 customers don't recomend this product.
In my personal opinon is that if you can return it, that will be the ideal but if you can't please let me know to find a solution to this problem.
If this solution solve the problem pleas grade my answer.
Tahnk you
Aug 15, 2010 | Samsung DVD-R130 DVD Recorder
Disc is stuck in the tray - samsung dvd R130
Without knowing more of your specific situation, it sounds like the disc is physically stuck and is blocking the motor mechanisms from ejecting. There should be 1-2 screws on each side & one at the rear of the player to remove the outer casing. When you open it, any obstructions should be obvious. The screws should be easy to figure out with an arrow pointing to them stamped into the medal, kindof looks like: =>
Mar 13, 2009 | Samsung DVD-R130 DVD Recorder
Do I have to use a DVD-RW with a Samsung R130
Hi and welcome to FixYa,
To my knowledge, a Samsung DVD R-130 will only accept blanks are either DVD-R or DVD-RW.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 14, 2009 | Samsung DVD-R130 DVD Recorder
Dvdvcr2 displaying SAFE
Hold down the "INFO" button on the remote for 5-10 seconds and this will clear the "SAFE" mode.
Jul 18, 2008 | Samsung DVD-R130 DVD Recorder
Dvd-r130 out of sync
Change recording speed to sp.
Mar 26, 2007 | Samsung DVD-R130 DVD Recorder
Samsung DVD-R130 DVD Recorder Logo
190 people viewed this question
Henry  Thomas
Henry Thomas
