Question about Microwave Ovens
Need door assembly diagram to replace door latch & spring on Panasonic microwave model nn-t964sf
  • 1 more comment
  • majormike Aug 02, 2008
    Video was helpful, it was the door panel tab.
  • Anonymous Mar 18, 2014
    I have a spring on the door of panasonic microwave
  • Anonymous Mar 25, 2014
    door latch spring appears to be spring. Door will not close and microwave will not operate.
  • Microwave Ovens Master
  • 9,086 Answers
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
My Panasonic microwave nn-t945sfx. Door is hard to shut and is not latching correctly. I inspected the spring and latch and it appears to be working correctly. I noticed the two holes where the latch
Common problem. Apply a small dab of lithium grease to the tips of the door hooks. You might also have to adt. the door latch switch assembly inside the oven as it could be bent out of shape from the hard to close door.
Nov 19, 2014 | Panasonic Microwave Ovens
NN-SN778S DOOR LATCH SCHEMATIC DIADRAM
There should be tension from the spring that pulls the door hook down. If there is no tension, the anchor for the spring has broken off and the outer door frame must be replaced.
Sep 02, 2014 | Panasonic Microwave Ovens
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Oct 25, 2012 | Panasonic NN-T774SF Microwave Oven
Have a Panasonic Microwave Mod. # NN-P294BF. The Door opener (push button type) became detatched from the door latch. It is mounted over the stove. Do I have to take it down to be able to take the...
Here you can find what you need for a very similar model
http://www.searspartsdirect.com/partsdirect/part-model/Panasonic-Parts/Microwave-Parts/Model-NNSD297SR/0789/0123370/50036271/00001?blt=06&prst=0&shdMod=NN-SD297SR
Yes, to take down the face you must have the unit fully accessible - the bolts are accessible only from the rear.
Apr 13, 2011 | Panasonic NN-P295SF Microwave Oven
NN-T964SF 1250 Watts Microwave Oven: my microwave went dead and wouldn't turn on at all...
Sounds like a blown fuse. Carefully remove the cover, and the fuse in directly behind the power cord on the top. Radioshack sells 15A ceramic replacements.
May 17, 2010 | Panasonic NN-T964SF Microwave Oven
Door spring latch broken - how to repair
Inside side of door there are screws that hold glass like a sandwich between outside side and inside side of the door. They are usualy fastened with screws. You have to unscrew and take a part to remove broken latch to replace it with new part.
If you need additional info how to get parts for appliance please do not hesistate to contact me thru this site.2d04cfd.jpg
Feb 21, 2010 | Panasonic NN-T964SF Microwave Oven
Door of my microwave oven NN A524M not closing properly and hence can't use it.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
If needed, you can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
You can find an authorized Panasonic servicer here.
Nov 03, 2008 | Panasonic Microwave Ovens
Dimension 4 microwave nn a725m door will not close
We have critical safety & disassembly info at our site, linked here.
You can order Panasonic parts here. You can find an authorized Panasonic servicer here.
Sep 08, 2008 | Panasonic Microwave Ovens
Door does not latch close on the Panasonic Microwave Oven Model No. NN T444SF
Aug 26, 2008 | Panasonic Microwave Ovens
MY microwave model number Panasonic NN T764SF was operating fine unitl now. but all of sudden the door just would not lock and the light is on all the time. i tried everythng but the door just is not...
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
If you prefer, you can contact your nearest Panasonic-authorized servicer.
Aug 15, 2008 | Microwave Ovens
Microwave Ovens Logo
748 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
