Question about Dell W3201C 32 in. LCD Television
Missing channels I hooked up my TV to a basic cable connection using the NTSC coaxial cable connector and after having the TV perform a channel search I am missing a handful or local channels I normally got using my old TV and should get according to my cable provider. Any solutions would be greatly appreciated.
  • antoinina Jul 23, 2008
    I tried all the settings. Auto, Antenna, Cable Std, cable HRC and Cable IRC.....I put the coax cord in NTSC and Digital, I even changed around the inputs....alas I am still not getting some channels and they are random local channels that I should get an none of it makes any sense.
  • 4,234 Answers
Make sure that the set is in the proper mode. There are Air and Cable settings.
Dan
Posted on Jul 23, 2008
  • ABRsvcs Jul 23, 2008
    Have you noticed any pattern to the missing channels at all? Are they clustered in a single range or just random?
    Dan
    I'm leaning toward a power supply problem. Tuning voltages change when channels change. Can you post here the channels that you are receiving and the ones that you are not? I can try to see if there is a pattern based upon the voltage to channel correlation.
    Dan
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
How to connect a philips antenna to a trutech tv
Unplug your television and turn the set around so the back of the set is facing you.
  • 2 Disconnect the antenna or cable connection from the television's "VHF," "Antenna In" or similarly worded port if it is connected.
  • 3 Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
  • 4 Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
  • 5 Plug the coaxial cable coming from the cable television connection outlet into the second coaxial port on the splitter. Use the port next to the one you used to plug the television antenna into.
  • 6 Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
  • 7 Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
  • 8 Plug in the television set and turn it around so the screen is facing you.
  • 9 Use your television's remote control to access the "Menu," "Setup" or similarly worded function. Or press the "Menu" or "Setup" button on the front of the television.
  • 10 Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
  • 11 Select the "Channel Setup" or similarly worded function, then set the input to "Antenna" and perform an "Auto Scan" to locate all available broadcast channels. Your television will locate both broadcast and cable television channels.
  • 12 Scan the channels on your television to make sure all available channels have been found. If you are missing any channels that you know you should have, manually program the channels into your television using the "Channel Setup," "Manual Channel Setup" or similarly worded function.
  • Oct 17, 2011 | Televison & Video
    I have an older tv with only a coaxial cable connection on the back, no others. I have a Magnavox dvd/vcr combo that does have RCA connections available and also a coaxial cable connection on the back. I...
    First make sure you have the cable connected properly.. on the vcr it should be connected to the OUT coaxial connector.
    Second.. the VCR usually has a VCR/TV setting..
    Most TV's must be set to channel 3 or channel 4 to output the signal from the VCR when getting the signal via Coax.
    So..insert a tape...hit play..tune the tv to channel 3 if you are not getting the playback signal..press the VCR/TV button on the vcr or vcr remote.
    Repeat this on Channel 4
    Check your cable to make sure the connections are tight.
    Finally check your television menus for Input settings..make sure it is set to COAX/ANT
    Make sure your VCR's output is not on some alternate output like L1 or L2 (line one or line two)
    Best of luck!
    Apr 22, 2011 | Televison & Video
    I hooked up my proscan to comcast cable, i can just get first 13 channels.i tried going into settings and doing channel search, it will only clickon analog, not digital channels what can i do to get the...
    Cocast may have only transmitting NTSC Ch 2~13 only for your area, to get more channel you may have to use Comcast cable box, I am in bay area, I can get 2~35 for basic plus service, I can get 2~13 for the most simple service for less money. What is your serivce level you are paying for?
    Your TV also anly has NTSC tuner, there is no QAM or ATSC turner.
    TV SPEC; http://reviews.cnet.com/flat-panel-tvs/proscan-26lb30qd/4507-6482_7-33403393.html
    You may have to call Comcast.
    Mar 09, 2011 | Proscan 26LB30QD 26 in. LCD HDTV
    Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
    If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
    Jul 22, 2010 | Sharp 27N-S300 TV
    Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
    If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
    If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
    To view or record a CATV channel:
    1. Tune the TV to the Recorder output channel (CH 3 or 4).
    2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
    3. Select a channel using the cable converter.
    With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
    Oct 20, 2009 | LG RC897T DVD Recorder/VCR Combo
    Can't figure out how to turn on cable on Sony Trinitron TV
    Setting Up the TV
    After you have finished connecting your TV, you can use Auto Program to set up your
    channels. During Auto Program, the TV will automatically search for available channels and
    program receivable channels.
    (Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
    1 Press to turn on the TV. The Initial Setup screen appears.
    2 Press on the remote control or on the TV front panel to start Auto Program, or press
    to exit.
    To perform Auto Program again
    Press .
    2 Press g to highlight Channel Menu.
    3 Press f to highlight Cable. Press to select.
    4 Press F or f to highlight On or Off according to how you connected your TV. Press to
    select.
    5 Press f to highlight Auto Program. Press to search for channels.
    6 After Auto Program finishes, press to exit.
    To reset the TV to factory settings
    Turn the TV on.
    2 Hold down on the remote control.
    3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
    then back on.
    4 Release .
    ✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
    available. Perform Auto Program again to program receivable channels.
    ✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
    Initial Setup
    Auto Program [CH+]
    [CH–]
    First please connect
    cable/antenna
    Exit
    Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
    How to hook my directv to digital input to lcd tv j32l637
    I don't know what flat screen tv you have,but you must be aware of the coaxial input behind the TV.It could be analog input,digital input and OUTPUT!!
    Anyway,if you connect your basic directv box to your digital input,it will not serve you any purpose to get HD channels and you don't have the HD directv box.The TV will not display digital channel for you because if you use coaxial input to TV,you should be under either channel 3 or 4 and be sure either channel had been saved under memory.In order to change channels,you will need to change it from your directv box.
    JUST LIKE a VCR connect to TV.TV will be under channel 3 or 4,and you will change your channels from the VCR.Don't forget to scan all the channels from the VCR!
    solutiondoct
    Nov 11, 2008 | Televison & Video
    Dell W3201C 32 in. LCD Television Logo
    142 people viewed this question
    Top Dell Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Jaime Hernandez
    Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
