Loading my 7550 Printer it wants to know device Driver
Were I get support for new scanner poblem
Posted on Jul 23, 2008
  • paseo1 Jul 23, 2008
    I just purchase l7550 and scanner do not print legal page in full
No disk to run my photosmart 7550 printer
Hi
You can still install your printer by downloading the software/drivers straight from the printer's support site.You need only to select your PC's Operating System [Windows 7,Vista,Xp etc] in order to download the corresponding driver.
Click on the link below for the downloads.
h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=72891
Hope it helps.Thanks.
Feb 25, 2012 | HP PhotoSmart 7550 InkJet Printer
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
I want to connect my Dell inspiron 1525 laptop (basic vista)to HP 7550 printer. What type of usb cord do I need, and are drivers available online?
Assuming this is a Photosmart 7550 printer and not the 7550 Plotter, this is what you will need for connectivity. To connect printer to PC, you will need a standard USB A/B cable... one side is a male A connector and the other one a male B connector. As far as the drivers are concerned, you will not need to download any. Vista already has a compatible driver for your HP Photosmart 7550. HP recommends selecting the drivers for the Deskjet 5550 when installing your Photosmart 7550.
Sep 26, 2009 | Dell Inspiron 1525 Laptop
I have an HP Photosmart 7550 printer. How can I
First plug the printer to the computer .
Click on the "Start" menu button which is located on bottom left hand corner of your screen.
Click on the control panel icon.
Look for the printer/fax icon in the control panel window. Double click on the printer icon.
Find the icon for your printer in the opened window and right click on the icon. Now click on the "Preferences" option.
Look for the menu box pop up with tabs near the top of the box. Click on the "Services" tab.
Click on "Service this device." You will find the button on the Services menu that you just activated.
Click on the estimated ink level tab and a graphic will appear indicating how much ink is left in the cartridge.
Mar 08, 2009 | HP PhotoSmart 7550 InkJet Printer
Device Driver for 7550 Photosmart Printer
Just pick the OS you're running with it and download the driver.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=72891&lang=en&
Jul 23, 2008 | Office Equipment & Supplies
HP PhotoSmart 7550 printer - how to get the top off?
There are three special types of screws on the back of the printer. Using a TORK BIT T-10 screw driver remove the two top screws that holds the gray top on. There are several snap connections on the bottom edge of the gray case.
Jan 02, 2008 | HP PhotoSmart 7550 InkJet Printer
7550 Cradle CRASHES!! into side of printer
I had the same problem with my 7550. I followed this shortcut and so far so good. Be real careful with the strip cleaning and don't use anything but a damp cloth. No solvents.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpd50646
Oct 29, 2007 | HP PhotoSmart 7550 InkJet Printer
jasbo
jasbo
