Question about Frigidaire FRT21P5A Top Freezer Refrigerator
Which part do I need?
Thanks, for answering my e-mail, but as far as your answer, is it the cold control thermostat or the defrost thermostat in the freezer.
mjpagan
    Master:
  • 726 Answers
Cold control
Posted on Jul 23, 2008
Kenmore 106 56666500 not staying cold intermittantly?Does this sound like a defrost thermostat problem?
Look into the freezer and at the rear wall does it have frost building like the photo HERE If yes you will need to manually defrost the freezer with a hair drier or by placing a bucket of hot water inside the freezer and closing the door. Remove the rear wall of your freezer and see if the defrost heater and the defrost thermostat are good. This is the defrost heater part number=> 2323198 Defrost Heater Assembly The defrost thermostat part number is 2319914 Defrost Thermostat If both test OK the next part is found inside the fresh food compartment and behind the control panel=> 2313172 Main Control Board I am here to answer any questions you have, Thanks Sea Breeze
May 22, 2013 | Refrigerators
Where is the defrost timer in a kenmore elite model 10654602300
I am pretty sure the defrost timer is built into the 8201528 Temperature Control Board
If you have questions about the defrost control plese call Repair Clinic at 1-800-269-2609, 7 a.m. to midnight ET, 7 days a week They will be glad to answer any questions you may have. As for forcing defrost on your model I am still searching for a Service Manual that covers your model. If you suspect a defrost error on this model I would check the defrost heater and defrost thermostat before changing the 8201528 Temperature Control Board Here is a link to the 106.54602300 User Manual I do know that your model is made by Whirlpool and sold to Sears. You can find the parts breakdown for your model HERE
I will be here to answer any questions you have, Thanks Sea Breeze
Apr 10, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
We have a Whirlpool model ED5shaxmb10 that the freezer is working fine and the ice maker works but the fridge portion is not as cool as it should be, it is only 42 degrees at the highest setting
You most likely a defrost problem. Look into the back of the freezer and see if you have frost building on the rear panel like in the photo=> HERE
The most likely part that will need replaced is the=> W10351625 Defrost Control Board
The next most likely parts that may be defective are the=> 2323198 Defrost Heater Assembly
and the=> W10225581 Defrost Thermostat
Like I said the defrost control board is the most likely part to fail and cause defrost to stop working. The defrost control can be found behind the control panel inside the fresh food section just above the top shelf. I am here to anser any more questions should you need answers, Thanks Sea Breeze
Dec 12, 2012 | Whirlpool Refrigerators
I have a Hotpoint hss251fmd and the freezer and refrigerator are getting warm at the top. the bottom and the back are cold. The freezer Is cold but not freezing everything. There's alot of frost inside...
Sounds like defrost cycle has been altered. Look into back of freezer and see if a layer of frost is building. If yes then unplug and place items from freezer into an ice chest or another freezer. Remove the panel that showed the frost layer and defrost the evaporator coils with a hair drier Examine the WR51X10055 Defrost Heater and test if you cannot see burn marks HERE It does not hurt to also change the WR50X10068 Defrost Thermostat Instructions on replacing the defrost thermostat are also on the same page. Here is a=> Service Manual
I will be here to answer any questions, Thanks Sea Breeze
May 08, 2012 | GE Refrigerators
My whirlpool ed5fgexss00 wont get cold
Look at rear wall inside the back of the freezer and see if a frost line is building on rear wall. I have a feeling your freezer is not defrosting properly and not sure exactly what number you model has but checking the defrost timer Click Here=> ED5FTGXKQ00 Controls is where I would begin.We will need to run a couple test to make sure your=> 2323198 Heating Element and Defrost Thermostat=> 2321799 Defrost Thermostat are working properly.Testing heating element is also shown on same page above.Try turning the defrost timer clockwise slowly until refrigerator compressor stops running. This will place the freezer in manual defrost. Then tell me if once you do this if freezer begins defrost. If yes then the defrost timer=> 482493 Defrost Timer is at fault. If stays in defrost simply turn again until compressor restarts again. After doing this I will want you to watch this how to replace defrost heater=> Here I know this may be a little confusing but defrosting manually will help you see which parts may be needed. I will be here to answer any questions you may have, Thanks, Sea Breeze
Jan 08, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have an Amana ARB8057CSR that has stopped cooling. I have replaced the capacitor and overload relay on the compressor as well as the defrost thermostat and eliment. When plugged in it sounds like th
Part of your message was missing but I do see that you did not mention the defrost thermostat=> 12001937 Defrost Thermostat
Chec for any loose wire or burned electrical connections and remember that the defrost thermostat is designed to be on while below freezing temperatures and once the temperaytures reach 50 degrees F the contacts in the defrost thermostat open to prevent the freezer from getting stuck in the defrost cycle for too long and also is a safety feature. Test the defrost thermostat with a OHM Meter while freezing.. Ask if you need I will be here to answer any questions you may have, rate if helpful and please ask if you need more answers, Thanks John Tripp/ AKA Sea Breeze
Possible Causes
Symtoms: Frost or ice on evaporator
1. Defrost thermostat faulty->Check defrost thermostat. Replace if failed.
2. Evaporator fan faulty ->Check fan motor. Replace if failed.
3. Defrost control faulty ->Check control and replace if failed.
4. Defrost heater remains open -> Check defrost heater continuity.Replace if failed.
5. Open wire or connector -> Check wiring and connections. Repair as necessary
6. Refrigerant shortage or restriction -> Refrigerant shortage or restriction. This will look very differen that a totally frosted over evaporator. Click here for what that looks like=> Lack of Freon
Nov 09, 2011 | Amana ARB8057CSR Bottom Freezer...
It stoped frezing everything defrosted the next day it was frezing agen
If you need me and can fill out capsha. That is a way of reading the letters to get my email HERE That is a defrost problem and I will answer you that way for now until I need to understand why people have not been able to answer back.what has happend here at Fixya. Inside your fresh food copmpartment and behinde the light and control panel there is a defrost timer. Your story sounds like it possibly began defrost and thene the timer died. Place a screwdriver in the hole of timer and slowly turn clockwise and tell me if it begins to run again. Here is the location=> MTB2156GES Controls
do you see 15 in photo? That is the timer. And I think it is getting stuck in defrost too long, Sea Breeze
68233-3 Defrost Timer
Sep 17, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Back wall of freezer frosts over
Under that panel is the evaporation compartment Every 6 hours or so the evap needs to be defrosted to prevent ice from building up and blocking the flow of air to the fresh food compartment and basically bringing to a halt any kind of cold air going into the fresh food section. The ice does not form immediately bit takes weeks to get a buildup. The most likely problem is gonna be a bad defrost heater or defrost terminator thermostat. The defrost lasts for 21 mins. The heater needs to be turned off when the temp reaches 50f. The termination thermostat does that job. One of them 2 is bad. OR the defrost timer has died on older models and the auto defrost control has not kicked in due to bad control board or faulty defrost sensor. This was generalization of how it works. Post a model number for a specific answer.
Jul 09, 2011 | Refrigerators
Runs and freezes than goes into defrost mode and never goes back to freezeing
HI .thanks for the question. I think your problem is with the thermostat. It gets cold shuts off , and does not come back on . I would replace the thermostat. thanks the appliance doc. please rate my answer.
Sep 28, 2008 | GE GTS22WCP Top Freezer Refrigerator
Frigidaire FRT21P5A Top Freezer Refrigerator Logo
78 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
