Question about Garmin Nuvi 350 Car GPS Receiver
Will Not Charge
It appears that my Nuvi 350 will not charge. The wall charger works on other products. I tried the car charger and it took it to a screen showing a computer connection. Now I have no screans and it acts like it is totally dead after 7 months of limited use. Any suggestions?
  • martieroets Aug 13, 2008
    i got my garmin 6 months today it stp working only black sreen is not coming on is not charging in car charger also house charger what is wrong
    Problem Solver:
  • 11 Answers
You're still in warranty. Send it back to Garmin.
Posted on Aug 10, 2008
How long does it take to charge a garmin 255W gps?
Are you charging through the computer or wall charge,I charge my Garmin 255w with a wall charger for about 3 hours and I have all the bars.There are different strengths of chargers but even so,overnight is excessive,try a different charger.
Aug 08, 2009 | Garmin nuvi 255W GPS Receiver
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
New Nuvi 760 that won't work
Using the PC to charge a Nuvi is not the correct way to charge. Use either the AC wall charger or DC car charger. Many PC USB ports can not supply enough current to charge a Nuvi.
- Jim
Dec 12, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Nuvi 350 wont charge with car adaptor. But charges with ac charger in usb port of Nuvi. Any thoughts? I have another Nuvi 350 that does charge with this ones car adaptor.
Are you using the same port on the Nuvi to connect the car adapter and the ac charger, or two different ones? If not, then the jack could be broken (solder joint, pin?).
Aug 10, 2008 | Garmin Nuvi 350 Car GPS Receiver
Charge
A new 350 in the box should include a USB adapter, car adapter and AC wall charger.
It will charge faster with the car adapter or wall adapter. You can buy these accessories on eBay. Did you get the window mount?
A new 350 includes the window mount & dash mount pad. Again, you can get these off of eBay. Here's a link you can try:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190242949818
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160270081801
- Jim
Aug 09, 2008 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 250
Have you used the wall charger to fully charge the battery? If the battery is too low after lying around for a month it wil not start, giving it a couple of minutes of charging wo'nt help either, a good and full charge will!
Mar 29, 2008 | Garmin nuvi 350 GPS Receiver
I have a nuvi 200 that wont run when it is hooked up to a power supply
The Nuvi 200 only has a 5 hour battery. Once charged, it can be removed from the charger, but the battery will only last 5 hours. Can you plug it into the car charger and navigate while charging BEFORE the battery dies? If so, and you don't have to remove the charger, you can leave the unit plugged in while you navigate without damage to the unit.
Feb 09, 2008 | Garmin nuvi 350 GPS Receiver
AC charging problem
okay if it charges with your DC, and it gives you plomebs with the AC, i would only charge in the car because your AC charger must not be changing the current to volts and you can easily blow it up... you can buy another charger and that should solve your problem
Dec 24, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350
Disreguarding delholmes1 inappropriate comment, this could be due to lack of charge? Try charging it, or you could contact the seller for a refund or a new product
Aug 16, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
181 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
