Question about Garmin zumo 550 GPS Receiver
Touch screen issues
When I turn on my zumo 550 (a little over a year old), the touchscreen will not allow any inputs. Once it gets passed the user agreement and goes to the "where to" and "view map" buttons, the "where to" button is automatically selected, but doesn't go anywhere. In order to navigate passed this screen, we have to use the buttons on the left of the unit. Nothing on the touch screen works at all. Do you have any ideas?
  • rsp2112 Mar 09, 2009
    I have the same issues, but sometimes when the unit powers up it automatically asks me if I want to erase all my data
  • Anonymous Apr 27, 2009
    mine does the same thing `can't find what to do
    Scholar:
  • 174 Answers
Has the unit ever been really wet or is there a hole in the touch screen foil? If not have you ever done a cold reset?
. First turn the unit OFF, then HOLD your thumb on the furthest bottom right hand corner of the screen, push as far into the corner as you can on the screen itself. While holding your thumb/finger on the screen press and hold the POWER ON button until you see the ZUMO splash screen, once the splash screen is up you can release the power, but continue to hold your thumb in the right corner of the screen for another 5 - 10 seconds, you should see a window that pops up and asks "Do you really want to erase all user data?", make sure to answer YES to this window, if you don't see this window, then turn unit OFF and try the above instructions again, ensuring your thumb is in the furthest portion of the bottom right hand corner of the touch screen.
Posted on Jul 23, 2008
Zumo550 I use this unit on my motocycle I ride in rain and cold when I press letters on the screen diffrent letters show up also I notice some small inperfection shows under the screen sreen is going...
Have you tried recalibrating the touchscreen?
To calibrate the screen of the Zumo 550, press and hold the power button for about a minute until the screen calibration appears.
Sep 21, 2013 | Garmin zumo 550 GPS Receiver
When pressing letters wrong one show up zumo 550
Sep 21, 2013 | GPS
I have problems with the touchscreen zumo 550 An example: When you press the A activate the B in all the tabs do the same Is there any way to calibrate the screen;
To (re-) calibrate the touchscreen you must hold the power button for approximately 1 minute when turning it on. Then follow the onscreen instructions.
http://garminzumo.wikispaces.com/Tricks
Jan 23, 2010 | Garmin zumo 550 GPS Receiver
Touch screen is a little sluggish
Try cleaning house on it.
Also Try the Garmin web-updater Here to keep it running well.
You could wipe all data and start again,
Backup anything you want first.to the Pc....
Hold bottom right of screen, keep pressing until it says,
Do you want to erase all data, erase it, select yes,
Re-register with Garmin, re-update,
Your good now,
Regards
Apr 16, 2009 | Garmin zumo 550 GPS Receiver
ZUMO CHARGING STATUS
I have had Zumo 550 for 2 years now, and it does exactly the same.
I think it is just the way the unit is, and is not a fault.
Feb 14, 2009 | Garmin zumo 550 GPS Receiver
Garmin zumo switch on problem
Use the allen wrench to remove the battery. Let stand for 5 minutes and replace the battery. It should start fine. Mine has done this 3 times since I purchased it.
Jan 05, 2009 | Garmin zumo 550 GPS Receiver
Can't end Bluetooth phone call with Zumo 550
I have a motorola phone, and it's fine.
I have paired the phone to the zumo, and the phone is set to connect to the zumo automatically.
Check the phone is set up this way, and all should be well.
Hope this helps.
Dec 24, 2008 | Garmin zumo 550 GPS Receiver
No road maps ( Zumo 550
Do you see a map, with street detail? Any SD card installed?
Tap the wrench symbol, tap mapping, tap about, any maps checked? if not, check the apropriate map and go back to the map screen
Jun 07, 2008 | Garmin zumo 550 GPS Receiver
Touch screen not working properly
I'm not familiar with the Zumo family of GPS from Garmin, but if they are similar enough to the StreetPilot, you should be able to recalibrate the screen. In the StreetPilot series, to recalibrate you turn the unit off. Press and hold the bottom right of the screen and turn the unit on. Keep pressing the screen until the calibration information begins. Try this, see if it works on the Zumos, too.
Mar 11, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo gps 550
Hmmm, sounds like a firmware issue, current firmware is 4.20, to update use the garmin webupdater download from the garmin site. PS the issues you mention were with firmware 3.30
Feb 17, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
420 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
