Question about ASUS A7V8X Motherboard
PROBLEM IN MOTHERBOARD
HI MY COMPUTER IS ILL,WHEN I SWITCH ON ,A SCREEN APPEAR SAID CHECK CMOS
  • 2,794 Answers
Is could need a new cmos battery. Look on your motherboard for a battery the size of a quarter. There ease to replace but be careful that you don't bend the metal clip.
Posted on Jul 23, 2008
How can i reset the cmos in my ms200 all in one computer?? it shows that my hasrd drive is not working, and it is really working in other computer
To reset the CMOS the easiest way is, remove the motherboard battery for ten minute then install it again. It will clear the CMOS. Then reset the CMOS/BIOS setup, date/ time etc. Another way to clear CMOS is, reset the CMOS Jumper in motherboard.
To detect your hard drive you can try to check by change the hard drive cables. Change the port in motherboard. Check the BIOS setup and reset it if need.
Jul 06, 2011 | HP Pavilion AllinOne MS214 185" Desktop PC...
Hi! My hard drive is password protected. I do not know what it is. I tried to use it as a slave drive but it wont appear in my computer. What will I do?
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 07, 2011 | Computers & Internet
We have a Sony VAIO, VGC-LV290J. When plugged into an outlet, the machine's fan just revs. The "VAIO" splash screen does not appear and the screen remains blank. The Bluetooth keyboard does...
It seems that the 'POST' (Power On Self Test) is not starting, and thus is not displaying the "splash" screen. The fans will run at 100% until the POST completes.
But, if the POST does not complete, the fans will "roar".
Check for a defective CPU, or defective RAM, or a defective motherboard.
It probably is *NOT* the CMOS battery -- if that battery is dead, then the "default" settings should allow the computer to start (with the wrong date/time).
Mar 15, 2011 | Computers & Internet
Came home computer was on black screen and now it won't reboot. When I try to reboot, I get a "cmos checksum error ". Keyboard also isn't working. What could be the problem?
The CMOS checksum error occurs when the CMOS battery is worn out and the CMOS data gets corrupted. Replace the CMOS battery, this battery most likely a CR2032 lithium coin size button battery - check to make sure before you purchase.
After replacing with a new battery, then go to the BIOS configuration and set the Time & Date etc.
Sep 02, 2010 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Computer begins to start up and then turns off after windows xp is displayed. Reformatted drive installed windows 2000, same thing happens
The issue that you experience might be problem of your power supply please change the location or check the power supply of computer. If you shut down your Windows XP-based computer, your computer may restart instead of shutting down. The computer may also restart unexpectedly while you are using the computer to perform certain tasks. An error message may appear on a blue screen when the computer restarts.
For more information, please click the link below;
http://support.microsoft.com/kb/320299
Moreover, check the motherboard, CMOS battery or SMPS, as that might be one of the reason. Any of such device not functioning properly may cause computer restarts automatically.
Regards,
Anirban Mazumdar
Computer & Accessories Category Expert
May 30, 2010 | E-Machines eMachines Desktop PC
Hello, Trying to update this motherboard, now cpu celeron 3.20G 533ghz and would like to update to pentium 4 3.6G 800ghz that the user's manual says is doable. The problem is the motherboard will not...
Always remember that when you add new hardware like a processor or faster memory you have to clear the CMOS to reset the BIOS to defaults so it will recognize the new hardware. Sometimes you have to do this with hard drives particularly SATA drives.
On the motherboard, near the motherboard battery look for a small coloured plastic jumper. If your motherboard has one it will be marked as CLR_CMOS. Just move the jumper to the other position and press the on/off button. That will clear the CMOS.
If you don't have a CMOS jumper then remove the power cord from the back of the computer and take out the BIOS battery for half an hour or so. Replace the battery and plug in power. Turn the computer on and hopefully the the computer will boot and you will see a splash/post screen. If you do remember to set the correct date and time in the BIOS utility.
If your still not getting a post screen go back and check the processor is compatible with the motherboard. Check that the processor is locked in the socket properly and also check to make sure your system memory is seated properly.
Post back if need anymore advice.
Reagrds.
Sep 29, 2009 | Mach Speed P4MBMS Motherboard
Hi, when i boot the system nothing appear on the system. i initially checked my ram it was not workinhg so i bought a new one but still the system won't start up!! it is a p4, intel d865, 512 ddr ram ,...
If you doesn't hear any beeps, at least you must hear one beep.
Clear CMOS or remove the Lithium Battery CR2032 in the motherboard about 1 minute, to know which MB is hang up with processor, then put it back again & power it on.
Aug 17, 2009 | Personal COMPUTER - LENOVO THINKCENTRE A61...
CMOS problem! help!
Change M/board battery
if it keep going flat check all contacts are clean and not distorted
Oct 03, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Won't load windows...
hi Lus;
What color do you have on the power button of your monitor? Check the VGA port at the back of your computer, how many VGA ports do you have? if you have 2, try the other port instead,
here is a VGA port:
http://www.google.com.ph/search?hl=en&q=VGA+port&btnG=Search&meta=
hope you see the images,
ill wait for your feedback
Jun 19, 2008 | HP Pavilion A730N (PJ510AA) PC Desktop
Poweredge 1650 not booting
It is possible the mainboard/motherboard is bad. However, you might want to check the internal fans on the 1650 to make sure they are not clogged or they are not obstructed. That would be the
first thing to check. After that if nothing work, then look to reset the CMOS (you should simply be able to short a jumper for them) or just simply take out the CMOS battery for a minute, then reconnect it.
Mar 19, 2008 | Dell PowerEdge 1650 Server
ASUS A7V8X Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
