Question about Microsoft Windows Vista Ultimate Edition
Every time I run paint shop pro X2 it freezes right on start up. It freezes in the same spot every single time, which is when it says "loading Cache files" or something rather. I have no i dea what it's doing but what ever it is, it is freezing my computer up and its bugging me. Another thing is that I also have paintshop pro X1 installed onto my computer, maybe it could affect X2?
    Scholar:
  • 67 Answers
Did you install the software update for the program. Also remove the software and delete the Paint Shop Pro folder off your HDD and download www.ccleaner.com and clean the registry with that software. Now reboot and re-install Paint Shop Pro.
Posted on Jul 23, 2008
My Paint Shop Pro X2 will not load. How can I resolve this?
Go to bottom of left hand corner of screen click start then click run then browse find your program click open download
Sep 06, 2010 | Corel Paint Shop Pro Photo X2 Full Version...
When I load paint shoppro x2 it closes worked fine
try to clean your registry or try to reinstall the software it may have some corrupted files
May 06, 2010 | Corel Paint Shop Pro Photo X2 Full Version...
Trying to install on new computer
On CD or back of packaging. If you registered it, e-mail or call the company. They will accomodate you.
Apr 20, 2010 | Corel Paint Shop Pro Photo X2
Paint shop pro x2 ultimate upgrade wont rum on Vista Home
I havent actually solved the problem but I did get PaingShopProUltimate to run by starting up in "SAFE MODE" I tried it out and everything seemed to work ok. but of course this is not very convenient.
Sep 05, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
My psp freezes on *updating cache setting*
I found this fix that worked for me:
A. Close Paint Shop Pro Photo XI if is currently open.
B. Go to Start | Run, Type %appdata% and click Ok. (Or find the folder under user\appdata)
C. Open the Corel folder.
D. Delete the following files:
ImageDB.db
LastDBFilter.PspCache
LastDBTreeSel.PspCache
thumbnails.db
E. Select the Paint Shop Pro Photo folder.
F. Select the 11 folder.
G. Delete the cache folder.
H. Close the open box.
Aug 18, 2009 | Corel Paint Shop Pro Photo X2
Paint Shop Pro will not respond AT ALL!
not a hardware or major software prob, but see that if any other software have the same prob...?
you will have to scan your pc through a best virus cleaner or remover. then will have to install a fresh O.S, and then install Paint Shop Pro X2, it will run faster then before..
take care
shafky
Jun 20, 2009 | Corel Paint Shop Pro® X Full Version for...
Corel Paint Shop Pro (any version) crashes while loading
i recently faced problem in paint shop pro x2...PSP was just freezes or stuck at load...i reinstalled it...It loaded successfully this time but soon became freezes when i shut it off and tried to run again....Now wht i did is this......
PSP Plugins was some whr incompatible or something other problem with Adobe CS4 Plugins..coz i redirected PSP to get load not just its own Plugins but also load Adobe CS4 Plugins as well....and thats whr my Problem started......
So wht i did is...just Cut the Plugins of Adobe CS4 to Desktop(for temporary purpose) and Load PSP again ...and it ran all fine...:)now i went to File/Preference/Locate File and remove the Path towards the Adobe CS4 plugins.....and then same Cut and paste Plugins(which i put on desktop) back to Adobe CS4 Folder......Now no problem at all....chao...
Apr 23, 2009 | Corel Paint Shop Pro 9
Paint Shop Pro Photo x2 won't launch
http://www.symantec.com/norton/support/kb/web_view.jsp?wv_type=public_web&docurl=20090319114809EN&ln=en_US
This web-site offers a fix for multi programs effected by Norton 360, it zapped my corel paint shop pro photo and corel support was worthless, it happened when Norton up-graded my program. MFinSOBs.....
Apr 11, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
PSP X2 Ultimate Not Responding
Hi, I got a fabulous response from Corel and it fixed my same problem! Here is what they sent me. The first step did not work alone, but may have been necessary for the second step to work properly. Good luck!
We are working on a permanent fix for this issue. Use the following workaround to allow launching of Paint Shop Pro Photo versions X1 or X2:
Delete or rename the Paint Shop Pro Photo XI database file: ImageDB.db.
Database file locations
On Windows XP: C:\Documents and Settings\<username>\Application Data\Corel On Windows Vista: C:\Users\<username>/AppData/Roaming/Corel Here are instructions to easily delete the ImageDB.db file.
  1. On XP systems, Go to Start | Run. On Vista systems, Click on Start button and then highlight the "Start Search" field.
  2. Type %appdata% and click Ok (or push Enter on keyboard on Vista systems).
  3. Double-click on the Corel folder.
  4. Delete* the ImageDB.db file and then close this window.
You should now be able to successfully run Paint Shop Pro Photo. *NOTE: if you receive a message that the file cannot be deleted or is in use, Restart the computer, then immediately try deleting the file. It should delete fine after a restart.
If Paint Shop Pro Photo X2 still hangs or is slow responding, try the following: Do the following to delete the Paint Shop Pro Photo X2 Database files. The program will recreate the files upon next launch. First Close Paint Shop Pro Photo X2 if is it running.
  1. Go to Start | Run, Type %temp% and click Ok. (on Vista, click Start button, then highlight Start Search. Type %temp% and then push enter on keyboard)
  2. On the Windows® Explorer Tool bar, Click the Up Folder button. The Up Folder button looks like a folder with a green arrow pointing up. If you don’t see it, Click View | Go to | Up one level. (On Vista, click Organize | Layout | Menu bar. Once displayed, go to View | Go to | Up one level).
  3. Double click on the Application data folder. NOTE: The Application Data folder is a hidden folder. Make sure you have enabled viewing of Hidden files and folders to see this folder. We have included instructions* below for enabling this view.
  4. Double-click on the Corel folder.
  5. Delete all content in the Corel Folder and then close this window
  6. Try running Paint Shop Pro Photo X2 again and note how it functions.
* To enable viewing hidden files and folders do the following:
  1. Go to Tools | Folder Options.
  2. Click on View tab.
  3. In the large white area marked Advanced settings, check the "Show Hidden Files and folders" radio button.
  4. Click OK to accept this setting. You should now see the Application data folder as described above.
Dec 02, 2008 | Corel Paint Shop Pro Photo X2 Full Version...
Microsoft Windows Vista Ultimate Edition Logo
108 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
