Question about Car Audio & Video
Emergency brake bypass
How can i drive and watch my dvd at the same time?
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Jul 23, 2008
BYPASS THE KENWOOD DDX8017
Im guessing since this is an in dash dvd player your trying to bypass the emergency brake so it will work with the vehicle in drive. If this is the case all you have to do is take the wire that goes to the emergency brake and ground it somewhere.
Mar 04, 2013 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
I have pioneer z2.i want to bypass emergency brake sensor so i can watch movies while driving.any ideas on how to do this
push ur emergency brake in only one click this will not affect ur driving or gas acceleration at all but will allow u to drive and watch ur dvd at the same time
Jun 22, 2010 | Car Audio & Video
How do I bypass the emergency brake on my Eclipse AVN 7000
You will have to connect the brake wire which is pink to the the ground wire.
Apr 27, 2010 | Eclipse (AVN7000) Car DVD Player
Jensen VM8113 how do i bypass the pink wire(emergency break)
I have this exact same unit in my car. All you have to do is connect the pink emergency brake wire to your ground wire. Your dvd's will play if the car is moving or not.
Jan 29, 2010 | Car Audio & Video
Dual xdvd 8625 double din emergency brake bypass
you can ground it,then enter the code 26604 after u insert a dvd real dvd then press stop twice then enter the code it should work
Jun 06, 2009 | Dual XDVD8170 Car DVD Player
I want to bypass the emergency brake wire on my Clarion VRX485VD.
take the grass green wire off of the park brake and connect it to the earth and this will allow you to watch dvd's whilst u drive
pls rate
Apr 08, 2009 | Jensen VM9510 Car DVD Player
Bypass brake
What kind of vehicle? If you can find where the wire to the emergency brake switch (usually there is a switch at the top of the emer/brake pedal) was tapped into. Take a a test light (Bought at auto supply store) and find out if your switch is grounded or has 12vdc when emerg/brake is depressed. If it is grounded then find the wire from th dvd player and attach it to a frame ground. If it is 12vdc find some other source of 12vdc in the fuse box and put the wire to that source. If I knew what type of vehicle I can possible walk you through it.
Feb 02, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Bypassing car dvd parking brake
Usually the wire should be grounded. Connect the wire to a ground point via a switch (is illegal to watch TV/DVD while you're driving)
May 06, 2008 | Dual XDVD8181 Car Video Player
BYPASS
The security device was created to avoid you from watching DVD's while driving. It is simple to bypass. Simply take the parking brake wire (blue/yellow stripe wire) and connect it to the a ground wire (all black wire). This will trick the DVD player into thinking that the car is in park with the parking brake on at all times.
Apr 03, 2008 | Panasonic CQ-VD7001U Car DVD Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
302 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
