Question about Kenwood KDC-715S
Manually opening a Kenwood motorized face
Hi. I have a Kenwood KDV-V7017. I'm having a problem with the cable that runs from the head unit to the D-Mask. So i've ordered a new cable, but due to the faulty cable, the face does not rotate open when I run power. Is there a way to manually open the faceplate by hand? Thanks in advance for your help.
  • JonnyNeedles Jul 23, 2008
    That worked great! Thank you!
  • 199 Answers
Hi if you pop off the top cover you should see a motor on the right hand side, with a flexi cable connected to it, if you unplug the Flrxi from the pcb, you can then use a pp3 (9v) type battery to power up the motor. this will be much esier than manually moving the gears.
be sure to remove the flexi first otherwise you WILL damage the motor driver.
Regards
Mark
Posted on Jul 23, 2008
I need the instruction manual for my kdcv7017 kenwood cd player
Kenwood has the manuals for many of their products available on their support web site: http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/ . The direct link to the KDC-V7017 CD Receiver user manual is http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDCV7017.pdf . See the Kenwood site for the other available documentation.
I hope this helps.
Dec 01, 2011 | Kenwood KDC-V7017 CD Player
My kenwood kdv 2339 faceplate stole last june. where can i find or buy same faceplate? thanks!
Unfortunately the same MODEL FACE PLATE is needed to work the set. So this can be sourced only from Kenwood as a spare as most of the dealers will not have a spare one. You can request to the service support of Kenwood near to your place for ordering the front panel.
The other option is to try for a second hand from a scrapped set most of which has a damaged main unit.
Jul 22, 2011 | Kenwood Car Audio & Video
Faceplate opens to remove the faceplate but there is no display?
you probably have a bad flexible cable (goes from the face to the main motherboard). unless you are good at desoldering and soldering, you may want to have it done by a professional.
Sep 08, 2010 | Kenwood KDC-V7017 CD Player
Ejecting my faceplate
you probably have a bad ribbon cable.
Aug 06, 2009 | Kenwood KDC-V7017 CD Player
Replace Flex-PCB in a Kenwood KDC-ps909
Don't remember but I think you need "Keys" a couple of funny shaped forks to press in the sides of the head unit...Frankly, if the PCB cable is bad (and you have one). Why not contact a local car audio dealer that sells Kenwood?
Good Luck
Jun 15, 2009 | Kenwood KDC-PS909
Kenwood kdc-v7017 wont turn on, fuse is good
I tested the cable from the face plate to the pcm with a ohm meter and fond that there were a few broken wires in the ribbon cable so i found a downloadable service manual got the part numbers for the ribbon cable and the recptical that the faceplate contacts and ordered them from the kenwood parts web site
Jan 02, 2009 | Kenwood KDC-V7017 CD Player
Kenwood KDV-412 In-Dash AM-FM-CD-DVD Player.. Will not turn on
I found a switch in the trailer which my wife had switched to the off position that controlled the unit. Turned it back on, and power was supplied to the player. Dumb me... I'll not forget this 'fix' Thanks for your service and reply.
Frank
Mar 27, 2008 | Kenwood Audio Players & Recorders
Kenwood KDC-715s problem.
the kenwoods with the motorized face platesdevelop one problem with time. the flexable ribbon cable between the main unit & the face plate. as the face open & closes, over time wares out the cable. problem consists of face plate not opening/closing, display missing & and/or some or all buttons not working. note these can also be intermittent problems. typically the part number is located on the cable itself on the side where it pluggs into the main board. since you have a service manual, you should verify it in the manual. good luck.
Dec 03, 2006 | Kenwood KDC-715S
Kenwood KDC-715S Logo
160 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
