Rowenta Powerglide DE011 Iron with Auto Shut-off Logo
Posted on Feb 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an older (1997) Rowenta DE 11 Powerglide iron. In the process of cleaning it, I mixed up the order of the wires. The colors are brown with the power cord, dark blue with the power cord, blue by itself and blue with a black. Looking that the bottom from left to right, I am trying to determine the correct order. I know this is a long shot. I've looked online but haven't been able to find anything else useful.
Jacques Alexandre
Level 2:
Sergeant:
  • Expert 183 Answers
  • Posted on Feb 10, 2011
Jacques Alexandre
Expert
Level 2:
Sergeant:
Answers
183
Questions
0
Helped
38199
Points
567
If you can take a sharp picture of the circuit board and send it [email protected] I might be able to help you.
P.S. Make sure all wires and circuit board are clear.
1helpful
My Rowenta Power Glide DE-08 iron has stopped working. Once, if I moved the cord around it worked. So I I took it apart and checked the wiring connection which seemed to be tight. I then plugged it in...
hi.
you will probably find that the cable is broken where it comes out of the iron.
this is not an unusual problem as the wire is being constantly bent and straightened here, and eventually breaks.
take the iron apart as you did before to check the connections, and cut of the last 4-5 inches of the cable and reconnect in exactly the same way it is now.
this should cure the problem.
hope this helps
7helpful
2answers
How to hardwire rowenta powerglide to bypass safety switch
lancell - you're an idiot...of course he understands - that is why he is asking!
2helpful
2answers
Wiring diagram for Rowenta DE-05
I have a DE-05 that needs a new cord and cleaning of steam discharge holes. I'll be gald to take photos and send them to you if you'll share your source for parts and method of disassembly. Contact me at chuxbizAThotmail.com, just replace the AT with @.
Thanks,
Chuck Jones
1helpful
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Rowenta powerglide 2
Rowenta DE-09 will not turn on. Plug it in and nothing happens. Is a fuse blown or some problem similar to that happening? Thanks
Chirs
[email protected]
2answers
Rowenta Iron
TO CLEAN THE BOTTOM OF THE IRON, MY NAN USED TO ALWAYS IRON BROWN PAPER, IF THIS DOES NOT WORK, USE A RAG DIPPED IN THINNERS, OR LIGHTER PETROL AND RUB GENTLY.
NORMALLY THE SELF CLEAN SYSTEM IS JUST A BUTTON NEAR OR ON THE TANK THAT YOU PRESS WHILE THE IRON IS ON AND HAS WATER IN, PRESSING THE BUTTON WILL FORCE WATER THROUGH THE STEAM JETS (SO KEEP IRON FACING DOWN) ALSO EMPTY THE IRON AFTER EVERY USE
Top Rowenta Irons Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
