Question about Kenwood KDC-7024 CD Player
Cable Hi, I have exactly the same problem. It powers up, then powers off and continues doing this over and over. I saw the solution that was posted; how would you fix the cable? Thanks, Paul
    Sergeant:
  • 300 Answers
The difficult part is I have a KDC-X815 and you have a KDC-7024, so I have no idea how different they are internally/mechanically. But if it's any help, here are the (excellent) instructions I used to repair mine. I was able to find a replacement cable at a local stereo shop that also does stereo repair.
http://www.csupomona.edu/~bvnorum/faceplate_ribbon_cable_replace_kdc-715s.pdf
This forum thread has a lot of good info, too:
http://forum.ecoustics.com/bbs/messages/4/162949.html
Posted on Jul 23, 2008
Why did my McCulloch EM14E electric chainsaw quit?
Hi:
Let's try some trouble shooting ideas:
1) plug some other tool into the power supply to make sure you're getting power. (maybe there's a tripped breaker)
2) Hook a continuity meter to the saw electrical plug. There should be no continuity.
3) With the meter still collected, squeeze the "on" switch/trigger. The meter should show continuity.
If you don't get continuity in step 3 the odds are that the switch or a wire is broken. The only way to find out is to take it apart.
SAFETY!!! Make sure the saw is unplugged.
Since it's already not working, consider it a fun project to try to figure out why. Work slow and keep the parts organized. Once you get access to the wires and switch, the continuity meter will help you isolate what part is not letting the electrical current through.
Cheerfuls!
Jun 09, 2015 | McCulloch Garden
Power button not working
3 possible sources of your problem. It would really hgelp if you have a continuity meter to check it with. With the saw unplugged, connedt the meter to the plug terminals. It should show no continuity. Press the saw trigger and the meter should show continuity. It probably won't since the saw is not working.
What you will need to do now is use the meter to isolate the problem. There are several possibilities:
- Broken electrical supply wire
- Switch not functioning
- Armature brushes not making contact.
Test each component separately and You will find the problem.
Mar 07, 2015 | Saws
Overload reset button on porter cable 10 in table saw
Why this is in sewing machines I will never know.
But this is an example of pushing a saw beyond it's limits. At best you should have cut one post, shut the machine off and let it cool... then go for the next. (Better yet get a friend with a saw mill saw the thing down for you)
I believe you have burned out your motor. Off the store you go....for a new one.
Oct 25, 2013 | Sewing Machines
No power
Check fuse in plug if fitted, possibly cores in cable have broken, this is most likely to happen at plug and where cable enters body of saw.
You will probably have to open the handle of the saw and do a continuity test with a continuity meter or multimeter from the pins of the plug to where the cores of the cable enter the trigger switch. If this checks out ok, then check brushes haven't worn, check for any overheating on armature.
Feb 28, 2011 | Makita 5007MG Factory Reconditioned 7 14...
Have a honda em5000sx generator 1986. installed battery and pos and neg cable leads, tested and there is 12v at the solonoid and 12v to the starter when the key is turned to on. problem is the starter...
My goodness I just saw your post and I see it has been around since Dec 2010. Your post appeared after I answered a much newer post. (site operates in this manner)
Anyway if you have a 1986 generator and you have 12V DC to the starter with the key on the most likely problem is the brushes in the starter PN: 31215-ZE2-003 or 31215ZR2003
http://ssl.jackssmallengines.com/jacks-checkout/shopping-cart.aspx?CFID=179837&CFTOKEN=92541317
The only problem I have is that I do not know if this is a set or an individual brush. Use the toll free phone number on the link above to confirm quantity.
Once you have the starter removed use some 220 grit or above sand paper and clean up the copper contacts on the starter armature and lubricate the bearings.
If you do a continuity test of the armature using the copper contacts your meter leads must be exactly 180 deg from each other (opposing) to get a resistance reading.
Reading out the stator winding is a matter of reading the + lead terminal to the case.
Thanks for choosing FixYa,
Kelly
Dec 30, 2010 | Honda Mmd 5000 Watt Electric Start...
How to remove the blade
If the saw doesn't have a locking blade button, you need to insert a ( most likely) 14mm thin wrench between the blade and the body of the saw, on the axle, to hold the axle. Unscrew the bolt of the axle and the blade is out. After you place a new one, the procedure is exactly the opposite. Keep the power cable unplugged during the entire time of the blade change. Safety first.
Sep 08, 2010 | Skil 18v Circular Saw saw 18 Volt 5995...
My problem exactly like the others users posted.
If it's not powering up and you have checked the fuses, it needs to go to service. Bad transistors. Common problem. If this is not your problem, I saw 8 or 9 different types posted. If you can clarify it I can help there as well. Post a comment & we can dig further.Hope this helps
Jun 23, 2009 | Pioneer VSX-D409
First Page printing Jibberish with the Zen thing at the end.
Try these.
Reset the Photoconductor Drum Counter
1. Turn off the power using the switch on the back of the printer.
2. Open the front door of the printer.
3. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash.
When the LEDs start to flash, release
Continue button. The LEDs will continue flashing until only Error LED will be lit.
4. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
5. Wait till the printer completes the POST process.
POST is complete when fan noise and rollers stops.
After POST wait for 5 seconds
6. Press Cancel button 4 times slowly until the Toner Low LED is lit.
This is the procedure resetting the counter.
7. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue.
Now only the
Toner Low LED will be lit.
8. Cycle the power of the printer.
- Remove the power cable
- Wait for 5 seconds
- Plug the power cable back to the printer
- Power the Printer on
Feb 24, 2009 | Dell 1720dn Laser Printer
Presario m2000 no power
the same EXACT this happend to me! i didnt know what to do so i just a new charger at dell.com
Sep 12, 2008 | Compaq Presario M2000 Notebook
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Kenwood KDC-7024 CD Player Logo
187 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
